kaylee Posted July 15, 2022 Share Posted July 15, 2022 hey guys!! please help me so i can recommend camera(s) for my friends new ~low budget youtube show~ its a satire of a typical late night talk show... from carson to the present, very similar sets, right? desk, two chairs/couch, etc. this will be a small set in a living room – not the ed sullivan theatre, just fyi the director wants to start with two cameras, allowing for the possibility of adding more in the future, but they need to match – meaning: we need two inexpensive identical camera bodies. two of the same camera the camera needs to: - have reasonable image quality - shoot forever without overheating - have a front facing flippy screen - be super affordable - it does NOT need to shoot stills at all, a 'camcorder' is totally a possibility (something in know nothing about) suggestions?? please help!! thank you!! love u guize!!! tupp and kye 2 Link to comment Share on other sites More sharing options...
tupp Posted July 15, 2022 Share Posted July 15, 2022 Sounds like small camcorder with a decent rocker zoom and manual capability would be ideal. Markus Pix recently touted the Sony CX405, but it would be smart to look at offerings from other brands: Tell your friend to put all the cameras side-by-side before shooting, and then to white balance them simultaneously off of the same white/gray card. Additionally, your friend should shoot a short clip of the white/gray card with each camera -- just in case! webrunner5 and kaylee 2 Link to comment Share on other sites More sharing options...
webrunner5 Posted July 15, 2022 Share Posted July 15, 2022 Makes you want to sell all your stuff and buy a camcorder. Hmm. 😬 tupp and HockeyFan12 2 Link to comment Share on other sites More sharing options...
PPNS Posted July 15, 2022 Share Posted July 15, 2022 second hand sony pmw 150s, panasonic AG-AC160s, or panasonic aj-hpx255s if the p2 cards are included? new panasonic HC-X1s or sony PXW-Z150s? kaylee and tupp 2 Link to comment Share on other sites More sharing options...
Emanuel Posted July 15, 2022 Share Posted July 15, 2022 On 7/15/2022 at 1:32 PM, webrunner5 said: Makes you want to sell all your stuff and buy a camcorder. Hmm. 😬 Expand Does it beat the handy Osmo Pocket series? Camcorder, right? So, forget that cinematic mantra then: Humm... ; ) But if you're not convinced how useful these tools can work out, take a look here and there. tupp 1 Link to comment Share on other sites More sharing options...
tupp Posted July 15, 2022 Share Posted July 15, 2022 On 7/15/2022 at 7:44 PM, Emanuel said: Does it beat the handy Osmo Pocket series? Camcorder, right? So, forget that cinematic mantra then Expand OP said that the cameras will be used in a "talk show" setting. So, they will likely be on sticks and require a lens that can get fairly tight, with smooth zoom-in/zoom-outs. kaylee and Emanuel 2 Link to comment Share on other sites More sharing options...
Emanuel Posted July 15, 2022 Share Posted July 15, 2022 On 7/15/2022 at 7:56 PM, tupp said: OP said that the cameras will be used in a "talk show" setting. So, they will likely be on sticks and require a lens that can get fairly tight, with smooth zoom-in/zoom-outs. Expand Well, in a much Brechtian more interesting setup approach than the conventional one, you'd be able to fix it pretty well... : D tupp 1 Link to comment Share on other sites More sharing options...
newfoundmass Posted July 16, 2022 Share Posted July 16, 2022 Will this be edited in post or will it be connected to a switcher? If it's being done in post then you've got a lot of options. Pretty much any camcorder that allows you to custom white balance will work. I filmed lots of multicam shoots with the Sony hdr-cx580. It's an older camera, but it was decent in low light and worked really well. If they're doing it live then two GH5 cameras with primes would work. Even if they do the editing in post the GH5 is a great option, but I specifically say this because it has the full size HDMI out. If they prefer camcorders then the Panasonic HC-MDH3 is the cheapest camcorder you'll find that has a full size HDMI, at least that I know of. kaylee 1 Link to comment Share on other sites More sharing options...
kaylee Posted July 18, 2022 Author Share Posted July 18, 2022 thanks guys!! im researching these many cheap camcorder options...! On 7/16/2022 at 3:23 AM, newfoundmass said: Will this be edited in post or will it be connected to a switcher? Expand edited in post – theres some effects that they just cant do live Link to comment Share on other sites More sharing options...
Snowfun Posted July 20, 2022 Share Posted July 20, 2022 I’d definitely go with 2 (or more) AIDA cameras fed into a BM Atem for this. They are cheap and capable and the setup is easy to use (either live streamed or recorded - in the latter case there are, of course, multiple options either to record each camera separately and mix in post or simply to record a single output from the Atem). I use 2 x HD100A but there are other more expensive options. kye, PannySVHS and kaylee 3 Link to comment Share on other sites More sharing options...
kye Posted July 21, 2022 Share Posted July 21, 2022 On 7/20/2022 at 6:02 PM, Snowfun said: I’d definitely go with 2 (or more) AIDA cameras fed into a BM Atem for this. They are cheap and capable and the setup is easy to use (either live streamed or recorded - in the latter case there are, of course, multiple options either to record each camera separately and mix in post or simply to record a single output from the Atem). I use 2 x HD100A but there are other more expensive options. Expand Interesting tiny cameras. What are you using them for? Link to comment Share on other sites More sharing options...
kaylee Posted July 21, 2022 Author Share Posted July 21, 2022 thank you @Snowfun, im new to these~! ill do some research – could you tell me a bit more about them, in a word...? Link to comment Share on other sites More sharing options...
Snowfun Posted July 21, 2022 Share Posted July 21, 2022 On 7/21/2022 at 4:15 AM, kye said: Interesting tiny cameras. What are you using them for? Expand I use them for delivering recorded and live lectures & meetings (using Teams). The Atem handled the green screen side of things so I had the Keynote slides behind me. kye 1 Link to comment Share on other sites More sharing options...
Snowfun Posted July 21, 2022 Share Posted July 21, 2022 On 7/21/2022 at 6:04 AM, kaylee said: thank you @Snowfun, im new to these~! ill do some research – could you tell me a bit more about them, in a word...? Expand “Professional” if I was permitted additional words - convenient, useful, adaptable, manageable, cost-efficient… I am not a professional broadcaster but for my use they are super little cameras especially when matched to the Atem. https://aidaimaging.com/hd-100a/ I have two of the cheapest model. kaylee 1 Link to comment Share on other sites More sharing options...
