Ryan Plunkett Posted January 22, 2021 Share Posted January 22, 2021 Greetings all! Looking to shoot my new camera in the flattest profile possible and stumbled across ZLog. Every article I’ve seen mentions the Z6 and Z7, but no mentions of the new kid on the block. Anyone tried this? Quote Link to comment Share on other sites More sharing options...
newfoundmass Posted January 23, 2021 Share Posted January 23, 2021 Yeah, unless you absolutely need one I don't understand using an external recorder. It just adds more bulk / effort. Mark Romero 2 1 Quote Link to comment Share on other sites More sharing options...
Administrators Andrew Reid Posted January 24, 2021 Administrators Share Posted January 24, 2021 17 hours ago, Evgeniy said: Desaturating and lowering contrast on existing profile doesn't make it "Log". You are ill informed my friend. That isn't what it is doing. It also reduces in-camera sharpening to below what is possible with the built in profiles. It is an external profile loaded onto the camera. Quote Link to comment Share on other sites More sharing options...
TomTheDP Posted January 24, 2021 Share Posted January 24, 2021 18 hours ago, Evgeniy said: You can apply REC709 LUTs to neutral profile, the results will be cleaner. Desaturating and lowering contrast on existing profile doesn't make it "Log". Yeah Nikon allows you to load custom profiles into the camera. It's actually a really cool feature. It's not like lowering contrast or saturation on existing profiles. Quote Link to comment Share on other sites More sharing options...
Wren Posted February 25, 2021 Share Posted February 25, 2021 Z-log is amazing. Although I am having troubles with it on both my Nikon Z6ii and Z7ii in 4K50fps mode. Seems every second frame is corrupted. Quote Link to comment Share on other sites More sharing options...
Hannes Posted March 12, 2021 Share Posted March 12, 2021 On 2/25/2021 at 10:07 AM, Wren said: Z-log is amazing. Although I am having troubles with it on both my Nikon Z6ii and Z7ii in 4K50fps mode. Seems every second frame is corrupted. Same here. It also happens to other custom picture profiles that I loaded onto the camera. Footage is rendered unusable unfortunately then.. 😞 Would be great to get an update. Though I can't imagine how to update the profiles.. Maybe it's a firmware problem with custom grad curves in high framerate modes in 4K? Only seems to happen in 4K. Andrew, any guesses? Quote Link to comment Share on other sites More sharing options...
Administrators Andrew Reid Posted March 12, 2021 Administrators Share Posted March 12, 2021 On 3/7/2021 at 11:45 PM, Wren said: Hi Andrew, Do you plan on updating Z-log for the Z6ii and Z7ii? Currently Z-log works on some frame rate setting but not others. Yeah there's some firmware problem. Working as expected 4K/24p but it seems Nikon has a problem going on in 4K/60p with custom picture profiles. I'll make them aware of it. Meanwhile, going to try a few workarounds. Quote Link to comment Share on other sites More sharing options...
