webrunner5 Posted June 20, 2019 Share Posted June 20, 2019 Yeah the new Spyders are really quick to use, and most of it is just push a button and let it do it's thing. The old ones took Forever to calibrate, and like 20 steps at that. I am not familiar with other brands. They may be as good or better? I have for some reason always used Spyders. mercer 1 Link to comment Share on other sites More sharing options...
thephoenix Posted June 21, 2019 Share Posted June 21, 2019 On 6/20/2019 at 11:07 PM, mercer said: Here are some more test shots from the Zeiss 25mm 2.8 ZF “Classic” lens... I’m in the process of picking out a new monitor, can anyone suggest the best/easiest/quickest color calibration tool... Spyder? Expand you wanna check the xrite i1, more professionnal than the spyder and the only calibration accepted by some brands like benq to calibrate monitors. must be about the same price Link to comment Share on other sites More sharing options...
kye Posted June 21, 2019 Share Posted June 21, 2019 On 6/21/2019 at 6:52 AM, thephoenix said: you wanna check the xrite i1, more professionnal than the spyder and the only calibration accepted by some brands like benq to calibrate monitors. must be about the same price Expand +1 for compatibility. I have a Spyder and an extended colour 99% Adobe RGB monitor but can't calibrate it in anything but sRGB, despite both products claiming compatibility with the standard. Buy the monitor (or at least choose the monitor) and buy the calibration device they have "partnered" with. Link to comment Share on other sites More sharing options...
Shirozina Posted June 21, 2019 Share Posted June 21, 2019 Xrite i1 display pro IME is best cheap calibrator but the stock software lets it down and you can get much better results with DisplayCal. AlexTrinder96, Volumetrik and mercer 3 Link to comment Share on other sites More sharing options...
Volumetrik Posted June 21, 2019 Share Posted June 21, 2019 On 6/21/2019 at 1:31 PM, Shirozina said: Xrite i1 display pro IME is best cheap calibrator but the stock software lets it down and you can get much better results with DisplayCal. Expand DisplayCal is a great software, free and open source, plus it's more powerful than the stock softwares from Spyder and Xrite. I calibrated my display with it and did the calibration with the Spyder's stock software to compare. The software DisplayCal applies a driver level correction while the software from Spyder did like an overlay which glitched in certain applications and was visually much less accurate. Shirozina and webrunner5 1 1 Link to comment Share on other sites More sharing options...
KnightsFan Posted June 22, 2019 Share Posted June 22, 2019 @Volumetrik I use DisplayCal with a Spyder as well. Do you happen to use Resolve? Do you know the process to creating a color correction LUT from DisplayCal to use in Resolve? I am not particularly confident that I did it correctly. Link to comment Share on other sites More sharing options...
Geoff CB Posted June 23, 2019 Share Posted June 23, 2019 On 6/22/2019 at 4:08 PM, KnightsFan said: @Volumetrik I use DisplayCal with a Spyder as well. Do you happen to use Resolve? Do you know the process to creating a color correction LUT from DisplayCal to use in Resolve? I am not particularly confident that I did it correctly. Expand ???? DisplayCAL is used to get your screen to show accurate color. Nothing to do with Resolve and LUT creation. Another with my Voigtlander 40mm. This time on the Z6 in Neutral Castorp, mercer, kye and 1 other 4 Link to comment Share on other sites More sharing options...
KnightsFan Posted June 23, 2019 Share Posted June 23, 2019 @Geoff CB As far as I can tell, Resolve on Windows doesn't use the ICC profile that DisplayCAL (or other calibration software) generates, so you need to create a 3D LUT to have the calibration applied to Resolve's viewers. See: https://hub.displaycal.net/wiki/3d-lut-creation-workflow-for-resolve/ however, some of the information that I found about it is very confusing and contradictory. Link to comment Share on other sites More sharing options...
Geoff CB Posted June 23, 2019 Share Posted June 23, 2019 On 6/23/2019 at 2:36 PM, KnightsFan said: @Geoff CB As far as I can tell, Resolve on Windows doesn't use the ICC profile that DisplayCAL (or other calibration software) generates, so you need to create a 3D LUT to have the calibration applied to Resolve's viewers. See: https://hub.displaycal.net/wiki/3d-lut-creation-workflow-for-resolve/ however, some of the information that I found about it is very confusing and contradictory. Expand That is only if you are using a external monitor with resolve. If you are using it on your desktop monitor there is no issues. Link to comment Share on other sites More sharing options...
thephoenix Posted June 23, 2019 Share Posted June 23, 2019 hi guys. anyone familiar with voigtlander here ? i can buy the 40mm 1.4 nokton but don't know if it is as sharp as the 40mm f2. anyone knows ? Link to comment Share on other sites More sharing options...
KnightsFan Posted June 23, 2019 Share Posted June 23, 2019 On 6/23/2019 at 2:46 PM, Geoff CB said: That is only if you are using a external monitor with resolve. If you are using it on your desktop monitor there is no issues. Expand There are two sections in that wiki, one for using it with a Decklink monitor, and one for using it with a desktop monitor. Seems pretty clear in this conversation with DisplayCAL's creator that you need both the ICC profile and LUT (which I just found today, and seems to be a strong confirmation of what I was doing). https://hub.displaycal.net/forums/topic/resolve-lut-for-gui-viewer-profile-loader-both-needed/ Link to comment Share on other sites More sharing options...
