Ninpo33 Posted March 20 Share Posted March 20 1 hour ago, John Matthews said: Yeah, I started collecting them too. Sometimes, you can find some great deals. So far, I have: 15mm fisheye 21mm f/2.8 28mm f/3.5 40mm f/1.8 50mm f/1.4 50mm f/1.7 (both versions) 57mm f/1.2 100mm f/2.8 135mm f/2.5 135mm f/3.2 200mm f/3.5 300mm f/4.5 I also have various zooms. For some reason I started to get really attracted to them, always looking for something a little different. With the exception of the 57mm, I got decent to amazing deals on them, often with working film bodies. The 28mm f/1.8 is one I'd also like to get. I got really lucky getting the 21mm as the person didn't know what they were selling. I told her what she had, offered her 2.5x what she was asking, and she decided to sell it to me rather some other person who was most certainly going to flip it. It's a nice sharp lens, but the build is more like a Tokina (the producer) than the 60-70's Konica-made lenses. I agree. One thing I've noticed about Konica lenses in general is that they often have grease problems. Due to the shorter flange, they missed the DSLR years, only being able to adapt to M-mount. I probably need to service most of them. Any suggestions for grease? Also, I've heard that declicking Konica lenses is a bad idea. Has anyone done that? I'm not really sure if I would, but I'd like to try on one. Oh yeah, sounds like you’re only missing a few. I also scored great deals by just waiting around until something reasonable came up. I refuse to spend top dollar on vintage glass when it can always be found cheap if you’re patient. I bid on a 21mm a couple of weeks ago that went for just about $500. Given that there’s a Tokina wide for much less out there I decided to let it go. The Konicas are only now starting to get some attention for video finally after the rehouse projects at Ancient Optics and Old Fast Glass. I’m working on a speedbooster project to mount on Fuji APS-C. Really tough because of the short flange distance but I found an ALPA speedbooster that works if I make a custom adapter. John Matthews 1 Link to comment Share on other sites More sharing options...
John Matthews Posted March 20 Share Posted March 20 10 minutes ago, Ninpo33 said: Oh yeah, sounds like you’re only missing a few. I also scored great deals by just waiting around until something reasonable came up. I refuse to spend top dollar on vintage glass when it can always be found cheap if you’re patient. I bid on a 21mm a couple of weeks ago that went for just about $500. Given that there’s a Tokina wide for much less out there I decided to let it go. The Konicas are only now starting to get some attention for video finally after the rehouse projects at Ancient Optics and Old Fast Glass. I’m working on a speedbooster project to mount on Fuji APS-C. Really tough because of the short flange distance but I found an ALPA speedbooster that works if I make a custom adapter. The only "problem" I've found with all vintage lenses is the coatings. If you look at footage taken with the 40mm and then the 50mm f/1.7, there are significant differences. If you use multiple focal lengths on the same shoot, you need to stay within the same generation of lenses. For example the 21mm, 40mm, and a newer zoom. Or, the 28mm, 50mm f/1.7 and 100mm, as they're made with similar coatings. I don't know how GL Optics gets away with that. The 57mm should probably only be used as a one and done lens as it's vastly different from all the other ones. Link to comment Share on other sites More sharing options...
Ninpo33 Posted March 20 Share Posted March 20 1 hour ago, John Matthews said: The only "problem" I've found with all vintage lenses is the coatings. If you look at footage taken with the 40mm and then the 50mm f/1.7, there are significant differences. If you use multiple focal lengths on the same shoot, you need to stay within the same generation of lenses. For example the 21mm, 40mm, and a newer zoom. Or, the 28mm, 50mm f/1.7 and 100mm, as they're made with similar coatings. I don't know how GL Optics gets away with that. The 57mm should probably only be used as a one and done lens as it's vastly different from all the other ones. I suppose it depends on a few things, namely how yellow your 57mm has become and yeah, not mixing the older single coated versions or even the second gen MC versions. I honestly haven't had any trouble with mixing all lenses from the newest gen and maybe only need to do a slight adjustment in post for really, really subtle color shifts. Have you thought about the UV light trick with your? I remember there was a cheap IKEA light that people were using for a while with nice results. I should look back into that because I have a few M42 Yashica and Mamiya lenses that could really use it. John Matthews 1 Link to comment Share on other sites More sharing options...
