Wild Ranger Posted November 26, 2020 Share Posted November 26, 2020 zerocool22, Belle and Kisaha 3 Link to comment Share on other sites More sharing options...
habeel Posted November 26, 2020 Share Posted November 26, 2020 @Andrew Reid Check this out. Link to comment Share on other sites More sharing options...
androidlad Posted November 26, 2020 Share Posted November 26, 2020 The guy @Matt Perks is actually a member of this forum. Link to comment Share on other sites More sharing options...
Popular Post Matt Perks Posted November 26, 2020 Popular Post Share Posted November 26, 2020 I am indeed! I meant to thank bloggers (including Andrew specifically) for bringing the issue of overheating up so much. The pressure about the timer nonsense forced Canon to change the way the camera monitors temperatures, which is the reason the mod works at all. Mark Romero 2, Wild Ranger, jack jin and 11 others 9 4 1 Link to comment Share on other sites More sharing options...
mkabi Posted November 27, 2020 Share Posted November 27, 2020 6 hours ago, Matt Perks said: I am indeed! I meant to thank bloggers (including Andrew specifically) for bringing the issue of overheating up so much. The pressure about the timer nonsense forced Canon to change the way the camera monitors temperatures, which is the reason the mod works at all. You should create a mod-kit. I mean... kickstarter is all you need to get it started. You don't even need to do so much either. You have the demo of it in the video (already).... sell the copper cut-out piece with the thermal paste at $250 a piece with a warning (voiding warranty). You don't need the fan.... just changing the 2 hour recovery time to 5 min. is more than enough. Link to comment Share on other sites More sharing options...
gt3rs Posted November 27, 2020 Share Posted November 27, 2020 Pure speculation mine but I think Canon did not route the heat to the back of the camera because people put their face there if they use the EVF.... a great solution for getting sued for burns. On the bottom seems safer. Or maybe the C90 would have a nice integrated cooling fan a la C70 with R5 internals..... Link to comment Share on other sites More sharing options...
Video Hummus Posted November 27, 2020 Share Posted November 27, 2020 @Matt Perks idea in the video of Canon being slightly more brave and business savvy of designing the heat sink to dump heat to the tripod mount and then selling a battery grip or standalone component that increases cool down times was a massive missed opportunity and quite a fail imho. They could have almost eliminated all the bad press and made bigger margins on their camera by selling an accessory or a upgrade service. 🤷♂️ Hell for all we know they might release a R5c that is $1500 more that is simply this heat sink mod! Link to comment Share on other sites More sharing options...
mrtreve Posted November 27, 2020 Share Posted November 27, 2020 Sweet. I've never made a product, but could the copper part be sent to a manufacturer as a prototype? I would happily use this mod - warranty be damned. I probably wouldn't even bother with a fan as it'd likely cover my needs as a B-cam on its own. mkabi 1 Link to comment Share on other sites More sharing options...
Wild Ranger Posted November 29, 2020 Author Share Posted November 29, 2020 I think that the copper heat spreader only is by far the best mos practical solution, and also good enough to keep it cool. mkabi 1 Link to comment Share on other sites More sharing options...
UncleBobsPhotography Posted September 18, 2021 Share Posted September 18, 2021 Kolari vision has basically copied this solution and now sells it either as a DIY kit or as a mail in service: https://kolarivision.com/product/canon-r5-cooling-mod-service/ https://kolarivision.com/product/diy-canon-r5-heatsink-overheating-kit/ And here is the tutorial: https://kolarivision.com/r5_cooling_mod-tutorial/ Has anyone tried it? $299 is expensive for a small piece of copper, but if it solves overheating for a $4000 camera it can be well worth it. I'm also a bit worried that the rubber grips will be a bit loose after removing and reattaching it. Link to comment Share on other sites More sharing options...
Django Posted September 19, 2021 Share Posted September 19, 2021 Interesting, any idea if something similar is possible for the R6? Link to comment Share on other sites More sharing options...
