simonfilm Posted February 17, 2014 Share Posted February 17, 2014 Imagine you make a Chroma Key with the GH4. And the final result has to be 1080p What would you do? With native 4K 8bit 4:2:0 (and after that convert to 1080p) OR with converted 1080p 10bit 4:4:4? I understand that it would be better the first option, because you work with more data, but perhaps the second one has other advantages... Simon. Link to comment Share on other sites More sharing options...
Michael Ma Posted February 17, 2014 Share Posted February 17, 2014 Increased dynamic range? I would think yes and no. Yes for when you are talking about less noise in the shadows, but not when it comes to any stops gained for recovery purposes. ScreensPro 1 Link to comment Share on other sites More sharing options...
Michael Ma Posted February 17, 2014 Share Posted February 17, 2014 Hi, im new in the forum. I understand this can be do too with gopro hero 3 2,7k fotage, more accesible. I was trying do it today without results (in AE). Somebody know a specific way to do it? I think that Cineform Studio free version (now called GoPro Studio 2.0) can do this. In step 1, convert your file to CFHD (in the same resolution). It is inflated to a 10-bit file. Step 2, select file. Step 3, export to custom settings, choose MOV container, scale down to 1080p, you can choose Film scan 2, which is the highest quality that can preserve the details of a 4:4:4 footage. Update: Just tried this with my Galaxy Note 3 which shoots 4K 4:2:0 8-bit at 50Mbps AVC. Looks a million times better than native 1080p. I also tried dropping the same 4K file into After Effects CC working in 16bpc. Created a sequence and exported to DNx 350X or 440X 4:4:4 10-bit...Looks different than Cineform (CFHD) workflow above. Not sure which is better to be honest. HurtinMinorKey, oardao and KarimNassar 3 Link to comment Share on other sites More sharing options...
oardao Posted February 17, 2014 Share Posted February 17, 2014 Thanks Michael Ma, i'll try it. Link to comment Share on other sites More sharing options...
Appleidiot Posted February 17, 2014 Share Posted February 17, 2014 I really like the Cineform codec, however, it can only be exported via compressor for those using FCPX. Well, I should say I'm assuming that as I'm not running 10.1.1, but I highly doubt that changed. Link to comment Share on other sites More sharing options...
Tim Naylor Posted February 17, 2014 Share Posted February 17, 2014 Thanks Andrew for laying this out. For those who doubt it theoretically, this is already done in camera by C300 and Alexa. C300 takes 8 bit 4k image, down samples to 10 bit 422 1080p and then re-packs it to 8 bit (to fit in 50mb). Alexa takes app. 3k image down samples to 422 10bit 1080p then up samples to 444 pro rez. But what I'd really like to know is what is the exact recommended workflow. Is it 4k 100mb to After FX RGB 10bit then to 1080p? Help. Link to comment Share on other sites More sharing options...
Administrators Andrew Reid Posted February 18, 2014 Author Administrators Share Posted February 18, 2014 I would also like to know the exact recommended workflow. This is new territory. Link to comment Share on other sites More sharing options...
jcs Posted February 18, 2014 Share Posted February 18, 2014 Any workflow which can downsample 4K to 1080p at 10-bits or more should be able to produce 9-bit 444 RGB. It won't be full 10-bit as the chroma was only 8-bit, however the luma mixed in with chroma when converting to RGB will be 10-bit, so really more like 9-bit at the end of the day. Ernesto Mantaras 1 Link to comment Share on other sites More sharing options...
hmcindie Posted February 18, 2014 Share Posted February 18, 2014 Minor nit picking but just see this "4:2:0 as 4:4:4 major discovery" as a bit off, to suggest 4:2:0 intetpolated and averaged 4k 4:2:0 to 1080p is going to give equivilant to 4:4:4 1080p shot in camera. It's actually gonna give more as all the HD cams are 4:2:2 max anyway. And with Blackmagic 2.5k res, you can't even get 1080 4:4:4, because the sensor doesn't have enough luma after debayering to fill HD. Link to comment Share on other sites More sharing options...
