Anamorphot lens compatibility
Arturo Chu
In theory it should. The front element of the Voigtlander 40mm f/2.0 Ultron SL II is smaller than 50mm in diameter and it is a pancake prime lens lens. You would probably need to stop down to f/2.8-4.0 to shoot. Keep us posted!
The Canon EF 40mm f/2.8 STM and Pentax 45mm f/2.8 is already reported to work at f/2.8. It is best if you could try for compatability before commitment to buy the taking lens as you are using it as a taking lens for the Anamorphot 50 and not a regular prime lens.
