AnthonyBert Posted February 16, 2014 Share Posted February 16, 2014 Andrew, Can I assume that the same rule would apply to my 1DC? If so, can i do the whole process in davinci resolve? turn the footage to 10 bit and then downscale and export to prores444? Link to comment Share on other sites More sharing options...
Brian Williams Posted February 16, 2014 Share Posted February 16, 2014 The BM pocket aint consumer level. It's nearly impossible to use for anything pro, let alone for consumer use... The average consumer doesnt spend £300-£400 on media to get an hours worth of recording time, a decent evf, rigging, and lenses to fulfil consumer purposes. The gh4 will deliver everything a consumer needs while also servicing the enthusiast, professional and semi pro sectors. This makes no sense. I have a pocket, I don't have any rigging on it 99% of the time, nor do I have (or need) an evf. You'll be able to format your cards in camera, but that's not a big deal to me. The GH4 will require the same amount of $$ for lens as the pocket. And shooting 4k on it, you're gonna pay a pretty penny for your sd cards, too. The GH4 sounds great, but don't be so damn negative about other cams! Link to comment Share on other sites More sharing options...
Administrators Andrew Reid Posted February 16, 2014 Author Administrators Share Posted February 16, 2014 Previous discussion thread: '?do=embed' frameborder='0' data-embedContent>> Discussion continues here, thank you to all contributors so far (and please let's stay on topic as I feel there's a lot to be gained from this info...) 1D C - yes same should apply to that. As for the actual workflow technique, perhaps others can chip in on how they would go about doing this... I have never tried it myself. Link to comment Share on other sites More sharing options...
AaronChicago Posted February 16, 2014 Share Posted February 16, 2014 So would you edit in a 4k timeline, then render out a cineform 1080 10 bit file, then grade? Just trying to get my head around the workflow. Link to comment Share on other sites More sharing options...
James Benet Posted February 17, 2014 Share Posted February 17, 2014 This recent DVX discussion seems to suggest that the 4:4:4 you get are not the same as real acquired 4:4:4. You get more info per pixel but not any new color information. The Hues that you get in 10bit from initial will not be there, you will only reduce artifacts and noise which is better but not true 10bit. DVX Discussion on 4k 4:2:0 to 1080p 4:4:4 Until we get footage from the GH4 and we process it this way to clear banding and do green screen work, we will probably never know for sure because the codec implementation could be the deciding factor here. Link to comment Share on other sites More sharing options...
Administrators Andrew Reid Posted February 17, 2014 Author Administrators Share Posted February 17, 2014 What camera does real acquired 4:4:4 though? Not many, especially not at $1999. Let's see the end results and compare to 10bit 1080p 4:2:2 on other cameras and then judge it. The theory holds tight mathematically. tosvus 1 Link to comment Share on other sites More sharing options...
James Benet Posted February 17, 2014 Share Posted February 17, 2014 We can try a test with the 4:2:0 1080p we have now on current cameras. Shoot a clip that has banding or green screen and reduce it to 1/4 1080p or 480x270 pixels on a 16bit After effects timeline after doing the conversion to cineform 10 bit. If the 8bit codec sample is cured of banding and you get a clean key then the theory holds true. It will be the same average but down-sampled to 1/4 HD res. Link to comment Share on other sites More sharing options...
Administrators Andrew Reid Posted February 17, 2014 Author Administrators Share Posted February 17, 2014 Yes but once you start getting down to such tiny resolutions, can you properly measure the results? Link to comment Share on other sites More sharing options...
tosvus Posted February 17, 2014 Share Posted February 17, 2014 should be easily testable as someone with an external recorder could do both types of recording on the gh4. What camera does real acquired 4:4:4 though? Not many, especially not at $1999. Let's see the end results and compare to 10bit 1080p 4:2:2 on other cameras and then judge it. The theory holds tight mathematically. Link to comment Share on other sites More sharing options...
Administrators Andrew Reid Posted February 17, 2014 Author Administrators Share Posted February 17, 2014 Indeed that would be an interesting comparison. I'll add it to my list! Link to comment Share on other sites More sharing options...
Natureflixs Posted February 17, 2014 Share Posted February 17, 2014 So I downloaded the 4K Panasonic footage from youtube. My editing system, Edius 5.51 does not do 4k. I dumped the 4k footage into Edius AVCHD Converter and converted it to Edius HQ 1080p .avi file. Is there any benefit to doing this other than being able to edit it? Keep in mind that Edius 5 is 8-bit. Link to comment Share on other sites More sharing options...
