ChrisInColour Posted January 25, 2022 Share Posted January 25, 2022 Hi, Â Does anyone know if there is an app the will convert Canon R5/R3 raw CRM video files to Cinema DNG? Thanks Chris Link to comment Share on other sites More sharing options...
Administrators Andrew Reid Posted January 25, 2022 Administrators Share Posted January 25, 2022 I don't think it's possible as Canon RAW isn't really quite "raw" in the way Cinema DNG is? I could be wrong but it is unlikely there would be enough benefit in the conversion to make an app worthwhile to make? Link to comment Share on other sites More sharing options...
ChrisInColour Posted January 26, 2022 Author Share Posted January 26, 2022 Cheers Andrew, I'm aware that the raw partially debayerd with Cannons secret sauce embedded in (or what ever the technical term is). I just hoping there was some way of converting them with what ever data is there. I really like Adobes processing of Cinema Dngs, the process is mind numbing slow but the results are very good. Does anyone know of a workflow or an app the might be able to do it? Â Also does anyone have a workflow to get the best possible processing out of the canon raws? Â Thanks Chris Link to comment Share on other sites More sharing options...
kye Posted January 26, 2022 Share Posted January 26, 2022 I'm guessing that if you have the studio version of Resolve you could do it? I'd imagine that the files from the R5/R3 will be readable in Resolve and it can definitely export CinemaDNG files. Â You'll need the paid (Studio) version though as the free version has a resolution cap on it (4K perhaps?) and I'd assume you're dealing with larger resolutions from those cameras. Link to comment Share on other sites More sharing options...
ChrisInColour Posted January 26, 2022 Author Share Posted January 26, 2022 Thanks, I have a studio version of resolve but I cant find CinemaDNG option. Do you know how to? Â Chris Link to comment Share on other sites More sharing options...
Administrators Andrew Reid Posted January 26, 2022 Administrators Share Posted January 26, 2022 There is no option for DNG in Resolve export. You can only import Cinema DNG. This is all a bit like trying to import a JPEG into Photoshop and saving it as a RAW file! I don't think it can be done or even makes sense because what makes DNG handle so nicely with Adobe's processing is the fact that it is virtually uncompressed true sensor RAW data, and Canon RAW isn't - that stuff is already processed and a lot is lost. Link to comment Share on other sites More sharing options...
kye Posted January 26, 2022 Share Posted January 26, 2022 @ChrisInColour @Andrew Reid of course - that makes sense.  Bummer. Could you use another format from Resolve that Adobe could import?  TIFF perhaps? Link to comment Share on other sites More sharing options...
Administrators Andrew Reid Posted January 26, 2022 Administrators Share Posted January 26, 2022 You can't use Adobe Camera Raw controls with a TIFF I don't think? Link to comment Share on other sites More sharing options...
Administrators Andrew Reid Posted January 26, 2022 Administrators Share Posted January 26, 2022 Here's a suggestion, dump the EOS R5 and get a 5D Mark III with Magic Lantern RAW DNG, or a Blackmagic Pocket Cinema Camera 4K with original firmware 😉 webrunner5 and kye 2 Link to comment Share on other sites More sharing options...
kye Posted January 27, 2022 Share Posted January 27, 2022 5 hours ago, Andrew Reid said: You can't use Adobe Camera Raw controls with a TIFF I don't think? This page at Adobe says "You can still edit JPEG and TIFF images in Camera Raw, but you will be editing pixels that were already processed by the camera. Camera raw files always contain the original, unprocessed pixels from the camera." That's why I suggest it might be an option.  IIRC TIFF can also be uncompressed and can contain high bit depths so it seems a good container to keep the benefits of RAW files but get the pixels into a container that works with ACR.  It would still have to be de-bayered in Resolve of course, but I doubt that the aesthetic difference that the OP is seeing is some revolutionary approach to de-bayering.  Of course, maybe it is and this approach may not work, but if it didn't then Resolve would be out, and it's a convenient tool considering the OP already has it. Link to comment Share on other sites More sharing options...
gt3rs Posted January 27, 2022 Share Posted January 27, 2022 As soon as you export to something Resolve would need to process the RAW. I wish there would be a tool that can generate a cRaw frame out of a CRL video file. As I process video and photo differently and I do a lot of frame extraction this is how I do: - In Resolve on a 8k timeline I do select the CRL and then the frame that I want hit I and then O so basically mark the a single frame and drop it to the timeline, repeat for each frame that I want. - Render the 8k timeline as 16bit Tiff - Edit the Tiff in Adobe Camera Raw - I also have the canon LUTs installed in Adobe Camera Raw - Ev final edit in photoshop if needed I set the camera raw panel in resolve to not apply any sharpening. If you need a big wb change you need to do it in Resolve up front, the rest I can do all in ACR and I’m quite happy on how much processing I can do on the 16bit Tiff. For video I do everything in Resolve I see no point in doing CRL -> Tiff -> ACR for video…  Andrew Reid and leslie 1 1 Link to comment Share on other sites More sharing options...
Administrators Andrew Reid Posted January 27, 2022 Administrators Share Posted January 27, 2022 Can see how that workflow might be nice for photographers grading stills out of a RAW video sequence. Link to comment Share on other sites More sharing options...
ChrisInColour Posted January 29, 2022 Author Share Posted January 29, 2022 Thanks gt3rs for the workflow, really helpful. Unfortunately with after effects you cant force it to open in camera raw. There doesn't seem to be anyway to open and make use of camera raw with the Canon CRM files. Shame I do very much prefer the cinema dng camera raw workflow.  Andrew On 1/27/2022 at 6:45 AM, Andrew Reid said: Here's a suggestion, dump the EOS R5 and get a 5D Mark III with Magic Lantern RAW DNG, or a Blackmagic Pocket Cinema Camera 4K with original firmware 😉 Yes I already do. I have a 5d mark iii with magic lantern that I do a lot of projects with, using one of the Dante builds. Convert the MLV to cinema dng and process in after effects. Slow but the results are amazing. Truly amazing.  I also have a Blackmagic Cinema Camera 2.5k MTF with a speed booster using the original firmware for non compressed CDNGS. Again processed in after effects. The results from that sensor are stunning.   I just was looking at either the R5 or R3, just for workflow on some projects. In built stabilisation, autofocus, small in built screen. Faster transcoding workflow.  Everything in a small package.  Chris Link to comment Share on other sites More sharing options...
