Technical analysis of the new Canon EOS C300
[html]
[img]http://www.eoshd.com/wp-content/uploads/2011/11/eoshd-canon-c300-specs.jpg[/img]
The Canon C300 is the first in the company’s new Cinema EOS line-up, a high end range of digital movie production cameras. The range will later be expanded say Canon, to include 4K movie cameras, a 4K DSLR, a camera for run & gun documentary makers (presumably with an auto-mode that the C300 lacks entirely) and a lower end offering priced for indie filmmakers.
[url="/"]Read full article[/url]
[/html]
Guest tuliocampregher
[html]
Gosh, The RED Scarlet X beats it to pulp on half the price. But then comes marketing and RED’s reputation for vapourware.
[/html]
Guest danyyyel
[html]
For $ 6000/7000 it would have been ok, but $ 20000 for a camera that cannot do 60 fps 1080p is a joke. We are already seeing it in many sub $ 1000 camera. so they can’t put it in a $ 20 000 one. If one processing chip cannot do it then add another one make the case a little bigger, no one is going to dye if it is 5 cm larger. What I see in this camera is greed, they just surfed on their dslr success and thought that they could put anything at any price and everybody would applaud them.
This camera does not have one selling point against for example a Sony F3 or now the Sarlet-X, is it the fastest, highest resolution, DR, codec etc.. None I can see. One example is comical, it can’t auto-focus with the Canon EOS lens but the RED can. I know that manual focusing is used more in the film narrative market but it does not mean that it has no use (steadicam shot for example).
[/html]
Guest Arie Van Dam
[html]
Ever worked with RED cameras? Specs is not everything!! I’ve shot a Feature and 15 videoclips with RED… Because I had to.. But I do not like them. Arri Alexa and Sony F65 are my favourits. Reliability!!!!!!!!
[/html]
Guest Arie Van Dam
[html]
Autofocus on steadycam??? Never have done that before. Will not work . You need a wireless focusunit and a focuspuller.
[/html]
[html]
“Canon say the sensor is capable of it but the image processor isn’t.”
They have the courage to say it ???? Like they couldn’t afford to put a newer processor in it. RIDICULOUS
[/html]
Guest Fandongo
[html]
“Will not work. You NEED A WIRELESS FOCUSUNIT AND A FOCUSPULLER.”
Err… t2i + magic lantern can pull focus (with AF lenses) thru the lcd sensor without touching the camera.
That means t2i (1lb) plus a glidecam 1000 is greater than or equal to team of dbags achieving the exact same final result.
You don’t NEED anything but your mind.
And a company that hasn’t lost theirs.
[/html]
[html]
Pretty much agree except that, by looking at the illustrations Canon put up, it is in fact a traditional Bayer sensor but instead of demosaicing/interpolating it just uses a 2×2 block of the RGGB pattern to spit out one pixel with a red, blue and green reading. This sounds like what Sony is doing on their more expensive models as well. It certainly reduces the processing needed once the data come off the sensor, 2mp each of RGB data ready to go is a lot easier to push through than 8mp of data that needs demosaicing, that’s what probably allowed them to use existing video processing chips. The cinema/DLSR hybrid camera however sounds like it will have to do some pretty heavy lifting since it will have to go through the exact process the c300 is avoiding.
All in all Canon’s roadmap for the next few years is starting to shape up, still a lot of unknowns but we can see now what they’ll be doing: dedicated cinema cameras like the c300, hybrid DSLR/movie systems like the red C, and traditional SLRs with video specs similar to the 1dx. I’d really love it if the hybrid DSLR/movie camera trickles down to the lower end but I bet Canon will take their time getting around to one, especially if the higher end model sells well. It’s a rather conservative but pretty sound model, they seem to know where they want to go and how they want to get there (unlike Nikon).
[/html]
Guest dayoldbread
[html]
Red’s codec has a lot of problems as well. I have DITed on a lot of Red One shoots where we lost clips to error and that sort of thing (fear the green screen of death). That being said 720p 60p being the only in camera slow mo is going to be a really deal breaker for a lot of high end DPs I know. I kind of feel that it should be as well. We have come so far in the camera wars and to have a function that was on the HVX200 is kind of well ridiculous. Before you say anything I know that it is 10bit and that they don’t want to push their processor but the DPs I work with don’t really see those things. All they see is 1080p and 720p. The fact that 10bit is a way better image doesn’t cross their mind.
[/html]
Guest gecofilms
[html]
Arie, you are wrong; the new functions of the cameras like FACE FOCUSING, allow us to mantein focus in some pre-set points, ant the autofocus system do the job, works perfect, not for all situations, but is very good on stedycam shots when you are following someone or something. And the other thing I did’t hear about is the steadyshot for diferent kind of lenses on the C300
[/html]
Guest Arie Van Dam
[html]
Facefocussing steadyshot….. what are we talking about… amateur stuff or profesional filmmaking??
