DDagg Posted September 26, 2014 Share Posted September 26, 2014 I have just downloaded Sony's XAVC/XD CAM Plug in and I still can't import XAVC footage into FCPX. I am using the latest edition of FCPX(10.1.3) and Apple's Mavericks operating system. Also, my Mac has been updated with the ProApps Codecs version 1.0.5. Thought that I had done everything right. Guess Not! I would love it if someone could point me in the right direction here. Should I buy a Ninja Star and go straight to Pro Res and forget about all the conversion stuff. It seems to me that the more we convert things we lose quality. Link to comment Share on other sites More sharing options...
wjkotze Posted September 26, 2014 Share Posted September 26, 2014 There should be no problem. Just remember to dig into the root folder of the sd card until you get to the clips. Link to comment Share on other sites More sharing options...
Quirky Posted September 26, 2014 Share Posted September 26, 2014 I have just downloaded Sony's XAVC/XD CAM Plug in and I still can't import XAVC footage into FCPX. I am using the latest edition of FCPX(10.1.3) and Apple's Mavericks operating system. Also, my Mac has been updated with the ProApps Codecs version 1.0.5. Thought that I had done everything right. Guess Not! I would love it if someone could point me in the right direction here. Should I buy a Ninja Star and go straight to Pro Res and forget about all the conversion stuff. It seems to me that the more we convert things we lose quality. Just out of curiosity, as I haven't been playing with XAVC files yet, do you happen to have Aperture installed in your machine? If yes, what happens if you try importing those video clips into Aperture? Do you see them popping in as thumbnails, as it happens with regular AVCHD clips, or do you get some unknown file error or something? I know this is not likely to be too helpful, but like said, just curious about how the OS itself handles that format, if at all. I know nothing about Sony's own plugin, or how it works but I'm pretty sure that native XAVC support will come into FCPX/OS X, eventually. Hopefully in the next update, if it doesn't have it already. As for the idea of getting a Ninja Star, well, why not, depending on the camera you have. I probably would. Link to comment Share on other sites More sharing options...
DDagg Posted September 26, 2014 Author Share Posted September 26, 2014 When I shoot AVCHD the clips show up in aperture and it does upload nicely to FCPX in 24p. When I use XAVC files no clips are shown in Aperture or FCPX. Link to comment Share on other sites More sharing options...
DDagg Posted September 26, 2014 Author Share Posted September 26, 2014 I don't know what you mean by digging into the root folder of the SD card. wjkotze can you please explain this to me. Much appreciated. Link to comment Share on other sites More sharing options...
Quirky Posted September 26, 2014 Share Posted September 26, 2014 Maybe it's about the Sony plugin then. What exactly is it supposed to do, is it a FCPX plugin? Maybe you're supposed to plug the whole damn camera with the card onto the computer first... Or something. Or maybe the plugin itself is no good. I did a quick search in Google and looks like there are quite a few different XAVC to ProRes/Mov converters out there already. Probably one or two in the App Store, too. Suppose that's one simple way to go. Sorry about not being more helpful than that. Perhaps I should look into it properly when I have more time. So far I've just used a Ninja 2 to record ProRes directly. But meanwhile, as suggested above, maybe you can try getting the actual video clips by digging into the XAVC file structure (rigth-click the Private folder and choose "show package contents") until you reach the actual video clips. I don't know if it works, haven't shot any XAVC yet. Therefore I'm also curious to see if someone else has a proper solution. Link to comment Share on other sites More sharing options...
DDagg Posted September 26, 2014 Author Share Posted September 26, 2014 After further review, the sony plug in for FCPX says it works with Sony SxS cards. I think that is the key. Those cards look way expensive. I think i might just get the ninja star. Link to comment Share on other sites More sharing options...
wjkotze Posted September 26, 2014 Share Posted September 26, 2014 FCPX 10.1.3 on Mavericks can import XAVC files from any suitable sd card without any problems (assuming the sony plugin is installed). Go to the import dialog window and select the sd card. Now work through the folder sytem on the sd card until you get to the root folder. Inside the root folder you will find the clip folder. Inside the clip folder you will find the clips. Simply import the clips. You do not even have to transcode the files if you do not want to. Link to comment Share on other sites More sharing options...
DDagg Posted September 26, 2014 Author Share Posted September 26, 2014 Forgive me but I don't know where the import dialog window even is. Is it in FCPX. Sorry need help? Link to comment Share on other sites More sharing options...
wjkotze Posted September 26, 2014 Share Posted September 26, 2014 Go to file, then import media and the import dialog box will appear. This how you import all media into FCPX. Link to comment Share on other sites More sharing options...
DDagg Posted September 26, 2014 Author Share Posted September 26, 2014 I got that thanks but how do you select the sd card. I have done lots of importing and editing in FCPX with AVCHD but I just don't get this at all. Link to comment Share on other sites More sharing options...
DDagg Posted September 27, 2014 Author Share Posted September 27, 2014 Thanks wjkotze I finally figured it out. The clips look amazing in the new codec. You saved me from a major headache. Link to comment Share on other sites More sharing options...
peterwhite Posted March 12, 2015 Share Posted March 12, 2015 old thread , but still want to post here if you don't mind . I have also tried the Sony plug-in but with no luck, the most unbelieveable thing is that sony developed this codec but it can't deal with it by themself ! even for the sony vegas..... so I have to transcode the xavc to prores with some converter from pav, here is what I learned online, even you don't transcode them into prores, the fpc will help you do the same job in the backstage. So I just do it first which may speed up the rewrap conversion. Link to comment Share on other sites More sharing options...
Axel Posted March 23, 2016 Share Posted March 23, 2016 On 26. September 2014 at 5:46 PM, DDagg said: I have just downloaded Sony's XAVC/XD CAM Plug in and I still can't import XAVC footage into FCPX. I am using the latest edition of FCPX(10.1.3) and Apple's Mavericks operating system. Also, my Mac has been updated with the ProApps Codecs version 1.0.5. Just for the record: This was two OSXs back and several FCP X updates as well (which can be installed only on Yosemite or El Capitan). Current are OSX 10.11.4, FCP X 10.2.3 and Pro Codecs 2.0.4. XAVC is natively supported since quite a while now, no need to rewrap or transcode or use a Sony plugin. The professional tool monica66 recommends is for FCP7. Link to comment Share on other sites More sharing options...
