BMCC or Sony FS700
TIAN
If you use the computer, you'll be limited by your port speed (in this case, USB 2.0).  If you can't snag more 7Q SSDs, or get a computer with Thunderbolt/USB3.0/eSata, you could try a stand alone drive duplicator like this: http://tinyurl.com/md2yfnu
I haven't tested a duplicator with the 7Q SSDs personally, but theoretically it should work.  Reviews seem to indicate most of the sub $100 duplicators can go around two to three times faster than USB 2.0.  Just remember, assuming it would work, it would fully duplicate the 7Q drive, so you'd need one extra disk for every 7Q SSD you want to copy (but, these could cheaper mechanical drives or non-CD SSDs).
Exciting, we're about to record some shots, but was wondering bout 1 thing. You recommend 24fps, but as we live in a 50hz country and we will use tungsten and ac powered LED's wouldn't we risk flicker in our shots? Or is it also possible to shoot 240fps instead of 200fps when recordinf in 50hz?