John Matthews Posted March 21 Share Posted March 21 17 hours ago, Ninpo33 said: honestly haven't had any trouble with mixing all lenses from the newest gen and maybe only need to do a slight adjustment in post for really, really subtle color shifts. Have you thought about the UV light trick with your? I remember there was a cheap IKEA light that people were using for a while with nice results. I should look back into that because I have a few M42 Yashica and Mamiya lenses that could really use it. That's good to hear. We are usually talking about 4k 10bit files in 2025 and they should have that kind of latitude. As for the 57mm f/1.2, I think you could just grey card it and it would be fine. I personally won't be trying to remove the yellowing. For me, that's just part of the charm. Ninpo33 1 Link to comment Share on other sites More sharing options...
maxJ4380 Posted March 21 Share Posted March 21 pardon my ignorance, wouldn't the yellowing add some kick to a sunrise / sunset? I guess that would make it a bit of a one trick pony. I have been thinking on and off about acquiring a "yellow" lens just for that particular reason. Ninpo33 and John Matthews 2 Link to comment Share on other sites More sharing options...
mercer Posted March 22 Share Posted March 22 Sorry for the repost but after second thought, I realized that this wasn't shot with the Super Takumar 50mm 1.4, it was actually shot with the Nikon Nikkor 28mm f/2 N.C. non-ai lens. I was using the Tak a lot last spring/summer, so I just assumed that was it, but the close up bothered me so I went back to my notes. Anyway, I didn't want to misrepresent the lens... maxJ4380, kye, Ninpo33 and 1 other 3 1 Link to comment Share on other sites More sharing options...
mercer Posted March 22 Share Posted March 22 Speaking of Nikkor non-ai lenses, I have a small set with the updated "c" coating, the 28mm f/2, 50mm 1.4 and the 105mm 2.5. All are in mint condition, but they could use a CLA. Those old non-ai Nikkor lens' focus lubricant dries up pretty good, and although the focus is smooth and holds, it doesn't have the same dampening as older Taks or Minoltas have. Anyway, can anyone recommend a lens tech in the US. I'm in the Philly area, so anywhere in the mid-Atlantic, northeast would work. John Matthews 1 Link to comment Share on other sites More sharing options...
maxJ4380 Posted March 23 Share Posted March 23 7 hours ago, mercer said: Anyway, can anyone recommend a lens tech in the US. I'm in the Philly area, so anywhere in the mid-Atlantic, northeast would work. finding good service people is getting harder and harder i reckon, if all else fails maybe one of those lens rehousing services could help. If their pulling a lens apart and machining parts, cleaning and lubing a lens should be a piece of cake, but maybe not cheap... would depend on how you value the lens as to whether it is worthwhile or not. Btw i like what you doing with the black and white images care to share a little of your processing / workflow? mercer 1 Link to comment Share on other sites More sharing options...
eatstoomuchjam Posted March 23 Share Posted March 23 8 hours ago, mercer said: Anyway, can anyone recommend a lens tech in the US. I'm in the Philly area, so anywhere in the mid-Atlantic, northeast would work. SK Grimes is one of the most famous lens technicians, though sadly is priced to match - located in Rhode Island. https://skgrimes.com/product/repair-services/ mercer 1 Link to comment Share on other sites More sharing options...
mercer Posted March 23 Share Posted March 23 16 hours ago, maxJ4380 said: finding good service people is getting harder and harder i reckon, if all else fails maybe one of those lens rehousing services could help. If their pulling a lens apart and machining parts, cleaning and lubing a lens should be a piece of cake, but maybe not cheap... would depend on how you value the lens as to whether it is worthwhile or not. Btw i like what you doing with the black and white images care to share a little of your processing / workflow? Thanks. I shoot raw video with either the 5D3 and Magic Lantern Raw or cDNG with the Sigma FP. Recently I've been treating their raw files as rec709 in Resolve's Camera Raw Tab and then after those basic adjustments, I use an S-Curve LUT, Log Wheels for micro adjustments and tweak the color channels in the RGB tab. Obviously, I'm going for a dark, moody image, but I have a horrible monitor so I'm never 100% sure what the final output looks like on other devices... Basically, I just tinker with it. One day I'll make a movie that will be constructed of the coolest b-roll shots I can take with the most dramatic lighting possible. I've yet to come up with an interesting plot for that film. maxJ4380 1 Link to comment Share on other sites More sharing options...
