elvisvalentine Posted December 29, 2011 Share Posted December 29, 2011 Hi folks, this is my first post. The title is basically the question im asking. Can you hook up a DSLR to an external hdd via an sd to usb adapter and therefore not have to buy numerous sd cards with limited recording capacities? Thanks for any input in advance. Link to comment Share on other sites More sharing options...
Scott Klein Posted December 30, 2011 Share Posted December 30, 2011 I could only find the mobidapter micro Sd to USB and it says it is limited to 32gb. Have you found something else? A sdxc to USB would be intriguing. Link to comment Share on other sites More sharing options...
elvisvalentine Posted December 30, 2011 Author Share Posted December 30, 2011 No, i have not really seen many different types of adapter but that mobiadapter is the sort of thing i expected there to be an abundance of. I mean there must be something like that out there but instead of an normal usb2 port it has a mini usb2 port so you could just plug in an external hdd right? lol If not i claim the patent right now:-) It just seems like that would be a really obvious easy thing for longer recording times etc. i have a 1 tb drive that would easily fit next to my gh2. im not sure about transfer rates etc but isnt this a decent viable idea? Cheers Link to comment Share on other sites More sharing options...
Administrators Andrew Reid Posted December 31, 2011 Administrators Share Posted December 31, 2011 A CF / SD to SSD drive adapter would be very interesting although 32/64GB is probably the limit of most camera I/O controllers, and speed certainly wouldn't be at the 500Mb/s mark that a SSD can achieve via SATA 3. If the manufacturers got their fingers out, we'd have a SSD in a battery grip by now with 4K RAW going onto it from a 35mm sensor, with the body costing around $3K. All technically achievable but there isn't A) the margin B) the mass market. If they produced it for a niche it would be in smaller numbers so the margin on each unit would have to be higher to justify the support, R&D and overall endeavour. Link to comment Share on other sites More sharing options...
elvisvalentine Posted December 31, 2011 Author Share Posted December 31, 2011 Yeah, that sounds exactly like the sort of thing that should exist . But alas. >:( Thanks for the replies though. Link to comment Share on other sites More sharing options...
