Magic Lantern for 5D Mark III 1.2.3
Ergo Zjeci
From Magic lantern forum a1ex:
It's out!
Not alpha, not beta, nor zeta, just a bleeding edge that happens to work for me. It might work for you or it might not.
(note that my standards are fairly high, so what I call bleeding edge, others may call semi-stable or
whatever)
- bootflag issue solved!
- installation is really easy (simply unzip the files on the card, update firmware and you are ready to go)
- uninstallation is equally easy (update firmware and follow the instructions)
Installation:
1) Format the card from the camera.
2) Make sure you are running Canon firmware 1.2.3.
3) Copy ML files on the card and run Firmware Update.
Uninstallation:
1) Run Firmware Update from your ML card.
2) Follow the instructions.
What's hot:
- bootflag issue solved! (p.s. some bloggers got it wrong, you still enable it in the camera, but you can disable it by uninstalling)
- EosCard is now optional
- ML restores itself after formatting the card (man, that komputerbay card is fast!)
- you may install on any card combination you may think of.
What's not:
- unlike most firmware updates which fix minor things, this one changed a LOT, especially on the display side (for example, LiveView is now quad-buffered and most of the display registers were changed).
- watch out for corrupted frames (from my limited testing, I'm not fully convinced the issue is fully resolved on 1.2.3 => for serious video use, please consider staying on 1.1.3)
- fast zebras not working, but can be fixed
- no full-screen magic zoom (I never used it anyway, but was nice)
- no brightness/contrast/saturation adjutments (registers changed)
- HDMI issues (possibly worse than 113, didn't try yet)
- no documentation (yet).
For photo use (raw overlays, ETTR and so on) it should be just fine (that's how I use it).
Source code:
- the 5D3-123 branch in the main repository.
- feel free to merge it locally with unified or experimental branches to get a sneak peek for the future updates.
- I'll merge it to unified when I'll be confident it's at least as good as the 1.1.3 branch (based on your feedback).
Thanks to:
- chris_overseas for initial porting and testing
- horshack for advice about safely toggling the bootflag
- Audionut for early builds and support in the early porting thread
- marekk, pompeiisneaks, jpaana, rufustfirefly, sinubis and others for early feedback and small fixes
- mk11174 for getting the 700D port in sync in this one
- everyone else who volunteeres their time to make a great community project.
Final notes:
- check nightly builds often and stay up to date! I'll do my best to make sure there are no critical issues in the nightly builds.
- there are quirks and bugs waiting to be fixed (please report them properly, with details on how to reproduce).
- grab the ARM toolchain and start hacking! (start with something easy or just tweak/fix whatever you find interesting).
- If anything goes wrong, we don't pay for repairs. Use Magic Lantern at your own risk!
coming soon: a lot of stuff, including a real sensor upgrade, a C compiler that runs on your camera and other geeky stuff like this
http://www.magiclantern.fm/forum/index.php?topic=11017.msg106777#msg106777
