subsequent Posted April 29, 2021 Share Posted April 29, 2021 I sold all my equipment some time ago as i tried to go with a more mobile approach but i now regret this decision. I only do familiy videos and private stuff so no paid gigs. I've owned diffrent cameras from panasonic in the past (gh2,gh3,lx100,gx85,g9 and so on) but i never been totally satisfied with the color from these except the gh2 with @Andrew Reid Pro Color hack back in the days. What i'm looking for is and easy to pickup run and gun camera that i dont have to color grade in post. Nice in camera colors. Preferably IBIS (as i do most handheld) Easy post workflow (so no raw i guess?) Nice allround lens to pair it with. Decent AF I know there is alot of talent on this website so I would really appreciate som good advice from you guys! Link to comment Share on other sites More sharing options...
IronFilm Posted April 29, 2021 Share Posted April 29, 2021 Fujifilm X-T4 + Fujifilm XF 16-80mm F4 R OIS WR (perhaps pair it with a couple of primes too, if you've got the budget/time/space) Alternatively instead of the 16-80mm F4, you could consider the more expensive Fuji 16-55mm f/2.8 (you'd gain speed, but lose reach. Or the Fuji XF 18-55mm f/2.8-4, which is the cheapest of the three but a different mix of compromises instead). Panasonic S5, and Nikon Z6 are worth a look too. Even though you have already tried the Panasonic G9, it's got big firmware update in the past, and might be worth a second look again. josdr 1 Link to comment Share on other sites More sharing options...
kye Posted April 29, 2021 Share Posted April 29, 2021 I second the Fujifilm cameras, they seem to put the most effort into their built-in colour profiles, although for home use most cameras these days create modern video-looking images so if that suits your tastes then you could get away with using the built-in profiles. Link to comment Share on other sites More sharing options...
Marcio Kabke Pinheiro Posted April 29, 2021 Share Posted April 29, 2021 If you don't need 10-bit files, take a look at the X-S10 too. Coming from the m43 world, and amateur here too. Liking it a lot, much better than the midranges m43s (GX95, GX9, E-M10 MK III). Pros (albeit did not have much time to proper testing): - Very good colors; - Robust codec (8-bit 4k24 and 4kDCI with 200mbps data rate - the midrange m43 only goes to 100mbps); - Good AF in video - not Sony or Canon levels, but miles ahead from the CDAFs m43 (never tested a E-M1 II/III or E-M5 MK III). Filming my little daughter and the AF is almost flawless (thing that was impossible with the 3 m43 cameras that I told); - Punch-in focus DURING filming; - Focus joystick; - Lenses - the 18-55 f/2.8-4 is a gem. The little f2 primes are good, with VERY fast AF too. Cons: - IBIS is good, better than Sony, but the m43 ones are better; - Menus are kind of messy, almost Olympus levels; - When you change ISO, all the display indicators disapear - hence, you can't change ISO while looking at the histogram (or I did not find how); - No AF tracking in video; - Some problems with Face/Eye AF in video - if 2 faces are visible in the focus area, the AF system will jump between them; - Would like a little bigger LCD / EVF indicators (you have the option to make them become bigger, but it goes to the another extreme, too big and with few information); - Would like to have the dual electronic level indicators always on - normally you only have the horizon level indicator, you could assign a button to toggle to a dual level indicator, but it disappear after touching any button. In general, much better than the middle range m43 cameras . But I second the opinion to have a second look on the G9. IronFilm 1 Link to comment Share on other sites More sharing options...
ade towell Posted April 29, 2021 Share Posted April 29, 2021 I've got Fuji X-t4 with spare battery, 16-80mm f4 plus 35mm f2 and Smallrig cage with Hdmi clamp I am thinking of selling for £1750 if you're interested. Was f going to put it up in the marketplace. Am in the UK though... Link to comment Share on other sites More sharing options...
subsequent Posted May 10, 2021 Author Share Posted May 10, 2021 Thanks for alle suggestions here! I dont think i NEED 10 bit codec. I mostly just want an easy workflow without the need to colorgrade in post. I will look in to some of these cameras. thanks. Link to comment Share on other sites More sharing options...
