Relation Between Zerbas And Luminance Levels
WideEyedPictures
I was curious what the zebra levels (both 80% and 100%) represented depending on the different luminance levels you have set.
For example, if you're using the 0-255 luminance level setting, does the 100% zebra represent whites that are 255? Does the 80% zebra represent white that are at 204?
Thank you!
