ML Raw changes Lens Selection?
jasonmillard81
Greetings,
I am looking to purchase a good zoom for my 5d Mk 3.  I am between 24-70 and 70-200 both from Tamron.  It is for general documentary work (interviews, scenes, etc.) as well as for travel/friends/personal use.
With the 3x crop mode on ML Raw is it necessary to get the 70-200 for my purposes if I can get great range from 24-70 using 3x crop mode?
I currently own a nifty 50 and a Samyang 85 1.4 lens.
Thanks!
3x zoom gives you the reach but it also changes the depth of field. The 24-70mm f/2.8 will virtually turn into a ~75-210 f/8.4. So you won't get the small DOF that is possible with the 70-200mm 2.8. If that's no problem, just go for the 24-70mm and decide from there if the crop mode works for you I'd say.
Guest Ebrahim Saadawi
Yes the 24-105mm L is an incredible workhorse of a lens, it's much more useful to me than the 24-70 as it has image stabilization. It can be the perfect general shooter, and when in low light you have your 50/80 fast primes.
