30p to 24p pulldown removal tools?
HockeyFan12
Ffmpeg has a "pullup" filter, but removing pulldowns can be done in ffmpeg without that special filter.  Mencoder and AviSynth can also remove pulldowns.  Several NLEs and post programs have plugins that do the same.
However, the pulled-down 30fps footage is usually interlaced.  Can you post a few seconds of the 30fps footage?
31 minutes ago, HockeyFan12 said:
Even though you'd expect it to be, it's not interlaced, it's 24p footage someone put into a 1080/30p timeline from what I can tell.
Perhaps it was interlaced (60i), and then deinterlaced to 30p.
34 minutes ago, HockeyFan12 said:
Is there any fast way to do this with After Effects or Premiere or Compressor?
There are probably plug-ins/filters in those programs that might work, but I am not familiar those apps.