Administrators Andrew Reid Posted February 17, 2014 Author Administrators Share Posted February 17, 2014 Don't download anything from YouTube. It is mega heavily compressed. YouTube do not serve the originally uploaded file like Vimeo. You will not be able to download a high bitrate file from there let alone a ProRes clip. To test this we need original 100Mbit MOV files from the GH4 or a 4K ProRes master uploaded somewhere. Link to comment Share on other sites More sharing options...
Nikkor Posted February 17, 2014 Share Posted February 17, 2014 If you have 4 pixels with the same value (there is noise so this isn't going to happen), you will get the same value afterwards. And that value was obviously just an rounup into 8bit, so it's not the same as the one you would get with 10bit. Obviously it's not the same as taking 10bit directly. Link to comment Share on other sites More sharing options...
HurtinMinorKey Posted February 17, 2014 Share Posted February 17, 2014 let's make this even simpler, and use a dynamic range to show why you can't always resurrect higher bit depth (even with error diffusion): Assume there are two types of A/D conversion: 1 bit (taking on the value of 0 or 1) 2 choices 2 bit (taking on the values of 0 1 2 3) Let's assume that analog values are: (0.1) (1.2) (2.0) (2.1) (3.0) (4.1) and that A/D conversion assigns the closes possible digital value. 1 bit A/D conversion becomes: (0) (1) (1) (1) (1) (1) 2 bit A/D conversion becomes (0) (1) (2) (2) (3) (3) at half resolution you get either: (0) (2) (3) or (1) (2) (3) either one represents 3 levels of light , which you cannot represent in just 1 bit. Is this a contrived example, yes. But the point is to try and show they are not mathematically equivalent. maxotics 1 Link to comment Share on other sites More sharing options...
Administrators Andrew Reid Posted February 17, 2014 Author Administrators Share Posted February 17, 2014 OK let's put this in context HurtinMinorKey please. What affect does your theory have on the end result, are we arguing here over a tiny technicality / mathematical proof, or is it a serious issue which will mean we get nowhere near a higher bit depth as David and others are suggesting? Link to comment Share on other sites More sharing options...
piz Posted February 17, 2014 Share Posted February 17, 2014 This is awesome news! For those who only want pristine 1080p would be then downscaling to 1080 4:4:4 and then grading or would we be grading in 4k 4:2:0 and then scaling down? Link to comment Share on other sites More sharing options...
maxotics Posted February 17, 2014 Share Posted February 17, 2014 OK let's put this in context HurtinMinorKey please. What affect does your theory have on the end result, are we arguing here over a tiny technicality / mathematical proof, or is it a serious issue which will mean we get nowhere near a higher bit depth as David and others are suggesting? If a pixel in the camera reads 14 bits of data you CANNOT get all of it back once you truncate to 8 bits of data. Certainly, there will probably be modest color/luma improvements by downsampling fomr 4K, but only within its 8bit dynamic range. That is to say, IN PRACTICE, if you shoot a scene that falls within the CODEC's dynamic range output you may get better color nuance through average of neighboring pixels. But if the neighboring pixels are choppy then you're just going to create artifacts. However, you cannot get values from those RAW pixels that were out of the 8bit range they took from the 14bits. I don't mean to be rude, but you're confusing color bits with compression bits. People who read this thread who think the GH4 is going to do what the Blackmagic cameras, ML RAW, or high end RAW based cameras do should understand this. nazdar 1 Link to comment Share on other sites More sharing options...
Nikkor Posted February 17, 2014 Share Posted February 17, 2014 It means that this is no magical cure for banding. Once you compress your 8bit range to get out the dark bits into safe zone and highlights you end up with even less range which gives you even more banding, and banding affects more than 4pixel clusters so you will still have it. Link to comment Share on other sites More sharing options...
HurtinMinorKey Posted February 17, 2014 Share Posted February 17, 2014 OK let's put this in context HurtinMinorKey please. What affect does your theory have on the end result, are we arguing here over a tiny technicality / mathematical proof, or is it a serious issue which will mean we get nowhere near a higher bit depth as David and others are suggesting? I'm not sure exactly about the practical implications. The math seems to indicate that we cannot get 10-bit DR benefits out of 8-bit by downsampling. Maxotics, I was wondering when you'd show up! You probably have as good a handle on this as anyone. In Andrew's defense, I think he has been led astray by a Software guy at GoPro. But the idea of error diffusion got me thinking. While we cannot resurrect the full DR of 10 bit, perhaps we can do a decent job of approximating this precision within the DR limits. Link to comment Share on other sites More sharing options...
Guest Ebrahim Saadawi Posted February 17, 2014 Share Posted February 17, 2014 Thank you for the article and continued discussion in this thread. Very exciting information really! Link to comment Share on other sites More sharing options...
