LOMO 35 nap2 3m 56/2 f:80-110,Attaching to Film Camera and Need of ? lens between LOMO and Camera Body
Mustafa Umut Sarac
Hello there ,
After long years of waiting , today I bought an LOMO 35 nap2 3m 56/2 f:80-110. I want to attach that lens on to Film Camera.
First of all , I dont have any idea whether there is a need for a lens between LOMO Anamorphic Lens and camera body..
And I want to learn the cheapest option to mount the LOMO .What is the name of adapters ?
May be I can buy a nikon autofocus camera or canon autofocus camera.
By the way serial is 0010667 , what is the date of the lens ?
Thanks
I believe you have a projector lens.  The NAP series are for projectors not cinema cameras, AFAIK.
You'll need a taking lens to render an image on your sensor.  I'm guessing somewhere in the neighbourhood of 55-100mm to avoid vignetting.
You'll also need a clamp to attach the two.  I think these lomo projector lenses are quite beefy, so I'm not sure what clamp will work.  It might be better to get a rail mount for the lens and then line it up with your taking lens and then black out the gap between the two.
Hope that helps.
