APS-C action cam
JurijTurnsek
It is a fisheye lens though. Would rather go with this:
https://www.bhphotovideo.com/c/product/1387950-REG/7artisans_photoelectric_7a12f28se_12mm_f2_8_aps_c_for.html
Or this if you need it even wider:
https://www.bhphotovideo.com/c/product/1399998-REG/venus_optics_ve928se_laowa_9mm_f_2_8_zero_d.html
And ideally, a Z Cam E2-S6 over a Sony QX1, for an action / crash cam.
15 hours ago, JurijTurnsek said:
The overall package would be pretty compact, but a dedicated solution could be a lot smaller still. Maybe some OEM ventures beyond 1" in this segment in the future - the bump in IQ would be noticeable.
If you want bigger than GoPro sensor size, in ultra compact form factor, then you've got the 1" sensor in the Sony RX0 (and there is a mk2 now too).
