popalock Posted May 16, 2012 Share Posted May 16, 2012 I'm shooting in 3 hour blocks (in 45min intervals) and swapping batteries from my GH2, but having been connected to a tripod is proving a total b!tch. So I'm looking for options which would be either an extended battery pack OR a much easier way to QUICKLY swap out batteries while being connected to a tripod Any ideas? I've found this [url=http://dolgin.net/zen_dolgin/index.php?main_page=product_info&cPath=18&products_id=99][b][i]extended GH2 battery plate[/i][/b][/url] but it's not particularly cheap + I'll have to think about where to mount it(and so opens the door to more problems) Link to comment Share on other sites More sharing options...
booneypants Posted May 20, 2012 Share Posted May 20, 2012 This battery grip looks pretty cool for a china product: http://www.ebay.com/itm/Ownuser-Battery-Grip-MIG-PGH2RAB-for-Panasonic-Lumix-DMC-GH2-/400297946366?pt=Camera_Cables_Cords&hash=item5d339decfe Link to comment Share on other sites More sharing options...
mongssim Posted June 10, 2012 Share Posted June 10, 2012 Looks like you are in luck. You might want to order a CGPro Battery Grip for GH2. Link below. Good luck. Features: • Compatible with Panasonic LUMIX DMC-GH2 • Extended run-time up to 7-9 hours. • Built-in Ultra High Capacity 5000mAh Li-ion Rechargeable Battery • Non-memory effect for maximum performance • 4 level LED indicator for a quick check of remaining battery capacity. Package includes: 1x CGPro Battery Grip Built-in 5000mAh Li-ion Rechargeable Battery 1x Charger http://www.cinegearpro.com/hdmi-cables/power-batteries/cgpro-5000mah-li-ion-rechargeable-battery-grip-for-panasonic-lumix-dmc-gh2.html Link to comment Share on other sites More sharing options...
Stephen de Vere Posted June 12, 2012 Share Posted June 12, 2012 I made a very simple flat plate that goes under the camera and provides a tripod mounting point offset well away from the battery door. I also have done the custom made battery setup which works for 6hrs or more. 8.4v 45mA RC battery 1.7mm int 4.75mm ext connector (ebay "Power DC Plug 1.7mm") to Panasonic DMW-DCC8 DC Coupler (requires at least 8.4 v) http://www.personal-view.com/talks/discussion/265/gh2-batteries-discussion/p1 Link to comment Share on other sites More sharing options...
DaveC Posted June 12, 2012 Share Posted June 12, 2012 I use v-mount batteries and a Switronix adapter [url=http://www.switronix.com/news/204-switronix-releases-xp-cable-for-panasonic-lumix-gh2]http://www.switronix.com/news/204-switronix-releases-xp-cable-for-panasonic-lumix-gh2[/url] I added sensor connectors (similar to LEMO, not as good but cheaper) and it works really well. Link to comment Share on other sites More sharing options...
