Administrators Andrew Reid Posted July 11, 2014 Administrators Share Posted July 11, 2014 The A7S is so close to being a 'complete' system for high end video quality in a small prosumer camera, but there's one issue that has quite rightly been highlighted by filmmakers such as Andrew Wonder and that is the rolling shutter distortion. The A7S actually has a very fast sensor with high efficiency made possible by the latest technology but because it does not skip any lines when reading out the image the net result is a scan that takes roughly as long as the older 5D Mark II, which does line-skip. Sony plan to fix this by introducing a new sensor technology which can read entire lines of pixels in batches of 4 simultaneously.Read the full article here Link to comment Share on other sites More sharing options...
Raymond Poulet Posted July 11, 2014 Share Posted July 11, 2014 For me another issue is the stabilization.Lens with Oss are not terrific and the only way for shoot great video is fix the camera on a tripod. We don't want to solve this problem in post with wharp in Premiere or other software. Finally the user guide miss lot of informations. I hope Andrew you will prepare a new shooter guide. Thanks Link to comment Share on other sites More sharing options...
Administrators Andrew Reid Posted July 11, 2014 Author Administrators Share Posted July 11, 2014 The ultra sonic stabilisation on Canon lenses can be used via the Metabones Smart EF adapter on the A7S. The 100mm F2.8L Macro especially is very effective for general handheld shooting and not just macro. 35mm F2.0 IS is another good one. Link to comment Share on other sites More sharing options...
Raymond Poulet Posted July 11, 2014 Share Posted July 11, 2014 Thanks, another additional cost. Do you know if leica lens with oss are better for stabilization than sony lens with oss. I really appreciate your support and if you have tips and tricks to improve Stabilization let me know. Link to comment Share on other sites More sharing options...
Guest Ebrahim Saadawi Posted July 12, 2014 Share Posted July 12, 2014 How good is rolling shutter correction in post? What are the downsides? What are the available options (plug-ins) for Sony Vegas, Premiere, Final cut, Avid ? Link to comment Share on other sites More sharing options...
sunyata Posted July 12, 2014 Share Posted July 12, 2014 Ebrahim- I've never had to fix rolling shutter issues, but I did come across this tutorial when researching it: http://www.premiumbeat.com/blog/rolling-shutter-adobe-premiere-pro/ For Premiere, it seems to be a built in filter.. probably also in AE. It looks like unlike removing camera shake, the gate doesn't move around. There are 2 modes, "warp" and "pixel motion".. pixel motion appears to be temporal, warp appears to be progressive and a mesh warp like effect. Gate seems unaffected with both. Since you're already going to be dealing with a blurry image, I think the quality loss issue is probably negligible. Interesting fix btw.. the 4 lines at once trick, assuming that doesn't create some visible line separation. Link to comment Share on other sites More sharing options...
Inazuma Posted July 12, 2014 Share Posted July 12, 2014 I tried that plugin the other day on a7s footage. Its indeed very effective at reduce rolling shutter effects on pans, but not so much for general movement. Link to comment Share on other sites More sharing options...
Germy1979 Posted July 12, 2014 Share Posted July 12, 2014 I like the point about the 5d Mark 2. People are still making fantastic stuff with it. It even had a run as A-cam for a Hollywood action feature with the same rolling shutter. Link to comment Share on other sites More sharing options...
Michael1 Posted July 12, 2014 Share Posted July 12, 2014 I have to admit I cringe when I read about fixing a problem by running a full frame camera in crop mode, and then fixing the crop mode "problem" with a SpeedBooster. :D Michael Link to comment Share on other sites More sharing options...
apefos Posted July 12, 2014 Share Posted July 12, 2014 maybe this 4 lines readout will introduce stair steps... so premiere will need to consider this in the rolling shutter repair... Link to comment Share on other sites More sharing options...
Administrators Andrew Reid Posted July 12, 2014 Author Administrators Share Posted July 12, 2014 I have to admit I cringe when I read about fixing a problem by running a full frame camera in crop mode, and then fixing the crop mode "problem" with a SpeedBooster. :D Michael You don't have to do it all the time, just when you want reduced rolling shutter though. Link to comment Share on other sites More sharing options...
Administrators Andrew Reid Posted July 12, 2014 Author Administrators Share Posted July 12, 2014 maybe this 4 lines readout will introduce stair steps... so premiere will need to consider this in the rolling shutter repair... No it's a linear roll at constant speed. Link to comment Share on other sites More sharing options...
letchhausen Posted July 13, 2014 Share Posted July 13, 2014 I have to admit I cringe when I read about fixing a problem by running a full frame camera in crop mode, and then fixing the crop mode "problem" with a SpeedBooster. :D Michael And you do the hokey pokey and shake your credit card around, that's what technology's all about! Link to comment Share on other sites More sharing options...
ernstdante Posted July 13, 2014 Share Posted July 13, 2014 Five straight postings on the Sony A7S. Is the Panasonic GH4 falling out of favor? Link to comment Share on other sites More sharing options...
Tzedekh Posted July 13, 2014 Share Posted July 13, 2014 Or they could implement a global shutter and move the global-shutter circuitry to another layer, like Alternative Vision Corporation. Isn't Sony a leader in stacked-sensor design? Link to comment Share on other sites More sharing options...
Administrators Andrew Reid Posted July 14, 2014 Author Administrators Share Posted July 14, 2014 Five straight postings on the Sony A7S. Is the Panasonic GH4 falling out of favor? No you just missed the 10 straight GH4 postings when that came out. Link to comment Share on other sites More sharing options...
Administrators Andrew Reid Posted July 14, 2014 Author Administrators Share Posted July 14, 2014 Or they could implement a global shutter and move the global-shutter circuitry to another layer, like Alternative Vision Corporation. Isn't Sony a leader in stacked-sensor design? They probably already did do that on the F55. Link to comment Share on other sites More sharing options...
MatthewP Posted July 14, 2014 Share Posted July 14, 2014 No it's a linear roll at constant speed. I think he means that if each line is being used, but in bursts of 4, then the differences in time will also be represented in chunks of 4 lines, assuming 1:1 pixel representation. This would create stair-stepping on pans etc. That's if I'm understanding the method correctly. Unless of course those 4 lines get merged into 1 line, if for example the sensor has a very high megapixel count. Link to comment Share on other sites More sharing options...
Administrators Andrew Reid Posted July 14, 2014 Author Administrators Share Posted July 14, 2014 I think he means that if each line is being used, but in bursts of 4, then the differences in time will also be represented in chunks of 4 lines, assuming 1:1 pixel representation. This would create stair-stepping on pans etc. That's if I'm understanding the method correctly. Unless of course those 4 lines get merged into 1 line, if for example the sensor has a very high megapixel count. Nope. Please read the patent for the answer. "Hayato Wakabayashi proposes to read 4 rows simultaneously, while keeping a smooth progression of the rolling shutter" The ramp DACs 142 and 152 work with a delay to have a smooth shutter curtain advance http://image-sensors-world.blogspot.de/2014/07/faster-readouts-smaller-rolling-shutter.html Link to comment Share on other sites More sharing options...
Marco Posted July 14, 2014 Share Posted July 14, 2014 Who knows how much time Sony needs before we see a faster rolling shutter in a Sony camera. Maybe one more year. I don't think at Photokina we'll see a new camera with this patent. Anyway it is a good news! Link to comment Share on other sites More sharing options...
