Sebastien Farges Posted May 4, 2021 Share Posted May 4, 2021 SECOND PART outside shots : THREE FOCALS (SLR Magic Cine lenses with anamorphic), a Seb Farges movie This is a movie shot with three different focals from SLR Magic This second part is outsides shots, the 1st part was interiors shots ( https://vimeo.com/541548262 ) The 2.25 first minutes is shot with the anamorphot, the rest is a mix of the three lenses. Anamorphot-65 1.33x anamorphic adapter on the 50mm Microprime Cine lens 50mm t1.2 Microprime Cine lens 18mm T2.8 Shot between T1.3 to T4 Everything looks sharp, the anamorphic adapter too. The Cine lenses are a real pleasure to use, they are strong and solids. Double focusing with the Anamorphot is helped because of the calibration of the lens : for example when you are at 2 feet on the taking lens, you set the Anamorphot at 2 feet. The Anamorphot is vignetting a little with the 50mm, so some of the clips are cropped at 110%. It’s weight is quite light (780Gr) and it has the new high resolution coating. Thanks to Fabienne, Mathieu, Andrew Chan from SLR Magic music VSSP « Intent » shot with Sony A7RII 4K 24P Slight CC with (sometimes) ND filter Shot in Bordeaux, Grand Piquey and La Leyre river, France Link to comment Share on other sites More sharing options...
