boxtree Posted June 27, 2014 Share Posted June 27, 2014 Hi, I live in the UK where we don't see much sun :) so my questions is do I still need one if not shooting in bright sun light all the the time. Also my brightest lens currently is the Panasonic 12-35 2.8 so again would I need one with shutter at 1/50. Lastly is their ever a need to use a variable ND indoors or is it strictly for bight sunlight? All words of wisdom greatly appreciated. G. earnesync 1 Link to comment Share on other sites More sharing options...
Bob Wall Posted June 27, 2014 Share Posted June 27, 2014 It gets used anytime the amount of light coming into the lens is greater than the ISO and aperture you want to be at. Link to comment Share on other sites More sharing options...
Nick Hughes Posted June 27, 2014 Share Posted June 27, 2014 Unless you're using some powerful lighting, I don't see much use for an ND indoors (for video at least). A good variable ND can be quite expensive, so it might be worth picking up a cheaper 1, 2 or 3 stop ND and see if it benefits your work. Link to comment Share on other sites More sharing options...
fuzzynormal Posted June 27, 2014 Share Posted June 27, 2014 I find that 2 ND filters (rated @ 0.9 and 1.8) get me through just about any situation. A 1.8 (or x64) would be close to on target for daylight sunlight at 2.8, 200ISO, and 50fps. The .9 gets the exposure on point for overcast days. Link to comment Share on other sites More sharing options...
Inazuma Posted June 27, 2014 Share Posted June 27, 2014 I use a Hama variable ND which you can pick up for about £25. They are indespensible because otherwise you'll have to be shooting at f16+ outdoors. In fact sometimes I also place an ND4 filter behind the variable ND. On the other hand, some vintage lenses give quite a nice look despite using narrow apertures. Link to comment Share on other sites More sharing options...
HurtinMinorKey Posted June 27, 2014 Share Posted June 27, 2014 Shooting in bright sunlight I always slap a 1.2 on. Sometimes i'll go to the 2.0 if i really want to open up the lens. I think variable NDs are more important if you are shooting live events. Link to comment Share on other sites More sharing options...
Shane Essary Posted June 27, 2014 Share Posted June 27, 2014 Outdoors, I don't go anywhere without my Genus Variable ND. Indoors, I generally remove it if its convenient to do so. Link to comment Share on other sites More sharing options...
andy lee Posted June 27, 2014 Share Posted June 27, 2014 Tiffen NDs are the best at a good price , they are superb I use them all the time .(They where used on Need for Speed and Act of Valor movies by Shane Hurlbut) get ND 2, 4, 8 and 16 and stack them to get the exposure you need I never shoot outside without NDs , and I often shoot outside in bright daylight at f1.7 using Tiffen NDs I NEVER use a vari ND as they give odd results including artifacts , rainbow fringing , wierd flares etc and I just do not like what they do to your images. a vari ND is basically 2 polarizers stacked and rotated together (you can make one easily cheaply yourself this way if you so wish!) stick to normal NDs and you cant go wrong. Yes I do use NDs inside on set if Im shooting wide open and need to knock down the exposure to keep a narrow DOF. Tiffen NDs for digital cameras http://www.tiffen.com/press_release_hv_filter_kits.html jonpais 1 Link to comment Share on other sites More sharing options...
varicam Posted June 27, 2014 Share Posted June 27, 2014 I have just got a Tiffen variable ND filter and it seems ok so far. Indispensable when shooting outdoors. Link to comment Share on other sites More sharing options...
jonpais Posted June 28, 2014 Share Posted June 28, 2014 I also almost always use ND filters outdoors, sunny or no. I like the Tiffen kit, which cost around $40 USD. I mostly use the .9 filter I believe. Link to comment Share on other sites More sharing options...
Christina Ava Posted June 28, 2014 Share Posted June 28, 2014 i have the tiffen VND, cant go anywhere without it since its always sunny here, the uk has a permanent natural ND if you look up as i recall from my student years, with the exception of the south, if i was in the UK I would try the Digital Filter from Heliopan instead of the ND http://www.bhphotovideo.com/c/product/156804-REG/Heliopan_707786_77mm_Digital_Glass_Filter.html for the overcast days and a cheaper ND for the sunny days... Link to comment Share on other sites More sharing options...
