thementalist Posted April 10, 2014 Share Posted April 10, 2014 Come on, you had to expect this next logical question, after the 4k to 1080p resample. I know, 1080p is not four size of 720p. So let's start theory for poor 1080p-people like me who doesn't have money to get 4k. Today, DSLR shoot in 1080p in 60 fps if we are lucky, but it's enough or could it be. To get better colours, can we use the trick to resample in 720p, in a certain way? If it's a stupid question, sorry Quote Link to comment Share on other sites More sharing options...
Julian Posted April 10, 2014 Share Posted April 10, 2014 _If_ 4K 4:2:0 really turns into 1080p 4:4:4, then 1080p 4:2:0 makes 540p 4:4:4. So downscaling to 720p would result in something between 4:2:0 and 4:4:4 (4:2:2 I guess?). I don't really see why you'd want to do so though, unless you are watching on a 720p screen it will be upscaled again to 1080p, introducing artefacts and degrading the image quality. Quote Link to comment Share on other sites More sharing options...
James_H Posted April 11, 2014 Share Posted April 11, 2014 When you go from 4K to 2K, you have a 2:1 ratio in each direction (vertical and horizontal). When you go from 1080p to 720p, you have a 3:2 ratio. You don't quite have enough pixels to have a proper 4:4:4 subsampling, but you could use some sort of averaging or binning of pixels to interpolate a greater amount of chroma detail. Quote Link to comment Share on other sites More sharing options...
thementalist Posted April 11, 2014 Author Share Posted April 11, 2014 Can the improvement justify this discussion and the 'how to'? Thanks Quote Link to comment Share on other sites More sharing options...
James_H Posted April 11, 2014 Share Posted April 11, 2014 Can the improvement justify this discussion and the 'how to'? Thanks Here's the gist of how it would work. Let's take a quick look at what a 4:2:0 file looks like: The black lines represent pixel borders. Here is that same image broken into luma and chroma components: As you can see, the luma channel has data for each individual pixel, whereas the chroma channels only have data for groups of 4 pixels. In other words, the chroma channels are at a lower resolution (half the resolution vertically and half the resolution horizontally). Now, if we scale down the image, we should get something like this: (Instead of scaling the image down, I just resized the pixels) Remember, the black lines denote the pixel borders. So we end up with the original values spanning several pixels. Obviously each pixel can't contain more than one colour value, so we have to take the weighted average of each pixel. We end up with this for the chroma channels: As you can see, we're getting a different colour value for each pixel. This technique isn't as accurate as downscaling 4K to 2K, but it does give you a pseudo-4:4:4 image. The luma channel would also be affected. But this far into my response, I realize that the luma pattern I used in my examples was a bad choice and doesn't properly illustrate what happens. Quote Link to comment Share on other sites More sharing options...