I don’t get it! You need a proper reliable camera and manual focussing lenses and a professional DP.
That’s it!!! I’ve made feature films, music videos, commercials and documentaries for over 15 years.
Can’t stand ll this ……. Stay with the t2i and glidecam. Do not know what you have on IMDB?
[/html]
Guest Fandongo
[html]
I Drive a Dodge STRATUS!!
The whole point of the DSLR movement… the reason it’s terrifying is not because of what they are.
They symbolize an idea. A movement.
The 5d2 was a film competitor the second it came out, doubly so if you could afford accessories.
That was 3 years ago.
Do you think there was no outside pressure, no threatening influence keeping them from pushing as far and fast as they can truly go??
Consumer equipment is baby steps away from being able to perform previously unthinkable things (like being superior to film in every way).
The competitive advantage does not = he who wastes the most resources.
There is something to putting on a show for everyone, making it look like a “real” production.
It forces people to take it seriously.
There is a great blurring of the line between professional and amateur.
Recording/lighting/editing equipment is being revolutionized every 6 months.
For so long people have only done one thing, and they did it great.
MUCH, MUCH less is needed now (the intent, understanding, and vision still has to be there).
On Harry Potter 6 they built two tarantulas…One Million dollars EACH!
a massive one for the regular actors, and a slightly smaller one for Hagrid.
The problem is, they were comping in the background (and the majority of the movie) anyway, and his character doesn’t interact with it.
$1,000,000. They should be imprisoned.
But, *shrug* that’s just the way it is.
That’s what i find so fu$%ing offensive about the c300.
It’s a whole new in-your-face wasteful, overweight solution.
Canon: Because We Can!
stupid.
But you’ll look professional.
I can’t wait for people to 4k pixel peep on youtube swearing there’s a difference between the $6.8k cinema primes and old nikons.
Until we project 4k…and even then, i bet nobody can tell.
The point – one day, everyone is going to wake up without a job.
And the funny thing – they won’t even see the glaringly obvious coming.
Just ask Kodak.
Lack of vision – Lack of innovation.
There’s a reason features like video tracking autofocus on the gh2 got removed after preproduction.
It’s the same reason it will never exist.
Existing means someone will find a way to make it better.
I don’t expect any non-hack related functionality advances in consumer/prosumer cameras.
For one big reason.
It threatens the well being of “professionals”
“professionals” have always done it X way.
idiots do it Y way.
Y way is not as good, but it’s basically free + requires less non-essential man power.
*update, Y way matches X way.
Y way surpasses X way.
I think Darwin had a theory about this.
Scary.
But we’re coming anyway [img]http://www.eoshd.com/wp-includes/images/smilies/icon_smile.gif[/img]
Best of luck sir,
Stay the Course!
[/html]
Guest SelwynReed
[html]
The Scarlet X isn’t half the price in any real terms. Unless you already own an EPIC and supporting gear you’re not going to be shooting anything useful with a Scarlet for much less than $20k.
When you consider the additional workflow issues in handling the much higher datarates as well you are looking at spending quite a lot more with Scarlet than the C300.
I don’t think the C300 is especially well suited to feature films, but then neither is the Scarlet. I do think the C300 is ideally suited to TV production. And also apparently will make a great B-cam to the Alexa.
[/html]
Guest worldwidewes
[html]
That’s a fairly condescending tone for someone with only a few years experience. It’s better to solve problems using “amateur” means, than to decide beforehand that they can’t be overcome.
There’s an old saying “When your only tool is a hammer, every problem looks like a nail.”
If a DP tells me he can’t solve a problem – I hire a new DP who will do what it takes, even if it means “lowering” himself to using “amateur” tools.
When a “professional” uses a tool to solve a problem on set – voila – that tool is magically transformed into a “professional” tool.
But if a “professional” cannot solve a problem on set because his mind is limited – voila – he is no longer a “professional” creative, but a slave to manufacturers.
I’ve been working in film and video for a few decades – I’ve seen a lot of ingenious problem solvers use a lot of tools in clever ways. We once went from full 35mm BL-IV’s to SD news cams, to Polaroids all on the same movie Whatever Works – each tool worked its magic according to the needed images. There is no need to limit yourself to “professional” methods while denigrating your fellow filmmakers use of “amateur” tools.
[/html]
Guest Fandongo
[html]
i miss taking “Polaroids”. I do hope one day they rise from they ashes, creating a camera that can print onto paper that’ll play the clip you just shot.
wait, aren’t there ipads/ipods/droids?
anyone notice how nothing is integrated well (for dslrs), particularly for video?
stupid.
Not spending $500-$6400 for a camera monitor or EVF in an ipad world.
We can has thunderbolt?
[/html]
Guest charleslim
[html]
Give them a break – This canera is a video camera from their video people. LOL at least it’s not XF 305 part 4!
[/html]
