SLR Magic 10mm T2.1 world premiere, 1st video stills !!!!
Sebastien Farges
Hi everyone,
I've just received today the upcoming SLR Magic 10mm T2.1(eq. f1.8), and their upcoming variable ND filter !
My very firsts impressions : solid, heavy, compact, sharp at full aperture T2.1, only 2cm minimum focus distance.
The ND filter : good first impressions, and two great options on it : lever and hard stop !
Here are some pictures of the lens and of the variable ND filter, photo stills and video stills from GH4 C4K footages (most of them @ T2.1).
THE COMPLETE SET OF PICTURES IS HERE :
https://www.flickr.com/photos/43243778@N04/sets/72157646791136410/
Movie is coming soon  :)
TECHNICAL INFOS PRESS RELEASE at the end of this post
Thanks for your interest
THE LENS :
15109201586_fa6acc3837_k.jpgSLR Magic 10mm T2.1 by sebfarges, on Flickr
15109198866_3efe8f7e52_k.jpgSLR Magic 10mm T2.1 by sebfarges, on Flickr
15131817822_77a46c4c97_k.jpgSLR Magic ND variable filter by sebfarges, on Flickr
14945607578_284420644a_k.jpgSLR Magic 10mm T2.1 + SLR Magic ND variable filter by sebfarges, on Flickr
PHOTO STILLS with GH4
15109234966_60701f4e45_k.jpgSLR Magic 10mm T2.1 photo still by sebfarges, on Flickr
14945570830_260079cdfd_k.jpgSLR Magic 10mm T2.1 photo still by sebfarges, on Flickr
4K VIDEO STILLS from GH4
15129530001_bd8bac219d_k.jpgSLR Magic 10mm T2.1 4K video still by sebfarges, on Flickr
14945858650_bd44c702b5_k.jpgSLR Magic 10mm T2.1 4K video still by sebfarges, on Flickr
14945948047_37ca70085c_k.jpgSLR Magic 10mm T2.1 4K video still by sebfarges, on Flickr
TECHNICAL INFOS PRESS RELEASE :
NEW: THE SLR Magic HyperPrime CINE 10mm T2.1 and SLR Magic 77 ND 0.4-ND 1.8 filter
SLR Magic expands its micro four thirds lineup with new wide angle lens
Hong Kong, China (September 3, 2014)  - SLR Magic expands the micro four thirds lens lineup with the new SLR Magic HyperPrime CINE 10mm T2.1 wide angle lens. With this latest addition, the portfolio of lenses for the micro four thirds system is now comprised of thirteen focal lengths. The product will be officially introduced during upcoming Photokina 2014 fair in Cologne.
The field of view of this new HyperPrime Lens corresponds to a 20mm lens in 35mm format and this fast wide angle of view opens up many new creative composition opportunities, particularly in the fields of interior, architectural and landscape cinematography and photography. Additionally, a fast max aperture of T2.1 makes the SLR Magic HyperPrime CINE 10mm T2.1 ideal for available-light photography.
We place our highest priority in the development on our lenses to fulfill the demands of professional cinematographers and photographers. The design and build of the SLR Magic HyperPrime CINE 10mm T2.1 is solid and reliable.
The SLR Magic 77 ND 0.4-ND 1.8 filter is a solid variable neutral density filter providing a reduction of about 1.3 to 6 stops. The 0.4 to 1.8 density creates a darkening of the entire image, allowing you to photograph with a wider aperture or slower shutter speed than normally required. The degree of density is easily controlled by rotating the front filter ring via the non-removable lever. By slowing your exposure time you are able to control depth of field and convey movement more easily. Both filter substrates are combined into one filter ring, this filter is low profile and helps to eliminate vignetting on most lenses. The front filter ring diameter is 86mm in diameter, further helping to reduce vignetting, on wide angles lenses such as the SLR Magic HyperPrime CINE 10mm T2.1 lens.
The SLR Magic HyperPrime CINE 10mm T2.1 (MSRP: $799 US) and SLR Magic 77 ND 0.4-ND 1.8 filter (MSRP: $179 US) will be available from authorized SLR Magic dealers starting end of October 2014.
The SLR Magic HyperPrime CINE 10mm T2.1 will be first presented at Photokina 2014 fair. The SLR Magic stand would be in (No. L-011, Hall 5.1) during the fairs which are to be held in Cologne from 16th to 21st of September 2014. For all those who want to visit Photokina 2014 fairs.
SLR Magic is currently looking for volunteers to test this lens at a special price. If interested:
  1. Send an email to support@slrmagic.com with the subject "SLR Magic 10mm T2.1 volunteer".
  2. Include sample videos/photos or link to photo/video reviews you have done in the past.
Technical Data
Lens Type:
Fast wide-angle lens
Compatible Cameras:
All micro four thirds mount cameras
Optical Design:
13 elements in 11 groups
Distance Settings:
Distance range: 0.20m to ∞, combined scale meter/feet
Aperture:
Manually controlled diaphragm, 11 aperture blades , Lowest value 16
Bayonet:
micro four thirds
Filter Mount:
Internal thread for 77mm filter; filter mount does not rotate.
Surface Finish:
Black anodized
Dimensions:
Length to bayonet mount:
approx. 79.45mm (approx. 3.12in)
Largest diameter:
approx. 80.00mm (approx. 3.14in)
Weight:
approx. 420g (approx. 14.8oz)
Type:
Variable density
Size:
77 mm
Filter Factor:
0.4 - 1.8 (1.3 - 6 stops)
Front Filter Thread Size:
86mm
Guest
Reply to this topic...
  Only 75 emoji are allowed.