Geoff CB Posted June 23, 2019 Share Posted June 23, 2019 Quote "I want my (directly connected) display to be calibrated for the work in Davinci Resolve. I’m using Windows 10. In your guideline “Creating a 3D LUT for the GUI color viewer” I’m advised to install the profile on the system basis – so being loaded via the profile loader and in addition to this using the created 3D LUT in Resolve for the “3D Color Viewer Lookup Table” entry. I just wanted to ask, if that is really the correct way, as I thought that would then apply the profile twice?" Yes, this is correct. The 1D calibration will be applied system-wide in that case, which is why the 3D LUT must not include it (untick “Apply calibration (vcgt)” on the 3D LUT tab). Expand This implies monitor calibration will apply to Devinchi as well. Seems that if you do a separate 3D LUT calibration in resolve it will look a bit better according to him. So you are correct if you want flawless calibration. Another one from my new Z6. Nikon 24-70 2.8G wide open, lighting fill added from camera left. Emanuel and kye 2 Link to comment Share on other sites More sharing options...
Volumetrik Posted June 25, 2019 Share Posted June 25, 2019 On 6/22/2019 at 4:08 PM, KnightsFan said: @Volumetrik I use DisplayCal with a Spyder as well. Do you happen to use Resolve? Do you know the process to creating a color correction LUT from DisplayCal to use in Resolve? I am not particularly confident that I did it correctly. Expand I don't have experience with LUT creation in Resolve unfortunately. Link to comment Share on other sites More sharing options...
KnightsFan Posted June 25, 2019 Share Posted June 25, 2019 On 6/25/2019 at 1:42 PM, Volumetrik said: I don't have experience with LUT creation in Resolve unfortunately. Expand I meant making a LUT in DisplayCal so that the calibration is used in Resolve. AFAIK, the only system-wide calibration that software like displaycal can do is adjust the VCGT, which is gamma and doesn't effect color. So if you calibrate your monitor, you have to follow the steps in that wiki page I linked to earlier. However, it does seem that on Mac, Resolve uses the ICC profile and thus you don't have to go through those steps. I'm not completely sure, and probably a lot of my confusion is from reading contradictory information without realizing that the OS's behaved differently. On 6/23/2019 at 9:30 PM, Geoff CB said: This implies monitor calibration will apply to Devinchi as well. Seems that if you do a separate 3D LUT calibration in resolve it will look a bit better according to him. So you are correct if you want flawless calibration. Expand Thanks, I have since learned that on Mac, Resolve actually uses the system's ICC profile, and thus you wouldn't have to go through those extra steps. It's quite a big difference with the LUT and without, very noticeable on my system. The "1D LUT" he mentions is just a gamma adjustment, while the 3D LUT provides the same color adjustments as the ICC profile does for programs that use system color management. Link to comment Share on other sites More sharing options...
Super Members BTM_Pix Posted June 26, 2019 Super Members Share Posted June 26, 2019 A couple more from the 7Artisans 28mm f1.4 that I got the other week. meudig, Adept, Geoff_L and 2 others 5 Link to comment Share on other sites More sharing options...
mercer Posted June 26, 2019 Share Posted June 26, 2019 On 6/26/2019 at 7:34 PM, BTM_Pix said: A couple more from the 7Artisans 28mm f1.4 that I got the other week. Expand Love the mood. Are those stills or video frames? Link to comment Share on other sites More sharing options...
Super Members BTM_Pix Posted June 26, 2019 Super Members Share Posted June 26, 2019 On 6/26/2019 at 8:59 PM, mercer said: Love the mood. Are those stills or video frames? Expand Thanks. They're just jpegs off the SL as I only used the lens for about an hour after I got it before resuming holiday mode so today has been the first chance I've had to look at what I did with it so I was just pushing them to make a LUT with for when I do some video with it. I want to use it on the Pocket4K (or my newly acquired Micro ) but I don't know whether its just me but I don't seem to be getting much joy with M mount lenses on MFT. I picked up a dirt cheap A7Rii a few days previously to use with the TechArt to have a poor man's AF high res Leica M but only got chance to have this quick go with the 7Artisans 50mm f1.1, which I love on the SL, but the jury is out with it on the Sony although, again, I'm just pushing jpegs about so need to have closer look when I get more time. mercer and Geoff_L 2 Link to comment Share on other sites More sharing options...
mercer Posted June 26, 2019 Share Posted June 26, 2019 On 6/26/2019 at 9:26 PM, BTM_Pix said: want to use it on the Pocket4K (or my newly acquired Micro ) but I don't know whether its just me but I don't seem to be getting much joy with M mount lenses on MFT. Expand Yeah I’d be curious to see that lens on the P4K. Have you had a chance to use the Micro... or any inspiration/ideas for a grip? Link to comment Share on other sites More sharing options...
Super Members BTM_Pix Posted June 26, 2019 Super Members Share Posted June 26, 2019 On 6/26/2019 at 11:36 PM, mercer said: Have you had a chance to use the Micro... or any inspiration/ideas for a grip? Expand I'm waiting on a couple more parts to arrive next week but I've picked one of these cheap RC transmitters up as a starting point. You can connect the receiver to the Micro and assign controls to each channel of it so a full turn of the wheel will take the focus from near to far etc. This one has 3 channels (the wheel, the trigger and a switch) so probably looking at focus, aperture and record but I'll need to modify it to remove the springs so that the wheel and trigger don't return to the central point when you let go. Its more or less the same size as those cheap LANC handles so is size appropriate and will be quite neat to have a wireless control handle. mercer 1 Link to comment Share on other sites More sharing options...
kye Posted June 27, 2019 Share Posted June 27, 2019 On 6/26/2019 at 7:34 PM, BTM_Pix said: A couple more from the 7Artisans 28mm f1.4 that I got the other week. Expand Nice images!! You win the $150 challenge! oh, hang on... BTM_Pix and webrunner5 2 Link to comment Share on other sites More sharing options...
