richg101 Posted November 27, 2014 Share Posted November 27, 2014 P.s - My girlfriend is well secured in the loft AND the basement. She's in my basement tonight. The last time i saw her I came down with flu symptoms shortly after. Apparently ther eis something wrong with my immune system. - maybe get a checkup yourself. Hans Punk 1 Link to comment Share on other sites More sharing options...
Hans Punk Posted November 27, 2014 Share Posted November 27, 2014 She's in my basement tonight. The last time i saw her I came down with flu symptoms shortly after. Apparently ther eis something wrong with my immune system. - maybe get a checkup yourself. Oh dear :( Link to comment Share on other sites More sharing options...
Hans Punk Posted November 27, 2014 Share Posted November 27, 2014 For those interested, this seems to be a decent height adjustable lens support for use with the FM lens & clamp mount that is currently for sale: http://smallrig.com/camera-support-plates/other-plates/qr-lens-support-1505-15mm-lw.html I'm sure there are other/cheaper alternatives out there, but something like this will be needed for those adapting to 15mm rods and get correct height for different cameras and base-plates. Link to comment Share on other sites More sharing options...
dahlfors Posted November 28, 2014 Share Posted November 28, 2014 Hmm. I have rails already. But in the announcement it says "mounting ring ... with a 1/4 tripod female thread". That won't mount to the rails, which seems to be the handier way to mount something as big as the fm lens module and a schneider / ultrastar. So, Häns Punk. The one you linked, is that a rail mount added to the bottom of the mounting ring that would make it possible to attach it in a similar manner like in the FM Lens Module video? Am I understanding it correctly? Link to comment Share on other sites More sharing options...
Hans Punk Posted November 28, 2014 Share Posted November 28, 2014 Yeah, the height adjustable lens support I linked to would screw into that mounting ring base with the 1/4 inch female thread, enabling rod attachment via the quick release clamp at the bottom of the support. There are a few cheaper fixed height versions of those supports/ rod bridges out there, but having the option to adjust the height might be needed for some setups where the camera height cannot easily be adjusted. (My 5dmk3 is in a wooden camera cage for example, which would need the FM lens to be compensated a bit higher when attached to rails). dahlfors 1 Link to comment Share on other sites More sharing options...
dahlfors Posted November 28, 2014 Share Posted November 28, 2014 Great! Thanks for the clarification, Häns. Hans Punk 1 Link to comment Share on other sites More sharing options...
artiswar Posted November 28, 2014 Share Posted November 28, 2014 Order and honored the discount. £560 to my door via FedEx in 3-5 business days. As soon as I get it, I'll try to get some test up. What does everyone want to see? @comurit Thank you so much for all the work and correspondence. Cosimo murgolo 1 Link to comment Share on other sites More sharing options...
JohnVid Posted November 28, 2014 Share Posted November 28, 2014 Looking forward to it, Which anamorphic will you use with it? (More Cinilux & more Moller plz) Wondering how much spare room will be in there, if the 3 locating screws actually go into holes, to avoid scratching, as I thought the idea of the housing was to hide the anamorphic Wondering if the shipping unit has the same glass as the test unit, onow the minimum focus has changed. Wondering how easy/quick to focus. Which camera & taking lens do you hope to use it with, FF or APS-C? Link to comment Share on other sites More sharing options...
artiswar Posted November 28, 2014 Share Posted November 28, 2014 Using a Hypergonar. A7S with a set of Russian glass. Initial tests will be minimitable focal length for FF and APS-C as well as quick rack focus, sharpness tests, and of course bokeh and flares. Julian and Kristoferman 2 Link to comment Share on other sites More sharing options...
Hans Punk Posted November 28, 2014 Share Posted November 28, 2014 Order and honored the discount. £560 to my door via FedEx in 3-5 business days. As soon as I get it, I'll try to get some test up. What does everyone want to see? @comurit Thank you so much for all the work and correspondence. Don't you mean £460 to your door via FedEx in 3-5 business days? Link to comment Share on other sites More sharing options...
Guest Posted November 28, 2014 Share Posted November 28, 2014 I sent them an email this morning for purchase. havent gotten a reply :< Hope they arent TOO overwhelmed... Link to comment Share on other sites More sharing options...
Cosimo murgolo Posted November 28, 2014 Author Share Posted November 28, 2014 I sent them an email this morning for purchase. havent gotten a reply :< Hope they arent TOO overwhelmed... It's early in the morning in europe, they might sleep, they will reply don't worry! Link to comment Share on other sites More sharing options...
Guest Posted November 28, 2014 Share Posted November 28, 2014 It's early in the morning in europe, they might sleep, they will reply don't worry! They did. I placed my horderves :D EDIT: The total cost for me came out to be $665.71 USD Just so everyone know what it will ACTUALLY cost. Still, about 500 bucks cheaper than an Isco 36! Link to comment Share on other sites More sharing options...
Hans Punk Posted November 29, 2014 Share Posted November 29, 2014 Assuming that the production model of the FM lens operates in the same way as the early installation video, the FM lens needs to grip to the anamorphic lens inside, then the exposed rear area of that lens is clamped by a support ring...which is then attached to rails. I'm sure Anamorphicshop has a nice solution yet to come - that can reduce the internal diameter clamp via a collar or something to allow the use of smaller anamorphics (sub 71mm), but in the mean time - here is a 'Ghetto' solution. http://www.ebay.co.uk/itm/321033449391?_trksid=p2059210.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT Yep, exhaust pipe is the right diameter to match the exterior diameter of the ES cinelux that the FM lens looks optimised for. The stainless steel tube also has a nice and thin wall thickness to allow maximum space to accommodate any smaller anamorphic, providing it is packed in there with soft padding. This could be a decent temporary solution to those wanting to try alternative lenses for testing, until they release a proper internal reduction collar or whatever they have planned. Cosimo murgolo 1 Link to comment Share on other sites More sharing options...
Hans Punk Posted November 29, 2014 Share Posted November 29, 2014 They just extended the Warranty to 12 months. Cosimo murgolo 1 Link to comment Share on other sites More sharing options...
JohnVid Posted November 29, 2014 Share Posted November 29, 2014 2 C shaped felt lined shims (or split ring) to go round the anamorphic, would be better to clamp the anamorphic and then the screws could screw into them, rather than scratching the gold ana' but it would also benefit from some sort of bayonet to attach the rest to. Cosimo murgolo 1 Link to comment Share on other sites More sharing options...
Guest Posted November 29, 2014 Share Posted November 29, 2014 Im so glad I got one of those Schneider cinelux's on ebay for 80 bucks. Just in time for this! Still gonna keep my Sankor. Might sell my eiki. Love them all though. THE GLASS JUST LOOKS SOO COOOOL. Link to comment Share on other sites More sharing options...
richg101 Posted November 29, 2014 Share Posted November 29, 2014 I'm shutting this thread down for the good of the forum since its job is now complete. Anyone who has added their name to the list or has yet to do so, please contact Commurit via PM. I assume he has provided the list to the manufacturer. Link to comment Share on other sites More sharing options...
