kye Posted January 15, 2022 Share Posted January 15, 2022 ie, if I took a FF camera and all the available lenses, put them in a shrink machine, set it to 50%, and hit go, would I get an MFT system with the same optical characteristics? ie, same FOV, save DoF, etc? I'm not talking about the electrical side of things as that's an entirely different ballgame, just the optics and sensor size. In physics there are some things that scale linearly, but there are other things really don't, for example volume. If you put something in a 50% scaling machine it would be one-eighth the volume, and weight (assuming identical materials). Lens size and weight are smaller with MFT but not proportionately, in any way I've been able to identify anyway. PannySVHS and John Matthews 2 Link to comment Share on other sites More sharing options...
John Matthews Posted January 15, 2022 Share Posted January 15, 2022 I'd take it the other direction. The smallest MFT camera is the GM1 and the smallest "real" lens (with AF) is the 14mm f/2.5. The grand total of that combo is 259g and a volume of 0.181 liters (treating the camera as a block and the lens as a cylinder): GM1 = 54.9×98.5×30.4 = .164 liters, 14mm f/2.5 = 27.75 radius x 20.5 length = .017 liters So can we find a FF combo that is only double that figure? 518g and .362 liters It should be possible, but think it's never been done. The smallest FF camera is the Sigma FP (I think). It's weight and volume is 422g and accurately described as .357 liters, leaving only 96g and .005 liters left. Can you make a lens (with AF) for that? The weight is definitely possible, but the volume probably wouldn't work out. One major constant with all this is the human hand. There's only so much you can comfortably hold and operate. The other constant I suppose would be a pocket if you're taking it everywhere. PannySVHS 1 Link to comment Share on other sites More sharing options...
PannySVHS Posted January 15, 2022 Share Posted January 15, 2022 I like the original question because it inspires perspectives on size, ergonomy and camera choices. So, silly me, I decided to buy a BMMCC and so I did. But what reasons for? I got attracted by the cute size, by the prospect of cutely sized files in Prores LT and a great image to size ratio. I will see how that plays out regarding lenses. Tevidon lenses are not that easy to rig. After all small size is not a virtue by itself I figure. John Matthews 1 Link to comment Share on other sites More sharing options...
leslie Posted January 15, 2022 Share Posted January 15, 2022 Playing devils advocate momentarily... the bm p4k is mft, Not sure that black magic design, got your memo about cuteness or smallness or a flippy screen 😉 Still i am happy enough with my camera. With a olympus body cap lens, i can get it in a pocket just... 😀 webrunner5 1 Link to comment Share on other sites More sharing options...
