majoraxis Posted November 29, 2020 Share Posted November 29, 2020 Hi, There are a few Free Black Friday Audio Plugins - Waves and Slate Digital that are worth getting while they are still available. Waves - CLA EchoSphere - Take a Lexicon 480 Plate Reverb and a Tape delay. Great for music vocals or try in for post an use a small rooms with little or no tape delay for ambience. https://www.waves.com/lpn/black-friday-2020/free-plugin Slate Digital - Fresh Air - high frequency enhance that mimics the dobly A stretching audio trick - add to vocal or voice over to add clarity and intelligibility. https://slatedigital.com/fresh-air/ Both free for a limit time, and time is almost up. BTM_Pix 1 Link to comment Share on other sites More sharing options...
IronFilm Posted November 30, 2020 Share Posted November 30, 2020 This was my Black Friday audio plugin purchase: https://klevgrand.se/products/brusfri Link to comment Share on other sites More sharing options...
majoraxis Posted November 30, 2020 Author Share Posted November 30, 2020 Black Friday audio purchases: 1. DDMF Metaplugin https://ddmf.eu/metaplugin-chainer-vst-au-rtas-aax-wrapper/ allows you to over sample your entire audio processing chain inside Metaplugin for better bass response on compressors, limiters, clippers, and dynamic eq 2. FLATLINE - Mastering Clipper https://www.submissionaudio.com/products/flatline I run this before Voxengo Elephant Limiter to excellent effect providing clean loudness without losing bass or distorting the mid range as many Clipper and Limiters do. I run both inside DDMF Metaplugin over sampled 8x for best bass response. 3. Voxengo TEOTE Automatic Mastering Plugin https://www.voxengo.com/product/teote/ I purchase this a month ago but it is on sale for Black Friday. Excellent dynamic automatic eq that allows you to balance your mix and it constantly updates based on spectral content. A missing link in my mastering chain. Also has better bass when over sampled in DDMF Metaplugin. in general TEOTE help fill in the bass frequencies and would be excellent for post production. 4. DDMF Comprezzore https://ddmf.eu/comprezzore/ Compressor that can be used for mastering which allows you to plot your compression ratio curve so you can have a deeper amount of control than you normally would have over compression and it is pretty transparent. I use it as dynamic problem solver for mastering. Link to comment Share on other sites More sharing options...
