Liszon Posted September 29, 2014 Share Posted September 29, 2014 We were bidding on the same lens then :) My max bid was €105. The Schneider he uses in the video is actually a bit different, has no hood/collar on the front. I'm wondering if it will affect vignetting in any way. Another observation: The focus ring is moving up and down. Any ideas on using a follow focus? Link to comment Share on other sites More sharing options...
andy lee Posted September 29, 2014 Share Posted September 29, 2014 there are 2 versions of the Schneider the first one has a knurled knob on the front to adjust focus and a metal lip top and bottom I think you will have problems with this lens on the adaptor as the lip will stop it fitting in the end of the adapter tube the second version Schenider made is the current version they are still selling new right now it does not have the lips top and bottom on the front and it now has an allen key hole to adjust focus the front of this lens is totally flat - NO LIPS make sure you have the right version....... optically both lens are the same - same glass Link to comment Share on other sites More sharing options...
Cosimo murgolo Posted September 29, 2014 Share Posted September 29, 2014 We were bidding on the same lens then :) My max bid was €105. The Schneider he uses in the video is actually a bit different, has no hood/collar on the front. I'm wondering if it will affect vignetting in any way. :( sorry man!!!! I might be totally wrong, as I am totally ignorant on anamorphic and lens in general, but I think it looked as they set the anamorphic to infinity with the little knob and after took the hood front off. maybe someone else will answer to this. Link to comment Share on other sites More sharing options...
Hans Punk Posted September 29, 2014 Share Posted September 29, 2014 Another observation: The focus ring is moving up and down. Any ideas on using a follow focus? I asked Anamorphicshop on their Facebook page...apparently they plan to have a focus gear ring as an option. I presume it will be fairly wide (like Helicoptersean's isco 54 seamless ABS gear?) - so the linear travel will not be an issue with follow focus. The focus gear being wider would allow the follow focus gear to always have a 'bite' of the gear, throughout it's 'in-out' travel. Link to comment Share on other sites More sharing options...
andy lee Posted September 29, 2014 Share Posted September 29, 2014 this is the one I have. you got a good price too! I do think you will have trouble with this first version of the Schneider as it has lips top and bottom and the knurled knob on the front for focus the second version of the Schnieder is the current version it has a flat front and allen key hole to adjust focus.......no lips Link to comment Share on other sites More sharing options...
Julian Posted September 29, 2014 Share Posted September 29, 2014 Maybe you could remove those parts of the lens? The anamorphic is set at a fixed focuspoint anyway in the FM adapter. Link to comment Share on other sites More sharing options...
andy lee Posted September 29, 2014 Share Posted September 29, 2014 yeah ..get your dremmel out!! chop the lips off!! Julian and Cosimo murgolo 2 Link to comment Share on other sites More sharing options...
Cosimo murgolo Posted September 29, 2014 Share Posted September 29, 2014 yeah ..get your dremmel out!! chop the lips off!! what will you suggest, I mean, is there anything we can do, I bought it to use with FM Please tell me there is a solution! :) Link to comment Share on other sites More sharing options...
Cosimo murgolo Posted September 29, 2014 Share Posted September 29, 2014 I do think you will have trouble with this first version of the Schneider as it has lips top and bottom and the knurled knob on the front for focus the second version of the Schnieder is the current version it has a flat front and allen key hole to adjust focus.......no lips I have just asked anamorphic shop on facebook if I will encounter any problems using the first version of schnieder, the answer is..... no!!! FM lens is designed to be used with schneider I,II, and many others dahlfors and Julian 2 Link to comment Share on other sites More sharing options...
andy lee Posted September 29, 2014 Share Posted September 29, 2014 lets be realistic its not going to be ideal having the end of your lens with a lip stopping it fitting flat with the end of the FM adaptor they might say its fine but have they actually tried it for real its going to make a differance to the focusing if the lens is not flush. its pure physics its going to make a differance . the Schneider II and Isco and Sankor gold anamorphic lens all have flat ends I would stick with them .. Link to comment Share on other sites More sharing options...
richg101 Posted September 30, 2014 Author Share Posted September 30, 2014 what will you suggest, I mean, is there anything we can do, I bought it to use with FM Please tell me there is a solution! :) I intend to hacksaw the lips off mine. But in any case the fact that the front fm module optics are very large the lips shouldnt create very much of a problem even if you left them. removal of the lips with a hacksaw will take about 2 mins of gentle sawing with a decent hacksaw on a sturdy table lined with some old clothes for padding and to stop it slipping while you saw. there wont be any chance of the metal grains causing problems. just blow them away with some canned air. properly cleaning the lens element before starting to saw will remove any residue that might be on the lens that might attract the sawdust. the focus locking knob will need removing - which again wont cause a problem - its more for continuous projector vibration problems and focus wont shift when in the fm module I doubt. the focus know will also need chopping down a little - leave just enough length to allow you to still operate focus. the whole job will take less than 30mins Link to comment Share on other sites More sharing options...
richg101 Posted September 30, 2014 Author Share Posted September 30, 2014 Cosimo murgolo and Julian 2 Link to comment Share on other sites More sharing options...
Liszon Posted September 30, 2014 Share Posted September 30, 2014 I think I will keep looking for the lipless version or an Isco, I like to go for sure. Also first I want to see some follow focus in action. So I will leave the early adopting to you guys :) Liszon 1 Link to comment Share on other sites More sharing options...
Cosimo murgolo Posted September 30, 2014 Share Posted September 30, 2014 lets be realistic its not going to be ideal having the end of your lens with a lip stopping it fitting flat with the end of the FM adaptor they might say its fine but have they actually tried it for real its going to make a differance to the focusing if the lens is not flush. its pure physics its going to make a differance . the Schneider II and Isco and Sankor gold anamorphic lens all have flat ends I would stick with them .. I have asked again to be 100% sure if it will work with the first version of the schneider, and again and again!!! I am going to ask for a video too. the answer from anamorphic shop is YES it will work Julian 1 Link to comment Share on other sites More sharing options...
Nikkor Posted September 30, 2014 Share Posted September 30, 2014 That lens will be perfectly fine. If the cineluxs could take 50mm in FF it could be a problem, but that's not the case. Link to comment Share on other sites More sharing options...
andy lee Posted September 30, 2014 Share Posted September 30, 2014 you can use one with the lips - I certainly wont be! no way ! I have both versions ! Link to comment Share on other sites More sharing options...
Julian Posted September 30, 2014 Share Posted September 30, 2014 Whats the problem Andy? Maybe the version with lips works fine, the image shows it fits. Lets wait till we see the results. Not everbody has a infinite supply of these golden beasts like you. Link to comment Share on other sites More sharing options...
Nikkor Posted September 30, 2014 Share Posted September 30, 2014 The problem is the Treasure of Sierra Madre that's always going on in the anamorphics forum... Link to comment Share on other sites More sharing options...
Julian Posted September 30, 2014 Share Posted September 30, 2014 That's not even shot anamorphic :P Link to comment Share on other sites More sharing options...
rook Posted October 1, 2014 Share Posted October 1, 2014 Can anyone with a cinelux let me know what the widest 35mm lens they can use without vignetting. 50mm seems to be the standard, but I prefer a little wider for my narrative work. Has anyone tested a 35mm lens on a crop sensor? Scrolled through, and didn't see it mentioned. If it is a repeat question, I apologize. Link to comment Share on other sites More sharing options...
