mercer Posted October 13, 2015 Share Posted October 13, 2015 Nope. It was sad when he didn't know any better and the seller led him to believe it would work on his t2i.From that point on he received well informed advice, but he still wanted to give it a shot... Okay youth and all.It was then sad again when he received the lens and it didn't work.At that point, he should have just returned the lens... eBay has such a liberal return policy.But not sad anymore when he decided to take a screw driver to the thing, and other lenses, and attempt to create a Frankenlens.If he was paying attention earlier, he would have known that the mount had nothing to do with it not working.And then, assuming he was able to reassemble the lens, he went and told the seller he disassembled it... He probably wrote it in an email as well.I'm sure when he talked to him, the guy was grinning ear to ear, and ended the call quickly.So, what's the next best bet... he seeks out an optical engineer...I don't mean to be hard on the kid... I really don't, but this is getting ridiculous. And if he would show a little humility when he converses with people and an open mind, he wouldn't be in this predicament and he could be sitting pretty with a brand new BMPCC. Link to comment Share on other sites More sharing options...
mercer Posted October 13, 2015 Share Posted October 13, 2015 Honestly, I'm not here to dissect how your mind works. I wish you good luck with this lens, and that whole college thing, and maybe there was a good lesson learned. Life isn't about the mistakes you make, it's about how you react towards your mistakes. Link to comment Share on other sites More sharing options...
jgharding Posted October 16, 2015 Share Posted October 16, 2015 Listening is a far rarer skill than shouting, ya get me?Good money after bad does not undo a mistake... Admitting defeat can sometimes lead to a better place than the original goal...fortune cookie sometimes to hard for young teeth... Nikkor 1 Link to comment Share on other sites More sharing options...
richg101 Posted October 16, 2015 Share Posted October 16, 2015 So have you destroyed that k35 zoom?if it has been focal reduced it means it might be straightforward to revert it into something that covers s35mm, but even then i expect your camera will have mirror issues since the lens probably isnt retrofocus and will probably need to seated deep into the mirror box for infinity. post some pics! Link to comment Share on other sites More sharing options...
mercer Posted October 16, 2015 Share Posted October 16, 2015 So have you destroyed that k35 zoom?if it has been focal reduced it means it might be straightforward to revert it into something that covers s35mm, but even then i expect your camera will have mirror issues since the lens probably isnt retrofocus and will probably need to seated deep into the mirror box for infinity. post some pics! I was going to suggest he speak with you, but I didn't want to volunteer you for something. Quick question though, I recently declicked a zeiss Jena 50mm, the newer black version and it was pretty straightforward. After that success, I attempted to declick an older version that had a spring system. I was able to fix the aperture but not declick it. I recently picked up the zebra 20mm f4 for a steal, but the aperture doesn't work. I don't want to take the mount off and have the spring pop, if there is one, do you know? Link to comment Share on other sites More sharing options...
richg101 Posted October 17, 2015 Share Posted October 17, 2015 I have not focused on it now.don't give up on it. it may be possible to fix, but some pics of the lens will be helpful for us to advise. I was going to suggest he speak with you, but I didn't want to volunteer you for something. Quick question though, I recently declicked a zeiss Jena 50mm, the newer black version and it was pretty straightforward. After that success, I attempted to declick an older version that had a spring system. I was able to fix the aperture but not declick it. I recently picked up the zebra 20mm f4 for a steal, but the aperture doesn't work. I don't want to take the mount off and have the spring pop, if there is one, do you know? Unfortunately I have never worked on these lenses.but i'd suggest going back to the previous one you dismantled and relook at it. the spring is simply to engage/disengage the aperture ring pin for the auto diaphram. try playing around with a toothpick to decipher what is doing what. with your 20mm it's likely a lever just needs to be fixed in place to engage the aperture ring. I imagine oil has dried up in the auto mechanism and as such the spring inside doesnt have enough strength to pull it to the right place. mercer 1 Link to comment Share on other sites More sharing options...
mercer Posted October 17, 2015 Share Posted October 17, 2015 don't give up on it. it may be possible to fix, but some pics of the lens will be helpful for us to advise. Unfortunately I have never worked on these lenses.but i'd suggest going back to the previous one you dismantled and relook at it. the spring is simply to engage/disengage the aperture ring pin for the auto diaphram. try playing around with a toothpick to decipher what is doing what. with your 20mm it's likely a lever just needs to be fixed in place to engage the aperture ring. I imagine oil has dried up in the auto mechanism and as such the spring inside doesnt have enough strength to pull it to the right place. Thanks, yeah that is how I fixed the aperture on the older model, just fixing the lever in place. I think I had to take out a part that was used for the auto/manual functioning of the lens. The newer all black models are an entirely different design, instead of a spring, it uses a switch. The older models were actually a more complicated design. The zebra model is an in between version, hopefully it's the easier one. I am a mechanically inclined person, but I always get a little nervous opening up a lens.Anyway...Thanks again. Link to comment Share on other sites More sharing options...
richg101 Posted October 17, 2015 Share Posted October 17, 2015 Thanks, yeah that is how I fixed the aperture on the older model, just fixing the lever in place. I think I had to take out a part that was used for the auto/manual functioning of the lens. The newer all black models are an entirely different design, instead of a spring, it uses a switch. The older models were actually a more complicated design. The zebra model is an in between version, hopefully it's the easier one. I am a mechanically inclined person, but I always get a little nervous opening up a lens.Anyway...Thanks again. there's very little that can go wrong. all that's likely to happen is that you'll never be able to restore the auto diaphram function, something not used in the scope of our profession Link to comment Share on other sites More sharing options...
mercer Posted October 17, 2015 Share Posted October 17, 2015 there's very little that can go wrong. all that's likely to happen is that you'll never be able to restore the auto diaphram function, something not used in the scope of our professionThat makes sense, do you know if cleaning and relubricating focus rings are difficult? On my 35mm zeiss, the focus is a little rough... Specifically in one spot it hangs up. I know you said you never worked on these lenses, but I'd imagine cleaning focus helicoids are similar, no matter the make of lens? Link to comment Share on other sites More sharing options...
