KnightsFan Posted December 24, 2020 Share Posted December 24, 2020 5 hours ago, IronFilm said: You only need the one (per camera), because any professional (and even semi-professional these days) field recorder will hold timecode accurately by itself. Right, jam syncing. $200 to "plug in and forget" would be sort of reasonable to me, but $200 to also need to jam sync and remember to do that every time you shut down, and/or make sure devices are in free run, etc. leaves a lot of room for human error. Especially since it's such a simple problem to solve. So yeah I consider them to be way overpriced for the function they perform. Link to comment Share on other sites More sharing options...
IronFilm Posted December 24, 2020 Share Posted December 24, 2020 No, there's nothing complex here. You just attach to the X-T3 (once TC box & field recorder are synced together), check you haven't completely screwed up levels, then you're done. Nothing more needs to be done while you're shooting, you don't have to do anything else when you're turning on/off or doing battery swaps or whatever. josdr 1 Link to comment Share on other sites More sharing options...
josdr Posted December 25, 2020 Author Share Posted December 25, 2020 8 hours ago, IronFilm said: No, there's nothing complex here. You just attach to the X-T3 (once TC box & field recorder are synced together), check you haven't completely screwed up levels, then you're done. Nothing more needs to be done while you're shooting, you don't have to do anything else when you're turning on/off or doing battery swaps or whatever. Thank you for your help and your advice . Merry Christmas!! Link to comment Share on other sites More sharing options...