hmcindie Posted February 18, 2014 Share Posted February 18, 2014 But what I'd really like to know is what is the exact recommended workflow. Is it 4k 100mb to After FX RGB 10bit then to 1080p? Help. You need to work in software that's in 16-bit or 32-bit float. Just downconverting to 8bit will not do anything. The trick happens when the 8bit image is interpolated inside a 16/32-bit container. I'd say After Effects can do that (or any modern compositing software) if used in 16-bit mode. Editing software is more tricky. Maybe Premiere could do it if the enable maximum bit depth option is clicked on but not sure unless tested. Link to comment Share on other sites More sharing options...
jcs Posted February 18, 2014 Share Posted February 18, 2014 Premiere should work- it converts everyting to 32-bit float (and GPU accel when avail- so will be very fast). Link to comment Share on other sites More sharing options...
BobbyMurcerFan Posted February 18, 2014 Share Posted February 18, 2014 I have to believe that David is talking about "in practice," b/c the math is not perfect. Here's a simple example that illustrates what I'm saying: Have an image with a perfectly uniform shade of grey that falls between two 8-bit values but closer to the higher value. Lets say between 100 and 101 but closer to 101. Well it's going to be encoded as 101. But let's say you take the same perfectly uniform shade of grey and sample it with 10-bit precision. So it falls between 400 and 404, but lines up perfectly with 403. There is no way that four 8-bit values of 101 are going to mathematically sum to 403. They are going to sum to 404. And 404 <> 403. While I'm sure the downrezing helps the bit depth considerably, the math is not perfectly reversible. Link to comment Share on other sites More sharing options...
HurtinMinorKey Posted February 18, 2014 Share Posted February 18, 2014 I have to believe that David is talking about "in practice," b/c the math is not perfect. Here's a simple example that illustrates what I'm saying: Have an image with a perfectly uniform shade of grey that falls between two 8-bit values but closer to the higher value. Lets say between 100 and 101 but closer to 101. Well it's going to be encoded as 101. But let's say you take the same perfectly uniform shade of grey and sample it with 10-bit precision. So it falls between 400 and 404, but lines up perfectly with 403. There is no way that four 8-bit values of 101 are going to mathematically sum to 403. They are going to sum to 404. And 404 <> 403. While I'm sure the downrezing helps the bit depth considerably, the math is not perfectly reversible. We've said this in the thread a bunch now. I am sure this is true without error diffusion. But with error diffusion I think there might be a way to store the information in 8 bit. Link to comment Share on other sites More sharing options...
jcs Posted February 18, 2014 Share Posted February 18, 2014 Photons captured by the sensor have a random component (noise)- 4 sensor samples added together gets us 2 more bits of signal with an effective low pass filter (similar to C300's dual green sampling). Keep in mind the random sampling component when thinking about specific cases. Link to comment Share on other sites More sharing options...
svendson Posted February 18, 2014 Share Posted February 18, 2014 I have to believe that David is talking about "in practice," b/c the math is not perfect. Here's a simple example that illustrates what I'm saying: Have an image with a perfectly uniform shade of grey that falls between two 8-bit values but closer to the higher value. Lets say between 100 and 101 but closer to 101. Well it's going to be encoded as 101. But let's say you take the same perfectly uniform shade of grey and sample it with 10-bit precision. So it falls between 400 and 404, but lines up perfectly with 403. There is no way that four 8-bit values of 101 are going to mathematically sum to 403. They are going to sum to 404. And 404 <> 403. While I'm sure the downrezing helps the bit depth considerably, the math is not perfectly reversible. A rounding error of slightly less than half a least significant bit on a uniform scene, as per your example, is not a significant or noticeable issue. To see the advantage of four 8 bit samples -> One 10 bit you need something like a very gentle gradient that will generate noticeable banding. Then the four samples will, when averaged, allow 3 extra values between 100 and 101 - 100.25, 100.5, and 100.75, depending on how many of the 4 samples are 100 and how many are 101. Now of course, they won't actually take a decimal value as we are now working in a space with 10 bit resolution, not 8 bit and so the actual integer value will be times 4 and you can in fact resolve anywhere integer value between 400 and 404. This is in fact perfect math. But, as you point out if the absolute value of a uniform scene is subjected to a quantization error due to 8 bit resolution, the correct absolute value cannot be correctly reconstructed. Wikipedia has some nice info on over sampling and how you can trade back and forth between sampling rate and bit depth. Lots of info in this with regard to audio recording as well, if my explanation is not adequate Link to comment Share on other sites More sharing options...
