Two new Canon lenses - Wide angle zooms
Guest Ebrahim Saadawi
Canon just released two exciting ultra wide-angle zoom lenses,
- 10-18mm f/4.5-5.6 IS STM
- 16-35mm f/4 IS L
____________________
The 10-18mm is desinged for APS-C sized sensors, (or S35), thus fits Canon EF-S bodies including the C100/300
It has 4 stops of Image stabilization, and the new STM technology which means it's perfect for the Dual-pixel AF cameras. (IS and AF and Ultrawide are a perfect combination for glidecam, Movi kind of use)
All that for 299$ (!)
Important thing to keep in mind though, it ends at 18mm because it's made to be a companion to the 18-55mm kit lens, and the 55-250mm kit lens, therefore, it is a kit lens.
It will have similar build quality, weight and size as the 18-55mm kit lens, which is not bad by itself, but plasticy and fiddly compared to L lenses. I've used it and if you treat her with care, it's excellent optically and does the job for almost no money. So I see no reason not to have this 10-18mm in your kit even as a backup.
Exciting lens for those on a budget.
________________________
16-35mm f/4 IS
This one of course is designed for full-frame sensors, so it will fit both EF and EF-S bodies. Canon does have a non-stabilized 2.8 version, but this one will have the advantage of 4 stops of stabilization, and according to MTF charts, it's a much better performer in terms of IQ to nearly all other lenses. It has L build quality of course and will survive the beating.
It will sell for 1199$, which is a good price too.
What do you thing of these?
