Rhood Posted January 12, 2022 Share Posted January 12, 2022 Hi, I have an Iscomorphot 16 2x lying around. I searched here on the forums and on the net but couldn't find the version I have lying around. Mine doesn't have any rings that turn. So it seems like focus through version? Is anyone familiar with this version? I did some quick test handholding it in front, but didn't seem to get it sharp at 1 to 3m. Link to comment Share on other sites More sharing options...
au8ust Posted January 13, 2022 Share Posted January 13, 2022 There aren't "focus through" lenses. The lens you have without a focus ring is likely a fixed focus lens. That means they designed it to be focused at a specific distance eg. 4m or inf, depends on the manufacturer. You can, however, move the front or rear element back and forth to achieve different focus point. Check https://www.youtube.com/watch?v=dmMiuMFQSuU for a similar lens. Link to comment Share on other sites More sharing options...
Rhood Posted January 13, 2022 Author Share Posted January 13, 2022 Ah I see! Would a focusing diopter on the front solve this? Thanks! Link to comment Share on other sites More sharing options...
au8ust Posted January 13, 2022 Share Posted January 13, 2022 If it's fixed at something like 4m then you will be able to focus from 4m down to very very close, unless you have a special variable diopter that has both negative and positive power adjustment. I'd say the best way is to modify your scope to achieve inf and lock it there. Then you can use any focuser to focus it from inf down to about 1m. Link to comment Share on other sites More sharing options...
Leon Postma Posted January 23, 2022 Share Posted January 23, 2022 Rapido Technology makes variable diopters for this particular anamorphic. I have the same scope - just haven’t pulled the trigger on a diopter yet. Link to comment Share on other sites More sharing options...
keessie65 Posted January 23, 2022 Share Posted January 23, 2022 Great lens @Rhood. I have the same, single coated version. Check this link with more information: Link to comment Share on other sites More sharing options...
Rhood Posted January 25, 2022 Author Share Posted January 25, 2022 Will check it out! Thanks! Link to comment Share on other sites More sharing options...