HurtinMinorKey Posted February 18, 2014 Share Posted February 18, 2014 So let's start with your four 8-bit pixels example and compare it to a single 10 bit observation. Imagine our stored 8-bit values are all max readings: (256) (256) (256) (256) Now suppose we want to approximate a single, native 10-bit observation in the middle of all four of them ("X"). (256) (256) (X) (256) (256) What 10-bit value do we assign? 1024 seems logical, right? But what if the true value of the native 10-bit observation is 1023? (because 1023 would be mapped to 256 in all of the 8-bit observations) Then we have made a mistake in our mapping and overestimated the value. Similarly, we cannot be sure about assigning any number less than 1024, because 1024 might be the true value of the native 10-bit observation! In this case, used an example where the dynamic range is truncated in the 8 bit from above, but it doesn't matter where this lack of precision exists. All that being said, error diffusion complicates the matter. It may be possible to diffuse the errors (the remainders when going from native bit depth to 8 bit) It complicates the matter beyond a simple proof. Link to comment Share on other sites More sharing options...
Michael Ma Posted February 18, 2014 Share Posted February 18, 2014 Been playing with this all day. I want to share another way to explain information which may have already been posted. 4:2:0 to 4:4:4...it works, I tested it, it looks great when compared to other 4:4:4 vs 4:2:0 examples on the web. As for 8-bit to 10-bit, and looking to gain any dynamic range from that by combining 4 x 8-bit data, it is not possible. It's not that we're collecting actual light per pixel and combining light from 4 sources into 1. We can't add these together as if we're adding light photons. We only have the readings of 0-255 (8-bit) for each subpixel (R,G,B ) for each pixel for one ISO sensitivity. It knows no information outside of that for shadow or highlight recovery out of those bounds. Having this near identical data repeated 4 times won't help expand the dynamic range with any kind of formula or workflow. You can't extrapolate detail from the value of 0. Same thing for blacks. When all the RGB values goes to 255, you can only extrapolate shades of gray and any color is lost. All we can do is just average 4 pixels for each 1 pixel for better color accuracy. If Panasonic had made the GH4 so that you can flip a switch and each 4 sensor groupings collected data at 4 different sensitivities, then we'd have the data to work with, but then 4:2:0 to 4:4:4 conversion won't be as effective or effective at all because we're purposely overexposing or underexposing sensors for some pixels that would normally be collecting useful information. With that said, you still should convert to 4:4:4 10-bit (not 4:4:4 8-bit if that's even an option). That would give the color grading software more room to work with. I learned a lot from this thread. Now I want a 4:4:4 12-bit camera more than ever. :) Maybe in 1-2 years we'll have it on the GH5 or the GH6. Link to comment Share on other sites More sharing options...
dafreaking Posted February 18, 2014 Share Posted February 18, 2014 Does the end user really care about the maths involved or are the results more important? Link to comment Share on other sites More sharing options...
Michael1 Posted February 18, 2014 Share Posted February 18, 2014 I can see getting from 4K 4:2:0 to 1080 4:4:4, but I don't see how it can get from 8 bit to 10 bit without interpolation, which will introduce noise. Michael Link to comment Share on other sites More sharing options...
sam Posted February 18, 2014 Share Posted February 18, 2014 You have a box of 1024 differnt color crayons and 4 boxes of 256 color crayons. Combine all four boxes of 256 into a new box of 1024. Which one has more colors? oardao 1 Link to comment Share on other sites More sharing options...