Damphousse Posted June 28, 2014 Share Posted June 28, 2014 Hi, I live in the UK where we don't see much sun :) so my questions is do I still need one if not shooting in bright sun light all the the time. Also my brightest lens currently is the Panasonic 12-35 2.8 so again would I need one with shutter at 1/50. Lastly is their ever a need to use a variable ND indoors or is it strictly for bight sunlight? All words of wisdom greatly appreciated. G. Everyone is going the wrong way about telling you what to do. The best solution is figure it out yourself. I shoot film sometimes for photography. To this day film photographers even the ones that use $5,000 cameras use hand held light meters. Frankly every once in awhile I walk around with one in my pocket. Why? Because I am not that good of a photographer so I don't have an automatic feel for light levels. So I walk around with a light meter and get an idea what apeture I will be shooting at with different ISO film and different filters. Unlike digital cameras filters can do a lot for B&W film photography. So with different ISO films, different lighting conditions, and multiple different filters you have to understand the relationship between apeture, ISO, shutter speed and lighting conditions. One thing no one has mentioned is most lenses are only optimal under a narrow set of apetures. I use f/16 and very rarely f/22 sometimes on an aps-c sensors but that is only for specialized situations. And the size of the photosites on a camera matter as well. The smaller the photosites the sooner the image becomes diffraction limited as you stop down. So if you take a small m43 sensor with a bunch of photosites and compare it to a 5D MK III with bigger photosites it will get diffraction limited sooner. So technically on an overcast day you may be able to come up with some apeture, ISO, shutter speed combination that works for getting exposure but you will probably get a soft image on a lot of days. So even in the UK with overcast skies you can end up with... -Suboptimal technical use of apetures due to using f/16 and f/22 -Creative constraints disallowing shallow depth of field Please review Fred Parker's Ultimate Exposure Computer. You can pick your lighting conditions, your ISO, and your shutter speed and it will tell you what your apeture will be. Based on a heavy over cast sky (12), ISO 100, and a shutter speed slower than 1/60 I determined that your apeture would have to be beyond f/8. So on a high megapixel m43 camera you are already into diffraction territory. And that is with a HEAVY overcast sky. If you have a bright overcast sky you are beyond f/11. So image softness and gigantic depth of field. You will have to wait for sunrise or sunset to use your lens/camera combination at it's optimal settings if no ND filter is put in place. And againg if you look at the exposure computer you will see that for indoor use you don't need an ND filter. Most of the time you have the opposite problem indoors. You are using f/1.4 lenses and battling with depth of field just wishing you could stop down a bit but you're afraid of bumping up the ISO. Link to comment Share on other sites More sharing options...
lafilm Posted June 28, 2014 Share Posted June 28, 2014 Heliopan is much superior in my opinion. More expensive but worth it in the long run. Link to comment Share on other sites More sharing options...
dahlfors Posted June 29, 2014 Share Posted June 29, 2014 I NEVER use a vari ND as they give odd results including artifacts , rainbow fringing , wierd flares etc and I just do not like what they do to your images. a vari ND is basically 2 polarizers stacked and rotated together (you can make one easily cheaply yourself this way if you so wish!) +1 I had a Lightcraft Fader ND MK II which has gotten positive reviews. I still prefer standard ND's a lot more than that one. andy lee 1 Link to comment Share on other sites More sharing options...
