Mirrorkisser Posted May 23, 2012 Share Posted May 23, 2012 Hi, i cant get the manual aperture to work. I followed the steps in a guide, where i had to push in the pins and and move the inside of the lens clock wise. That all worked fine. Now i can change the aperture on the lens. But i cant mount it to my camera anymore. I can just do that, once i move the inside of the lens counter-clockwise again. Then i can change the aperture though. Any help highly appreciated Link to comment Share on other sites More sharing options...
Mirrorkisser Posted May 23, 2012 Author Share Posted May 23, 2012 I found out something weird: sometimes, when i do the routine with the 2 pins the manual aperture works after mounting the lens to my camera. Then when i unmount it and mount it again, it does not work again. Could the adapter be faulty? Link to comment Share on other sites More sharing options...
Mirrorkisser Posted May 23, 2012 Author Share Posted May 23, 2012 ok, apparently it is the ciecio adapter. depending on the angle i put the lens on it, sometimes manual aperture works, sometimes not. Maybe the stopper is too short or something... ok, its a bit tricky, but now i found the perfect angle to put the lens on the adapter and now it almost always works... Link to comment Share on other sites More sharing options...
