Germy1979 Posted June 28, 2014 Share Posted June 28, 2014 Hello! The ML Forum is a maze of posts. Forgive me if this has been ask before.. (although it's a shame I feel like I have to apologize for asking anymore for all the forum attitudes..) -I thought somebody here would be friendly enough to give me an update on where the progress of in-cam playback is on a 5D3 with raw. I seriously want to shoot our film this fall with it for the fact that it's image is spectacular even with the new options out there. The only problem is not knowing if we nailed the take I want until it's transcoded at the end of the day. That's rough. Thanks guys in advance! I really appreciate it Link to comment Share on other sites More sharing options...
andrgl Posted June 28, 2014 Share Posted June 28, 2014 Fairly certain this is possible on the 5D3. (I've used ML/TL on an EOS-M.)It works via a plugin that you have to enable. It gives you a rough file-browser you can use to select, view and delete raw sequences. Link to comment Share on other sites More sharing options...
QuickHitRecord Posted June 28, 2014 Share Posted June 28, 2014 I'm using a build from February, and it has a module called 'MLV_PLAY' that allows me to review shots, though not quite in real time. Not sure if this has progressed since then. I haven't upgraded though because everything has been working perfectly. Link to comment Share on other sites More sharing options...
andrgl Posted June 28, 2014 Share Posted June 28, 2014 I'm using a build from February, and it has a module called 'MLV_PLAY' that allows me to review shots, though not quite in real time. Not sure if this has progressed since then. I haven't upgraded though because everything has been working perfectly.Does it output via HDMI? I never tried with my eos-m.If it does, the less than real time playback isn't such a big deal. Link to comment Share on other sites More sharing options...
