tomekk Posted April 6, 2014 Share Posted April 6, 2014 Can I use AF when I put my canon glass on it? Link to comment Share on other sites More sharing options...
wolf33d Posted April 6, 2014 Share Posted April 6, 2014 Actually price 1699 is not official apparently, so let's wait a bit before being to exited Zach Ashcraft 1 Link to comment Share on other sites More sharing options...
richg101 Posted April 6, 2014 Share Posted April 6, 2014 s-log.. great that they included this Link to comment Share on other sites More sharing options...
itimjim Posted April 6, 2014 Share Posted April 6, 2014 According to Den Lenie, it does do 10-bit 4K:"The sensor reads out fully at 4k and via micro HDMI you can record 10 bit uncompressed to a 4k recorder. We used the Blackmagic Design Ultra studio Pro that records Ultra HD." http://www.fstopacademy.com/blog/sony-alpha-7s-first-hands-on-shooting-review/ Spec sheet says 8-bit. It's quite easy to feed 8-bit acquisition into 10-bit ProRes, which is probably the case here. Link to comment Share on other sites More sharing options...
Administrators Andrew Reid Posted April 6, 2014 Author Administrators Share Posted April 6, 2014 Spec sheet says 8-bit. It's quite easy to feed 8-bit acquisition into 10-bit ProRes, which is probably the case here. Den or the Sony spec sheet? Who is right? 3840 × 2160(30p/24p) / 1920 × 1080(60p/24p) / 1920 × 1080(60i),YCbCr 4:2:2 8bit/ RGB 8bit Link to comment Share on other sites More sharing options...
Derek Weston Posted April 6, 2014 Share Posted April 6, 2014 Arrrghh. Sad pirate. Really wish this was available A) now and B ) had a really good external recorder available. (also now) Link to comment Share on other sites More sharing options...
itimjim Posted April 6, 2014 Share Posted April 6, 2014 If he's using the BMD Ultra HD then I'm sure he's recording to a 422 (HQ) at 10-bit. The camera will be outputting 8-bit, I'm almost positive. Link to comment Share on other sites More sharing options...
thementalist Posted April 6, 2014 Share Posted April 6, 2014 Den or the Sony spec sheet? Who is right? 3840 × 2160(30p/24p) / 1920 × 1080(60p/24p) / 1920 × 1080(60i),YCbCr 4:2:2 8bit/ RGB 8bit Sony Specs here: http://www.sony.net/Products/di/en-us/products/vq5f/index.html It's a 4:2:0 sampling. That's the original Codec. Full hd. Output 4k: seems to be uncompressed and 4:2:2 8 bit Link to comment Share on other sites More sharing options...
Administrators Andrew Reid Posted April 6, 2014 Author Administrators Share Posted April 6, 2014 A good idea to separate output and recording when speaking of HDMI and the external recorders. So 8bit out to 10bit is still 8bit. Link to comment Share on other sites More sharing options...
Germy1979 Posted April 6, 2014 Share Posted April 6, 2014 Good ol' 8-bit... I should just shut up and get used to it haha. It's still pretty impressive Link to comment Share on other sites More sharing options...
itimjim Posted April 6, 2014 Share Posted April 6, 2014 I've only ever compared 8-bit 420 vs 10-bit 422, so I don't really know how much difference there is on 8-bit 422 to 10-bit. Link to comment Share on other sites More sharing options...
mike_tee_vee Posted April 6, 2014 Share Posted April 6, 2014 How does the crop mode work on the Alpha 7 series? Presumably the cameras crop to a Super 35 size when an APS-C sized E-mount lens is attached. When a full-frame lens is attached, does the camera give the option to apply the same crop factor similar to the lossless ETC teleconverter option on the GH3? Link to comment Share on other sites More sharing options...
Melbourne Park Posted April 6, 2014 Share Posted April 6, 2014 The specs do not mention PAL rates - ie its 60/30 frames (as well as 24P), but no 50/25 ... which might mean that its not a world camera ie PAL is different to NTSC. Which also means it will cost a lot more in for instance Australia (which was the case with Panasonic GH cameras, which cost much more in Australia for instance, than in the USA). The GH-4 is well priced in Australia. Not good sign for PAL users, I hope I am wrong. the specs on Sony Australia for the A6000 also only had 60 frames and 24P. No 50/25 mentioned. I hope that there is a simple switch (as Sony cameras typically had) to switch from NTSC to PAL). Sony says for 4K output, 25 is available: Non-compressed image output is now possible at 4K (QFHD: 3840 x 2160 pixels) resolution with selectable 30p (25p) and 24p frame rates. You can choose 4K or Full HD output from a menu. The 4K output capability allows recording of high-quality 4K images by a 4K-compatible recorder, as well as 4K output directly to a compatible monitor or TV. Link to comment Share on other sites More sharing options...
Michael1 Posted April 6, 2014 Share Posted April 6, 2014 The A7s is exciting in many ways, but I think the inconvenience and cost of an external recorder will be a deal breaker for many. I also wonder if using the internal recording will impose the lame recording time limits they have on their other cameras. I never understood why the onerous EU taxes have to penalize everyone else in the world. Michael Link to comment Share on other sites More sharing options...
Melbourne Park Posted April 7, 2014 Share Posted April 7, 2014 Specs indicate a bit less than an hour, so if that is not related to the battery (and a battery grip is available) then yes, the EU ridiculousness applies. Hardly surprising though .. Link to comment Share on other sites More sharing options...
itimjim Posted April 7, 2014 Share Posted April 7, 2014 The A7s is exciting in many ways, but I think the inconvenience and cost of an external recorder will be a deal breaker for many. If you're using the A7s in a pro capacity where post flexibility is key, then I don't think it's too much of an ask. Link to comment Share on other sites More sharing options...
Superka Posted April 7, 2014 Share Posted April 7, 2014 All these shots are rather "static". I hope Rolling Shutter is not too destructive. Link to comment Share on other sites More sharing options...
Nathanpaw Posted April 7, 2014 Share Posted April 7, 2014 Some more info Link to comment Share on other sites More sharing options...
Administrators Andrew Reid Posted April 7, 2014 Author Administrators Share Posted April 7, 2014 Can I use AF when I put my canon glass on it? It's currently so slow as to be of limited use but it does work. Link to comment Share on other sites More sharing options...
Germy1979 Posted April 7, 2014 Share Posted April 7, 2014 Some more info This was getting interesting until the audio fail.. :lol: Link to comment Share on other sites More sharing options...