jonpais Posted June 29, 2014 Share Posted June 29, 2014 Everyone is going the wrong way about telling you what to do. The best solution is figure it out yourself. I shoot film sometimes for photography. To this day film photographers even the ones that use $5,000 cameras use hand held light meters. Frankly every once in awhile I walk around with one in my pocket. Why? Because I am not that good of a photographer so I don't have an automatic feel for light levels. So I walk around with a light meter and get an idea what apeture I will be shooting at with different ISO film and different filters. Unlike digital cameras filters can do a lot for B&W film photography. So with different ISO films, different lighting conditions, and multiple different filters you have to understand the relationship between apeture, ISO, shutter speed and lighting conditions. One thing no one has mentioned is most lenses are only optimal under a narrow set of apetures. I use f/16 and very rarely f/22 sometimes on an aps-c sensors but that is only for specialized situations. And the size of the photosites on a camera matter as well. The smaller the photosites the sooner the image becomes diffraction limited as you stop down. So if you take a small m43 sensor with a bunch of photosites and compare it to a 5D MK III with bigger photosites it will get diffraction limited sooner. So technically on an overcast day you may be able to come up with some apeture, ISO, shutter speed combination that works for getting exposure but you will probably get a soft image on a lot of days. So even in the UK with overcast skies you can end up with... -Suboptimal technical use of apetures due to using f/16 and f/22 -Creative constraints disallowing shallow depth of field Please review Fred Parker's Ultimate Exposure Computer. You can pick your lighting conditions, your ISO, and your shutter speed and it will tell you what your apeture will be. Based on a heavy over cast sky (12), ISO 100, and a shutter speed slower than 1/60 I determined that your apeture would have to be beyond f/8. So on a high megapixel m43 camera you are already into diffraction territory. And that is with a HEAVY overcast sky. If you have a bright overcast sky you are beyond f/11. So image softness and gigantic depth of field. You will have to wait for sunrise or sunset to use your lens/camera combination at it's optimal settings if no ND filter is put in place. And againg if you look at the exposure computer you will see that for indoor use you don't need an ND filter. Most of the time you have the opposite problem indoors. You are using f/1.4 lenses and battling with depth of field just wishing you could stop down a bit but you're afraid of bumping up the ISO. Everyone else in this thread may be wrong, but I find this answer just a wee bit confusing :| Can't we just say that to avoid diffraction issues, avoid the smallest lens apertures or wait for the light to change? Link to comment Share on other sites More sharing options...
Damphousse Posted June 29, 2014 Share Posted June 29, 2014 Everyone else in this thread may be wrong, but I find this answer just a wee bit confusing :| Can't we just say that to avoid diffraction issues, avoid the smallest lens apertures or wait for the light to change? Everyone in this thread is most certianly not wrong. I 100% agree with the conclusions reached by most people posting. I just wanted to give anyone stumbling on this thread a reason for why these things are an issue and the tools to figure your their needs on their own instead of turning this into a faith based initiative. What I wrote was verbose and lacked a degree of clarity. That is a valid complaint. I have found the Exposure Computer invaluvable because it doesn't involve any gear and it doesn't involved traveling anywhere. You can sit at your desk and figure out exactly what you need. No one has to tell you. If you know the basics of photography or videography a lot of questions are answered before you even ask them. Link to comment Share on other sites More sharing options...
64mulford Posted June 29, 2014 Share Posted June 29, 2014 I have both marumi and light craft vari nd's. Couldnt shoot without them but sometimes results are mixed. Link to comment Share on other sites More sharing options...
jonpais Posted June 29, 2014 Share Posted June 29, 2014 I have both marumi and light craft vari nd's. Couldnt shoot without them but sometimes results are mixed. In what way are the results mixed? Link to comment Share on other sites More sharing options...
jgharding Posted June 30, 2014 Share Posted June 30, 2014 Vari NDs are all-right a lot of the time if you want speed, though they can create funny artefacts. I have cheap Polaroid ones, and I don't mind em. Colour temperatures goes cool one way and warm the other though, but it's a quick way to expose in bright light, just sticking setting the same and twisting the ND! Fixed-value NDs are better for quality though, if you're not shooting run-and-gun. The shot at 3:09 here is me twisting a vari ND up and down on 550D, so it can be used for special effects: Link to comment Share on other sites More sharing options...
itimjim Posted June 30, 2014 Share Posted June 30, 2014 Based on the opinions of a lot of people over at bmcuser, the Tiffen VariND can be a poor chice for some cameras and generally a bit muddy. The BMCs have a lot of problems with IR. Heliopan are held in high regard. I currently use Formatt Hitec multistop on my GH2 with good results. Not tested enough on the BMCC yet. Link to comment Share on other sites More sharing options...