mercer Posted March 23 Share Posted March 23 Does anyone know the value of FD L series lenses? They ballooned years ago, and I was lucky enough to pick up a 50mm 1.2 L for a pretty decent price before they were compared to the K lenses. At the time I was only shooting video on the 5D3 and had it modded by Simmod to the EF mount and declicked. I didn't add a follow focus gear or a larger front ring since I pull focus from ring. I've checked eBay but the pricing seems to be all over the place. Link to comment Share on other sites More sharing options...
eatstoomuchjam Posted March 24 Share Posted March 24 16 hours ago, mercer said: Does anyone know the value of FD L series lenses? They ballooned years ago, and I was lucky enough to pick up a 50mm 1.2 L Assuming that you're talking about the price of the lens that you have, sold item search on ebay puts it between $700 and $1,000 depending on condition. I'd guess that the simmod mount swap would put you near the higher end of the range. mercer 1 Link to comment Share on other sites More sharing options...
mtol Posted March 31 Share Posted March 31 Can anyone recommend a lens tech in Montreal or Toronto Canada? For a Contax Zeiss 35 1.4 with an aperture issue and loose barrel. Link to comment Share on other sites More sharing options...
maxJ4380 Posted April 3 Share Posted April 3 On 3/24/2025 at 4:32 AM, mercer said: Basically, I just tinker with it. One day I'll make a movie that will be constructed of the coolest b-roll shots I can take with the most dramatic lighting possible. I've yet to come up with an interesting plot for that film. Do you really need a plot ? I have watched alot of stuff on netflix and i'm not so sure a plot is the main ingredient any more. Admittedly there's some good stuff on netlfix, but what the ratio of good to less than good is i'm not sure. Link to comment Share on other sites More sharing options...
mercer Posted Friday at 03:29 PM Share Posted Friday at 03:29 PM For the m4/3 shooters, Pan/Leica 15mm 1.7 or Sigma 16mm 1.4? PannySVHS 1 Link to comment Share on other sites More sharing options...
Framed_By_Dan Posted Friday at 06:29 PM Share Posted Friday at 06:29 PM 2 hours ago, mercer said: For the m4/3 shooters, Pan/Leica 15mm 1.7 or Sigma 16mm 1.4? 15mm f1.7. The Sigma is much bigger and heavier which of course can be good for stability however it suffers badly with focus breathing apparently. Plenty of reviews out there comparing the two. PannySVHS and mercer 1 1 Link to comment Share on other sites More sharing options...
PannySVHS Posted Friday at 08:16 PM Share Posted Friday at 08:16 PM I've been thinking about the 15mm Panny Leica for a while. It's a pretty looking lens. I am very happy with my 14mm pancake though, which is an awesome little lens on my GX85 and my og pocket. The 15mm has about 1 stop more light gathering in comparison. If it had a clutch mechanism for hard stops in MF like the Oly 12 and 17mm, it would be hard to resist for me. There is also a cheaper Dji branded variante out there which came with Dji's mft raw recording gimbal camera. What would speak for the Sigma over the Leica? Maybe the big focus ring and ultimate image quality? Though I imagine the Panny Leica is no slouch in the image department. What camera would you mount your lens of choice to? Did I read something about a GH6 or GH7? Maybe big lens for a big camera then?:) @mercer mercer 1 Link to comment Share on other sites More sharing options...
mtol Posted Friday at 08:53 PM Share Posted Friday at 08:53 PM 5 hours ago, mercer said: For the m4/3 shooters, Pan/Leica 15mm 1.7 or Sigma 16mm 1.4? I have some experience with the 15 1.7 and while its sharp and tiny with nice color rendition I think it's best as a kind of point and shoot lens for the system. It's nice enough but I wouldn't use it for serious video work - it lacks good manual controls and character. No comment on the Sigma, but my highest recommendations for the Voigtlander 17.5mm f0.95 if you're looking in that focal range. Tons of character wide open, tack sharp stopped down, incredible ergonomics and manual control. mercer 1 Link to comment Share on other sites More sharing options...
