paulraymaekers Posted April 29, 2014 Share Posted April 29, 2014 hi, next question (thanks for the replies on the first question:-) can someone check what the DR is of the GH4 when you record externally 1080p 10bit 4.2.2 ? paul ps: i use a GH3 and a BMPCC: the last one for low light and DR (if needed) Link to comment Share on other sites More sharing options...
KarimNassar Posted April 29, 2014 Share Posted April 29, 2014 I also want to see a side by side comparison of the internal recording footage compared to the external 10bit one. Even better if they push the footage in post to compare how it holds up. But have not seen any as of now. Link to comment Share on other sites More sharing options...
paulraymaekers Posted June 11, 2014 Author Share Posted June 11, 2014 any one tested the GH4 10 bit 422 external recorded ? Link to comment Share on other sites More sharing options...
Guest Ebrahim Saadawi Posted June 11, 2014 Share Posted June 11, 2014 Would love to see it too. Have no external recorder at the moment unfortunately... anyone? Link to comment Share on other sites More sharing options...
Administrators Andrew Reid Posted June 11, 2014 Administrators Share Posted June 11, 2014 I will be testing this with some Atomos gear before too long. Nick Hughes 1 Link to comment Share on other sites More sharing options...
Guest d5f8611fa423d0e628c016f9d5c93b47 Posted June 11, 2014 Share Posted June 11, 2014 A guy did post some for download on this forum a week or two ago ... I'll try to find it Link to comment Share on other sites More sharing options...
Guest d5f8611fa423d0e628c016f9d5c93b47 Posted June 11, 2014 Share Posted June 11, 2014 Jacob Neilsen posted this 10 bit footage from GH4 + Ninja Blade via Dropbox (see EOSHD's GH4 Review comments thread, page 3): https://www.dropbox....est footage.mov I put it into FCPX and pushed it around a bit and was amazed (never worked with 10 bit before though!). I think it looks absolutely stunning - particularly the 2nd shot of the girl with the chair. nib187 1 Link to comment Share on other sites More sharing options...
Administrators Andrew Reid Posted June 11, 2014 Administrators Share Posted June 11, 2014 That footage is stunning... hello colour :) Hello dynamic range... I will definitely be delving into the HDMI output of the GH4 further next week. Link to comment Share on other sites More sharing options...
varicam Posted June 12, 2014 Share Posted June 12, 2014 I still don't quite understand how to record from the HDMI output. Do you just plug into an HDMI recorder and the GH4 will output the stream live to the HDMI? Or can you only record through playback from the camera? Link to comment Share on other sites More sharing options...
Administrators Andrew Reid Posted June 12, 2014 Administrators Share Posted June 12, 2014 It's live. You just plug it in, but instead of hitting record on the camera, hit record on the external monitor / recorder. Sony A7S also has a record trigger for external devices... Meaning you can just hit the record button on the camera as normal to trigger the external recorder to start / stop capture, so you don't need to touch the device, just the camera. Nice feature. Unfortunately GH4 does not have this ability with current firmware. Hope they add it by the time the Shogun is released. Link to comment Share on other sites More sharing options...
raf702 Posted June 12, 2014 Share Posted June 12, 2014 I'm downloading that clip right now. Im assuming it's recorded in 1080p 10 bit 422? I can only imagine how 4K will look if the 1080p video is that good. Link to comment Share on other sites More sharing options...
Guest d5f8611fa423d0e628c016f9d5c93b47 Posted June 12, 2014 Share Posted June 12, 2014 Yes it must be HD. The Blade can't record 4K. I genuinely can't imagine it being able to look any better! Andrew please do a comprehensive low light test (vs downsampled 4k) when you try this out! :) Can 10-bit/422 help with noise? It must do ... Link to comment Share on other sites More sharing options...
AaronChicago Posted June 12, 2014 Share Posted June 12, 2014 Very nice. Added an Osiris LUT with no other changes. Looks great! nahua, johnnymossville and Daniel Acuña 3 Link to comment Share on other sites More sharing options...
Guest d5f8611fa423d0e628c016f9d5c93b47 Posted June 12, 2014 Share Posted June 12, 2014 Just to clarify what I said above, the footage was shot at 4K on the GH4 but recorded to the Ninja as 1080p. I have no idea if you will get superior results recording 10-bit/422 4K to a Shogun and then downsampling in post. I don't see why you would really. Doesn't downsampling via the Ninja just simplify the workflow? Is it possible that the big wait for the Shogun will be a bit pointless if you're going to be downsampling to HD in post anyway?! Personally I'd rather have a Ninja Star in my pocket than a Shogun on top of my GH4 ... nib187 1 Link to comment Share on other sites More sharing options...
johnnymossville Posted June 12, 2014 Share Posted June 12, 2014 Aaron, that does look spectacular. Any video clips showing how that looks? AaronChicago 1 Link to comment Share on other sites More sharing options...
AaronChicago Posted June 12, 2014 Share Posted June 12, 2014 Aaron, that does look spectacular. Any video clips showing how that looks? It is from Jacob Neilsens test here: https://www.dropbox.com/s/9mt8hkrfk6hepj0/GH4%20UHD-Ninja%20Blade%2010bit%20test%20footage.mov johnnymossville and nahua 2 Link to comment Share on other sites More sharing options...
nib187 Posted June 13, 2014 Share Posted June 13, 2014 Jacob Neilsen posted this 10 bit footage from GH4 + Ninja Blade via Dropbox (see EOSHD's GH4 Review comments thread, page 3): https://www.dropbox....est footage.mov I put it into FCPX and pushed it around a bit and was amazed (never worked with 10 bit before though!). I think it looks absolutely stunning - particularly the 2nd shot of the girl with the chair. Andrew, I don't follow every thread in this forum, but I think that this is information anyone (shooting with GH4) should know. Do you cover it in the GH4 guide? Or - do you sometimes update your guides? My point is - I'd like to know wheter I have to read everything here or not :P Link to comment Share on other sites More sharing options...
paulraymaekers Posted June 13, 2014 Author Share Posted June 13, 2014 Just to clarify what I said above, the footage was shot at 4K on the GH4 but recorded to the Ninja as 1080p. I have no idea if you will get superior results recording 10-bit/422 4K to a Shogun and then downsampling in post. I don't see why you would really. and this brings us to another question again :-) (as we seem to ask good questions :-)) the HDMI out 1080p, is it compressed in a different way from the full sensor to 1080, compared to the internally recorded 1080? I know it is 10 bit 4.2.2, but the downsampling in the camera from full sensor to 1080 is the same algorithm for internal recording and external to HDMI, so it would have the same sharpness, and not sharper as some might hope? OR you write: shot at 4K but recorded to Ninja as 1080p. Does the Ninja convert the 4k HDMI signal to 1080p? Link to comment Share on other sites More sharing options...
varicam Posted June 13, 2014 Share Posted June 13, 2014 I have just burned 576 MB of my monthly data for just 28 seconds video. :D But the quality is amazing. Well worth it. Link to comment Share on other sites More sharing options...
Guest d5f8611fa423d0e628c016f9d5c93b47 Posted June 13, 2014 Share Posted June 13, 2014 Yes it's the Ninja that converts the 4K to HD. That's what you are seeing in the Dropbox video above. This is why I can't see any benefit to buying a Shogun if you're going to be downsampling in post anyway. As I understand it, the GH4 gives full sensor readout when using 4K whatever. If this really is the case it actually makes more sense to record to 1080 prores. In which case a standard Ninja is probably better - saving yourself money, time, hassle, space on your hard drives and space on your hotshoe! ;) Link to comment Share on other sites More sharing options...
