PannySVHS Posted August 14, 2022 Share Posted August 14, 2022 So I bet, many of you have heard or read of the Iscomorphot 8 1.5x anamorphic adapter, which is a tiny and single focus gem. It was built for Super 8 cameras and even works for S35 but with inherent flaws regarding resolution, since it was built for Super8. Here is a beautiful video in its own right and vertical use of the anamorhot, which means that camera was rotated by 90 degrees. Camera was a m43 Zcam, so the sensor was in a 3 to 4 format position after rotating it by 90 degrees. Taking lens was a 90mm Voigtlaender. This should give us a 3x1.5 to 4 format = 4.5 to 4 = 1.125 to 1 ratio! Enjoy and happy hunting for the Iscomorphot! 🙂 webrunner5 and Juank 2 Link to comment Share on other sites More sharing options...
webrunner5 Posted August 15, 2022 Share Posted August 15, 2022 If that would have been in B&W it would have looked even more 50ish. A little too much OOF for me but nice non the less. Yeah there are some old gems for lenses out there thrown in a box wasting away sad to say. But fungus is slowly killing most of them. Might be a good business to open cleaning and saving them. Link to comment Share on other sites More sharing options...
hyalinejim Posted August 15, 2022 Share Posted August 15, 2022 Ha ha! I had one of these to mess around with back in the midst of the anamorphic craze. Picked it up for peanuts, knowing nothing about it as I think there was almost no info online at the time. It gave usable results for sure! Here it is on my 5D2.... 12 years ago now! Juank, webrunner5 and PannySVHS 3 Link to comment Share on other sites More sharing options...
PannySVHS Posted August 15, 2022 Author Share Posted August 15, 2022 Great lensing, 50 on S35 with an anamorphot looking sweet. Good old 5D2 shines even in 720p for some S16 emulation. I plan on coupling it with a Tevidon 25mm and use it on my BMMCC. I´m just a lazy and stingy cat when it comes to rigging and buying rigging parts.:) webrunner5 1 Link to comment Share on other sites More sharing options...
Administrators Andrew Reid Posted August 15, 2022 Administrators Share Posted August 15, 2022 Is it this one (left)? I still have it. Could never quite get it working properly. Didn't even know it was single focus?! Might have to try it again with some c-mount stuff. PannySVHS and webrunner5 2 Link to comment Share on other sites More sharing options...
PannySVHS Posted August 15, 2022 Author Share Posted August 15, 2022 Exactely, Andrew. It's the Iscomorphot 8 which is single focus. There is an Isco anamorphot 8 which is fixed focus. That's what I'm planning on doing, to use it with my Tevidons on my Bmmcc. S16 should be the perfect format for it. Tito has tested both of them in S35 crop on an A7S II, which it covers but with super soft edges. I still have troubles adapting my Tevidons as the Tevidon to C-mount adapter does not screw deep enough into the C-mount to Mft adapter. My only Tevidon i get mounted is the 35mm to my S1. Awesome lens btw, covering S35 crop! Link to comment Share on other sites More sharing options...
Administrators Andrew Reid Posted August 15, 2022 Administrators Share Posted August 15, 2022 @Tito Ferradans Any thoughts? Link to comment Share on other sites More sharing options...
QuickHitRecord Posted August 16, 2022 Share Posted August 16, 2022 I had one a long time ago. I did a test with it that was actually featured in a blog post here, though I can't find the link. I found this lens to be terribly soft until f5.6 or so. Mine had the crazy "cleaning marks" on the front element, and I actually spent way too much money sending it off to have the front element resurfaced (and recoated? I can't remember). Which did not help at all. I did some tests with it after I got it back and sold it shortly afterwards. webrunner5 1 Link to comment Share on other sites More sharing options...
PannySVHS Posted August 17, 2022 Author Share Posted August 17, 2022 I remember that test @QuickHitRecord Cool to realise now that you did this test.:) Are you sure it is the iscomorphot 8 1.5x and not the isco anamorphot 8 1.5x? The iscomorphot 8 is the single focus solution, seen left on Andrews picture above, the isco anamorphot 8 is the fixed focus one with much worse performance. Tito has tested both of them. Hopefully I get to rig mine some time soon. I got two of them for setting them up with two focal lengths. Some time soon.:) Haha @Justin Bacle has even commented on it under Titos video.:) Link to comment Share on other sites More sharing options...
QuickHitRecord Posted August 17, 2022 Share Posted August 17, 2022 @PannySVHS Yes, that was the single focus Iscomorphot 8 1.5x. I also had the fixed-focus Isco Anamorphot 8 1.5x at one point (I have some footage from that lens that starts at 00:43). It's amazing to me how much money I spent on anamorphic lenses and adapters during the early 2010s. I could not imagine doing that now! Link to comment Share on other sites More sharing options...
