Voigtlander Ultron 40mm f/2 SL II EF focus issue
Henchman
  • Super Members
10 hours ago, Henchman said:
I have 2 Voigtlander Ultron 40mm f/2 SL II Lenses. One is EF one is Nikon.
For some reason the EF will not focus with my BMPCC 4k.
I've tried both a speedbooster and passive adapter.
What could the problem be?
Do you have a Nikon to EF adapter to see if that then causes the same issue with the Nikon version ?
On 5/7/2021 at 4:11 AM, BTM_Pix said:
Fixed it.
It was the helicoid not being assembled correctly.
I had to disassemble the entire lens and Re-insert the helicoid at a different start position. Took a couple of frustrating hours of trial and error. But now it's tack sharp.
And I saved myself $250
