kado Posted March 6, 2014 Share Posted March 6, 2014 I know the usual step to cut down light is to add ND filters inside a mattebox. but would adding an ND filter between the taking lens and and anamorphic lens, (mine is an iscorama 54) be a big no no? im looking a the Hoya ProND filters but the biggest size available is 82mm. thanks, Link to comment Share on other sites More sharing options...
Stuart Hooper Posted March 6, 2014 Share Posted March 6, 2014 I've been doing it behind an LA7200 no problem, only that I start vin getting a few millimetres sooner on the wide end. Link to comment Share on other sites More sharing options...
Lucian Posted March 6, 2014 Share Posted March 6, 2014 I know the usual step to cut down light is to add ND filters inside a mattebox. but would adding an ND filter between the taking lens and and anamorphic lens, (mine is an iscorama 54) be a big no no? im looking a the Hoya ProND filters but the biggest size available is 82mm. thanks, You generally want to mount the two optics as close together as possible. Small nd's are cheap, I'd buy one used and do a quality test side by side. Link to comment Share on other sites More sharing options...
kado Posted March 6, 2014 Author Share Posted March 6, 2014 I've been doing it behind an LA7200 no problem, only that I start vin getting a few millimetres sooner on the wide end. sweet good to know. You generally want to mount the two optics as close together as possible. Small nd's are cheap, I'd buy one used and do a quality test side by side. ah yes, i forgot about keeping them as close as possible. i'll definitely have to do some testing. thank you Link to comment Share on other sites More sharing options...
