Sony SRW-9000PL(Sony F35 sensor) kit ready to shoot
dhessel
SONY SRW-9000PL with all three optional upgrade boards (HKSR-9001 / 9002 / 9003) and PL lens mount transforms this camera into an ENG-style Sony F35. This camera has the exact same sensor and image as the F35, only better portability as the interface box, shoulder mount, and HDCAM-SR recorder are all built into the body on the SRW-9000PL.
- Super 35mm-sized CCD (Global shutter)
- PL Lens Mount
- 1080p
- 24p, 25p, 29.97p, 50p
- 10 bit 4:4:4
- S-Gamut Color Space
- ISO 800 Mode Gamma Curve
- HD-SDI Output
Includes:
- HKSR-9001 (HD-SDI Expansion Board)
- HKSR-9002 (Picture Cache Expansion Board)
- HKSR-9003 (RGB 4:4:4 Processor Expansion
- Sony SRK-CP1 (same control panel as is found on the Sony F65)
Sony SRW 9000 PL with all option boards and AC power supply
Sony HDVF C30WR
2 x Sony SRW-1/SRPC-1 (one set is fully functional the other set has a SRPC has a nvram 0103 error, it still works for playback and capture the only issue I have noticed is that remote deck control from a PC comes and goes about once a second)
Flight Case for 9000PL
Flight Case for SRW-1
Kona 3g sdi capture card with breakout cable
13 x 33 minute HDCAM-SR tapes
You can capture directly from the camera but I choose to use the SRW-1 to distribute use of the hdcam decks. The camera does have a 3G sdi out and can send record trigger signals without tape in the camera, I have never tested with an external recorder though.
https://imgur.com/a/3xxTKmr
Price: $3600 OBO