Super Members Mattias Burling Posted October 28, 2015 Super Members Share Posted October 28, 2015 Got ripped off, can't return it because I disassembled it, even though I put it back together. Now he keeps my fucking $1535. Well I hope you are happy you piece of shit Ebay seller with my money.save untill you can buy a bmpcc, g7 or similar. Link to comment Share on other sites More sharing options...
Cinegain Posted October 28, 2015 Share Posted October 28, 2015 Can't really be blaming him now... you're grown up enough, time to start taking your losses like an adult. You took a risk, then pushed your luck even a little further, and now that it's coming back to bite you, you're dumbfounded. It's in the past, bud, can't do much about it now. What you're left to do with is figuring out how to put it to use now. Focus on that.Take the advice some of us already offered, manage to somehow get yourself a BMPCC, T3i (I believe it could be put to C-mount crop?), G7 or so. You'd be doing yourself two favors. Getting yourself a camera that works with the lens you visioned having... and the camera is a probably a definit upgrade from the T2i... there's still future for what you said out to do... just takes a bit more effort than anticipated.Anyways, we all make mistakes, it's part of life really, take something away from it and use it for good in any future endavours. Maybe the lesson here is before jumping to any quick weighty decisions, first explore your options, take your time rather than thinking of all the 'pros' to find the 'cons' instead, rationalize and sleep on it, get others with experience and an objective look to weigh in on the situation... then you can make a deliberate decision.Don't want to fall? Don't take these huge impulsive leap of faiths... And if you do... brush off your shoulders and get up at it again! Zach Goodwin 1 Link to comment Share on other sites More sharing options...
mercer Posted October 29, 2015 Share Posted October 29, 2015 Got ripped off, can't return it because I disassembled it, even though I put it back together. Now he keeps my fucking $1535. Well I hope you are happy you piece of shit Ebay seller with my money.Did he ever tell you, before you bought it, that it would work on your t2i? Link to comment Share on other sites More sharing options...
Nikkor Posted October 29, 2015 Share Posted October 29, 2015 I disassembled it, and as a result can not return it... At all... look if you want it I will gladly ship it to you.Oh ok, my english is so bad I thought "getting ripped off" was an expression used to describe something they do to you, not something you are. Link to comment Share on other sites More sharing options...
Super Members Mattias Burling Posted November 4, 2015 Super Members Share Posted November 4, 2015 Ive been wanting one of these for a long time but never had the opportunity to get one.But today was my lucky day! Only shot a few seconds with it and fell instantly in love. Cinegain 1 Link to comment Share on other sites More sharing options...
Cinegain Posted November 4, 2015 Share Posted November 4, 2015 With 'the oppertunity' you mean 'it was never around at an acceptable price'? Return of the swirly bokeh! The inserts are cute. But to be honest, personally I think I'd rather have some vintage Russians and a tailored DSO 58mm! But I'm sure it's pretty great! Link to comment Share on other sites More sharing options...
Super Members Mattias Burling Posted November 5, 2015 Super Members Share Posted November 5, 2015 With 'the oppertunity' you mean 'it was never around at an acceptable price'? Return of the swirly bokeh! The inserts are cute. But to be honest, personally I think I'd rather have some vintage Russians and a tailored DSO 58mm! But I'm sure it's pretty great!It was more the lack of a Full Frame that keept me from it. Isnt much of a point to use it on smaller.I have bought vintage glass than most so I see where you are coming from. But yeah, it is great. Its one of those "have to try to get" sort of things. Not for everyone of course. Link to comment Share on other sites More sharing options...
jonpais Posted November 5, 2015 Share Posted November 5, 2015 First reviews of the Samyang/Rokinon 50mm f/1.2 APS-C manual focus lens are in and they're extremely positive - even going so far as to claim it bests the Sigma 50mm f/1.4. The Sigma is lovely, but the short focus throw makes it difficult to pull focus in video. Link to comment Share on other sites More sharing options...
Clive Posted November 9, 2015 Share Posted November 9, 2015 Anyone got any thoughts on the samyang 14mm cine on a GH3 thus getting a 28mm equivalent? Link to comment Share on other sites More sharing options...
BrorSvensson Posted November 9, 2015 Share Posted November 9, 2015 Anyone got any thoughts on the samyang 14mm cine on a GH3 thus getting a 28mm equivalent?not worth the huge size and the distortion is horrible on it. Clive 1 Link to comment Share on other sites More sharing options...
Clive Posted November 9, 2015 Share Posted November 9, 2015 Thanks for the info Bror. Much appreciated. Link to comment Share on other sites More sharing options...
