Gonzalo Ezcurra Posted May 21, 2014 Share Posted May 21, 2014 ae4cc3f54d35c9bcfee67b45e02df94f Christina Ava 1 Link to comment Share on other sites More sharing options...
Julian Posted May 21, 2014 Share Posted May 21, 2014 Hey Gonzola, Cool to have you here! I've seen the videos before. I love the third one, the dof is insane! If 500mm = 50mm equivalent, the 360mm f/4.8 is like a 36mm f/0.48 on a fullframe camera! Link to comment Share on other sites More sharing options...
Gonzalo Ezcurra Posted May 21, 2014 Author Share Posted May 21, 2014 Hi Julian, Thank you! I am still in experimental stage, soon I will show images on 14x14 " "sensor" size MiniCyclops with EPIC RED DRAGON as capture camera. No, the f/stop or F/D is maintained: 360mm f/4.8 (in MiniCyclops) is like a 36mm f/4.8 in Full Frame Link to comment Share on other sites More sharing options...
Julian Posted May 21, 2014 Share Posted May 21, 2014 I get that the f stop is maintained, as in the lens will gather the same amount of light, but the depth of field will compare to a 36mm f/0.48 on fullframe. Just like a 12-35mm f/2.8 on micro four thirds gives the dof equivalent of a 24-70mm f/5.6 on fullframe, etc. You can easily see that in your video's. Doesn't 'look' like f/4.8 or f/6, does it :) Link to comment Share on other sites More sharing options...
Gonzalo Ezcurra Posted May 21, 2014 Author Share Posted May 21, 2014 Exactly! it's really terrifying the critical focus. Seen from that point and geometric standpoint, it is. But photometrically keeping the F/Stop... Link to comment Share on other sites More sharing options...
Nikkor Posted May 21, 2014 Share Posted May 21, 2014 I can't see the difference to a m43, hahaha, great project.I hope we can see some street shots anytime soon! Link to comment Share on other sites More sharing options...
Gonzalo Ezcurra Posted May 23, 2014 Author Share Posted May 23, 2014 (y) Link to comment Share on other sites More sharing options...
Guest Ebrahim Saadawi Posted May 24, 2014 Share Posted May 24, 2014 I feel sorry for all focus pullers out there. While we -Directors and cinematographers- are lusting over larger sensors, they are the ones paying for it :D Seriously though, this look is awesome. I love this! Hoping to see more footage soon Link to comment Share on other sites More sharing options...
Gonzalo Ezcurra Posted May 26, 2014 Author Share Posted May 26, 2014 Thanks Ebrahim, Soon I'll upload new material. Link to comment Share on other sites More sharing options...
Gonzalo Ezcurra Posted May 31, 2014 Author Share Posted May 31, 2014 New street pedestal to MiniCylops: '' target='_blank'>> '' target='_blank'>> '' target='_blank'>> '' target='_blank'>> janosch simon and richg101 2 Link to comment Share on other sites More sharing options...
Gonzalo Ezcurra Posted June 17, 2014 Author Share Posted June 17, 2014 First Outdoors Test - MiniCyclops - 14x14 inches "sensor" size camera. Christina Ava, janosch simon and dahlfors 3 Link to comment Share on other sites More sharing options...
Gonzalo Ezcurra Posted June 19, 2014 Author Share Posted June 19, 2014 "Making of" MiniCyclops - First Outdoors Test (14x14 inches "sensor" size Motion Camera) janosch simon 1 Link to comment Share on other sites More sharing options...
dahlfors Posted June 20, 2014 Share Posted June 20, 2014 I can't help but smile when I see that huge setup :) Awesome results, looks wonderful! Link to comment Share on other sites More sharing options...
Wulf Posted June 20, 2014 Share Posted June 20, 2014 some of the shoots looking f' gorgious, really 3D like. Whatever you are doing there, you have the right eye for proportions Link to comment Share on other sites More sharing options...
Gonzalo Ezcurra Posted December 2, 2015 Author Share Posted December 2, 2015 Second Quick Test ECyclops 20x20 inches "sensor" size digital motion camera.Sony A7S + Shogun Capture Camera1942 Epidiascope Zenith Optical Co. Tessar 616mm f6 (wide open) -4 elements in 3 groups, bakelite lens body-2x 6 tube Kino + 1x 1K FresnelSlightly grading."One-person film crew", with makeup and costumes that assisted the model. kaylee and tupp 2 Link to comment Share on other sites More sharing options...
tupp Posted December 2, 2015 Share Posted December 2, 2015 @Gonzalo EzcurraThis rig is great! I hope you keep shooting with it and keep posting videos. Somehow, I missed your May 2014 post showing the "street" version. Did you remove the motorization? By the way, have you ever played around with the swing/tilt on the Omega View stage? Link to comment Share on other sites More sharing options...
Gonzalo Ezcurra Posted May 31, 2016 Author Share Posted May 31, 2016 Hi, Tupp Yes, you can make "Swing / Tilt / Shift" movement, thanks to the OmegaViwe head, but the image circles I use lenses are tight and do not spare much image to play tupp 1 Link to comment Share on other sites More sharing options...
tupp Posted May 31, 2016 Share Posted May 31, 2016 Gonzalo, Thank you for the reply! I guess that quite a few of the extra-large format photography lenses were not designed for extreme swing/tilts. On the other hand, it might be possible to find a cheap lens from one of the old, huge, graphics stat/process cameras that would allow much more play, and also have a larger maximum aperture. By the way, there has been a long-running debate here on whether or not there is a difference in "look" between large formats and smaller formats. Have you found any differences in look between your Cyclops rigs and smaller cameras? If so, please explain the differences that you see. Thanks! Link to comment Share on other sites More sharing options...
Gonzalo Ezcurra Posted May 31, 2016 Author Share Posted May 31, 2016 I notice that the ground glass makes as a buffer high and low lights, such as expanding the dynamic range, as well as having other image structure, that gives me the feeling more 3D Pop, regardless of the depth of field is most evident . tupp 1 Link to comment Share on other sites More sharing options...
tupp Posted May 31, 2016 Share Posted May 31, 2016 Thank you for the first-hand insight into the distinctiveness of the Cyclops' look. Perhaps the "buffer" in the highlights is similar to the "glow" that many enjoyed with 35mm DOF adapters. It certainly would be interesting to see a side-by-side DOF/look comparison test between a Cyclops and a much smaller format camera (such as a BMPCC, a BMMCC or a Digital Bolex). A test of such dramatically different formats might finally settle the DOF/look argument. Link to comment Share on other sites More sharing options...
