scotchtape Posted October 20, 2021 Share Posted October 20, 2021 10 hours ago, Tijmen Brouwers said: @scotchtape I would love to know how you made your own connector. Can't find the connector you recommendomend anywhere in Europe. How do you go from the JST connection with only two connection points (red and black) to the one with 3 points? (red, black and yellow). Do you need to combine two of them together on the end with the two connections? Or do you only use the black and red one and leave the yellow one unused? Can't really see how you did that in the video. Think I could make one like yours with these two components. Only need to know how to connect them properly. https://www.allekabels.nl/interne-voedingskabel/7032/1343759/ventilator-verlengkabel.html?gclid=CjwKCAjw_L6LBhBbEiwA4c46ui8RxYZ0tnrZS-Jzqq7sJcey7Qdowgf5KzHCS6Anlm4C_V3Y0TXtIRoCuCkQAvD_BwE https://www.hobbyelectronica.nl/product/jst-2-5-connector-150mm-2p/ Yep that is exactly how I did it. You only need the red/black - the yellow is for RPM signal and you don't need it. I'm not sure if the JST is the exact right one as there are different sizes but there's a good chance it is. Those cables are basically how I did it (except I have the JST connectors so I just crimped that onto the 3pin fan cable). If you get those cables you would just connect the black and red wires (obviously black to black and red to red) and you are good to go. These lights are great, just wish the color temperature was a bit higher. I am going to sell my 300D II 😄 I also just got an Aputure 200X for my main light because gelling is so annoying, but these will be here for max power! Got 4x to battle the sun! Link to comment Share on other sites More sharing options...
Tijmen Brouwers Posted October 21, 2021 Share Posted October 21, 2021 @scotchtape dude you are a hero! Thanks so much for the video and this extra explanation. One last question if you don't mind. In one off your comments you said that running the fan at 900 rpm would probably be a nice sweet spot between increased temp and noise. I'm considering buying this fan: https://noctua.at/en/nf-p12-redux-900 Would that give enough cooling power you think? Rotational speed (+/- 10%) 900 RPM Airflow 63,4 m³/h Acoustical noise 12,6 dB(A) Static pressure 1,21 mm H₂O Thanks again! Link to comment Share on other sites More sharing options...
scotchtape Posted October 21, 2021 Share Posted October 21, 2021 I suggest getting the same fan I used, it's easier to slow a fan down than speed it up (in this context). It's not that much louder, especially for location work it's a non issue unless you're in a quiet house (and even then it's very acceptable). If you want to slow it down just get a bunch of fan slow down cables or one with a pot. Tijmen Brouwers 1 Link to comment Share on other sites More sharing options...
