scotchtape Posted March 9, 2021 Share Posted March 9, 2021 We've come full circle boys (and girls). Is it just me? I'm noticing some pulsing backgrounds as the eye AF works it's "magic". Sony magic so strong I got Panasonic footage. Ok it wasn't that bad, it 95% was fine, subjects were always in focus but the focus pulse combined with focus breathing is really annoying if you notice it. Maybe because I noticed it in some of the "bad" shots I started noticing it everywhere! It's a very quick 1 or 2 frame pulse every once in a while, blink and you miss it. I used the Zeiss 50mm F1.4 and 85mm F1.8 with a typical 2 camera set up, maybe a bit closer than usual. I noticed the same thing in both cams. I also noticed that weirdly - in one shot I got what I can only describe as a lens correction pulse - for one frame as the focus shifted, the vignette correction seemed to flick off for one frame. Very weird and annoying on the 50mm F1.4. Firmware was PRE V2.0 Paid job so no examples, sorry. Thankfully it shouldn't affect the final product. Probably the best solution is to go easy on the Toneh and shoot F2 50mm and maybe F2.8 or more for the 85mm+ for now. If you think about it, if focus is 100% locked to the person's eye, then at very shallow DOF this issue is going to crop up as most people are not robots and move back and forth. BUT, I've just looked back at my A7III footage and don't notice this issue, so I do think some tweaking can be done for the A7SIII... Quote Link to comment Share on other sites More sharing options...
MrSMW Posted March 9, 2021 Share Posted March 9, 2021 Can focus be 100% using AF? I'm assuming you are using AF or any kind of pulsing cannot exist? But otherwise yes, your Sony is simply trying to be the Panasonic that it isn't 🤣 Quote Link to comment Share on other sites More sharing options...
Mark Romero 2 Posted March 9, 2021 Share Posted March 9, 2021 Thank you for the real-world report, @scotchtape So I guess it wasn't possible to have the on-screen talent constantly jumping in and out of the frame the way all those wonderful AF testers on youtube do? That seems to be where Sony excels at autofocus. The focus breathing is one of the things that gets me less excited about Sony AF, and the lack of focus breathing in Panasonic lenses has me happier about owing a couple of Lumix bodies. I know I won't be able to do the super shallow DOF thing (but those lenses are pretty much out of my price range anyway). Some situations the AF is good enough on the S series of cameras. Sometimes you just have to go manual I guess. And yes, I have experienced the thrill of having my S1 or S5 focus drift off in to the heavens never knowing where the focus point will land again. Quote Link to comment Share on other sites More sharing options...
scotchtape Posted March 9, 2021 Author Share Posted March 9, 2021 Just did more testing, A7SIII definitely needs some tweaks. Just filmed my partner while they were on zoom calls, the A7SIII is quite sensitive which has the unfortunate effect of wobbling and pulsing the background when the subject nods (or is, you know, human). The A7III is much less sensitive so it's actually better for interviews. I manually set the eye focus and speeds to 1 for the A7SIII and left the A7III in the default speeds. Again 50mm F1.4 and 85mm F1.8. Hopefully more people pipe up to Sony about this and we can get another mode in there, as it stands the A7SIII isn't great in this application. I can't believe no one else has noticed this?! Quote Link to comment Share on other sites More sharing options...
Trankilstef Posted March 9, 2021 Share Posted March 9, 2021 1 hour ago, scotchtape said: Just did more testing, A7SIII definitely needs some tweaks. Just filmed my partner while they were on zoom calls, the A7SIII is quite sensitive which has the unfortunate effect of wobbling and pulsing the background when the subject nods (or is, you know, human). The A7III is much less sensitive so it's actually better for interviews. I manually set the eye focus and speeds to 1 for the A7SIII and left the A7III in the default speeds. Again 50mm F1.4 and 85mm F1.8. Hopefully more people pipe up to Sony about this and we can get another mode in there, as it stands the A7SIII isn't great in this application. I can't believe no one else has noticed this?! I noticed very minor pulsing sometimes but not disturbing at all even for paid jobs. It's nowhere near as what my Panasonic S1H and S5 did when it comes to pulsing. Those were great cameras but yeah I felt the need for AF in a lot of shootings. Quote Link to comment Share on other sites More sharing options...
scotchtape Posted March 9, 2021 Author Share Posted March 9, 2021 Might not be as bad as Panny, but the fact that it's there whereas it's practically unnoticeable on the A7III means it could be improved. On my shots they were very distracting 😞 Quote Link to comment Share on other sites More sharing options...
scotchtape Posted March 9, 2021 Author Share Posted March 9, 2021 And now with video - blurred faces and sound distorted. Full screen for maximum pulsing...: Quote Link to comment Share on other sites More sharing options...
