PatrickV Posted May 15, 2014 Share Posted May 15, 2014 Hi guys, My GH4 arrived yesterday and I have some practical questions about how to deal with 4K files regarding clients: When the client uses the video for online purposes (Vimeo/YouTube): would you guys recommend to supply the orginal 4K resolution file? Or scale it down to 1080p first? (in terms of quality, playback etc.) When the client uses the video for offline purposes: I guess it depends on the system they wanna use for the playback of the video, right? When using 4K mode and slow-motions (1080p) in the same videoproduction. Should you render in 4K or 1080p? Hope to hear from you! Thanks in advance. Link to comment Share on other sites More sharing options...
Guest Ebrahim Saadawi Posted May 15, 2014 Share Posted May 15, 2014 1- Supply 1080p unless they specifically ask for it. Or if you can, both. I've always supplied 2 file versions. "Best", and "small". 2- Right 2- Render to 1080p if you're shooting 1080p slowmotion. Last thing you want is upscaling the soft 96p image 4 times bigger! Link to comment Share on other sites More sharing options...
PatrickV Posted May 15, 2014 Author Share Posted May 15, 2014 Hi Ebrahim, Thanks for your quick response! 1. Is this because of the slow internet connection of some users, which makes 1080p more suitable for online purposes because its playback is more user-friendly? 2. Clear. 3. Clear. Additional question: When u want the best possible image of your 4K footage on Vimeo: should you render as 4K or 1080P? Link to comment Share on other sites More sharing options...
dafreaking Posted May 15, 2014 Share Posted May 15, 2014 Also most people don't have 4K monitors, so serving 4K is not very practical as yet. Link to comment Share on other sites More sharing options...
Guest Ebrahim Saadawi Posted May 15, 2014 Share Posted May 15, 2014 1. Is this because of the slow internet connection of some users, which makes 1080p more suitable for online purposes because its playback is more user-friendly? Additional question: When u want the best possible image of your 4K footage on Vimeo: should you render as 4K or 1080P? 4K files will add more issues than benefits for a client who doesn't specifically want 4K. 1-It will take you longer to deliver if you're doing it online, 2-Will take more space on the client's harddrive. 3-It will require a faster computer to view/play.4-It will take them much more time to upload the 4K file to an internet video service (YT/Vimeo)5-Even if your client doesn't mind these 4 points, if they don't have an expensive 4K monitor to view it, they will not benefit from 4K at all. And will have cost themselves all these troubles for nothing at all. Remember: As the Dafreaking said: you need a 4K monitor to view 4K images. And most people don't. If they do, they will specifically ask for it, and you will deliver it. That's why I said "only when they specifically ask for it" As for the second question: I would like to know the answer too. Since Vimeo downscale the footage to 720p anyway, is it better to downscale the video to 720p before uploading, or uploading the highest resolution and letting Vimeo do the scaling? (Only speaking of online viewing) Link to comment Share on other sites More sharing options...
PatrickV Posted May 15, 2014 Author Share Posted May 15, 2014 Thanks! It's clear now! I hope somebody can answer question 2 for us :-) Link to comment Share on other sites More sharing options...
Nick Hughes Posted May 15, 2014 Share Posted May 15, 2014 As for the second question: I would like to know the answer too. Since Vimeo downscale the footage to 720p anyway, is it better to downscale the video to 720p before uploading, or uploading the highest resolution and letting Vimeo do the scaling? (Only speaking of online viewing) Probably best to still upload 1080 to vimeo. BTW, with vimeo plus ($60 a year or $10 a month), you have the option to stream at 1080. Link to comment Share on other sites More sharing options...