Trek of Joy Posted March 10, 2021 Share Posted March 10, 2021 I haven't noticed any pulsing like that, but I'm usually not shooting anything faster than f/2.8 or 4 with talking heads because they move around so much and the camera really sticks to the eye or face, if your lens breathes at all it will show in the footage - and most lenses do shift at least a little bit. Maybe slow down the AF a bit more so changes aren't so abrupt. Fuji did wonky things with shading too, the solution was turning off lens corrections. Off to try this with my 24GM and 35/85 1.8's to see if I get the same thing. Chris Quote Link to comment Share on other sites More sharing options...
Thpriest Posted March 10, 2021 Share Posted March 10, 2021 I've seen various reviews with people talking to the camera going on about how great the af is on the A7siii whilst the background pulses. Maybe better using face af? Quote Link to comment Share on other sites More sharing options...
John Matthews Posted March 10, 2021 Share Posted March 10, 2021 Just an idea... why not use manual focus and let the person just go slightly in and out of focus? ...much less distracting than electronic pulsing. Mark Romero 2 1 Quote Link to comment Share on other sites More sharing options...
Video Hummus Posted March 11, 2021 Share Posted March 11, 2021 On 3/10/2021 at 8:40 AM, John Matthews said: Just an idea... why not use manual focus and let the person just go slightly in and out of focus? ...much less distracting than electronic pulsing. Blasphemer! John Matthews 1 Quote Link to comment Share on other sites More sharing options...
Mark Romero 2 Posted March 12, 2021 Share Posted March 12, 2021 So there (to me) are two issues; The pulsing (as @scotchtape brings up and demonstrates), which to me isn't quite as bothersome as the focus breathing, which @Trek of Joy brings up. Of the two, the focus breathing when using a wide aperture with a more animated on-screen talent is more annoying. As for the pulsing, even in the magnified examples above, I don't really notice it that much (yes, even zoomed in and with a big red arrow pointing at it, I guess I just didn't notice that much). Quote Link to comment Share on other sites More sharing options...
MrSMW Posted March 12, 2021 Share Posted March 12, 2021 Focus breathing is a lens issue not a sensor one. Quote Link to comment Share on other sites More sharing options...
TomTheDP Posted March 12, 2021 Share Posted March 12, 2021 2 hours ago, MrSMW said: Focus breathing is a lens issue not a sensor one. If there aren't lenses available for Emount that don't focus breath it could be problematic though. But yeah you are right. On 3/10/2021 at 8:40 AM, John Matthews said: Just an idea... why not use manual focus and let the person just go slightly in and out of focus? ...much less distracting than electronic pulsing. I have never had an issue with manual focus for say interviews. If you are really crazy with your DOF wants on the close up shot though it can be problematic. I usually stop down quite a bit for close ups. Even at f5.6 you get a nice background blur on most close ups. John Matthews 1 Quote Link to comment Share on other sites More sharing options...
scotchtape Posted March 12, 2021 Author Share Posted March 12, 2021 I'm just saying that I've used the same setup with my a7siii with no issues, so the fact that a7siii is showing this behaviour is an issue. I get that super shallow dof is difficult, but the a7siii does it fine so surely sony could add another mode to make things better. Secondly, I have worse examples but I forgot to put them in as I'm currently working on several projects so you can imagine that those are the priority. Maybe I will make another video in a few weeks. Quote Link to comment Share on other sites More sharing options...
TomTheDP Posted March 12, 2021 Share Posted March 12, 2021 2 hours ago, scotchtape said: I'm just saying that I've used the same setup with my a7siii with no issues, so the fact that a7siii is showing this behaviour is an issue. I get that super shallow dof is difficult, but the a7siii does it fine so surely sony could add another mode to make things better. Secondly, I have worse examples but I forgot to put them in as I'm currently working on several projects so you can imagine that those are the priority. Maybe I will make another video in a few weeks. Have you messed with settings to see if that helps? Quote Link to comment Share on other sites More sharing options...
