wallpaperviking Posted October 10, 2014 Share Posted October 10, 2014 Wow! This looks awesome, look forward to some real world results! Just wondering if the Hypergonar Hi Fi 2 will work with this adapter? I don't see it listed but it is essentially a cinema anamorphic projection lens right? Link to comment Share on other sites More sharing options...
richg101 Posted October 10, 2014 Author Share Posted October 10, 2014 Nice video. Just got a cinelux myself. What's the diameter of the back thread on it? (you mentioned you screwed it on with a step ring) The thread is not a standard step ring gauge. it's very close to 67mm. I put mine on the lathe and took most of the thread off, then did the same with a step ring. leaving a small amount of thread on both means you can push a 67mm-62mm step ring onto it using a bit of weight and two flat surfaces.. however you'll never get the ring off again unless you saw it off. Hans_Punk knows about a special adaptor with the correct thread on it.. Maybe he can chime in. valid 1 Link to comment Share on other sites More sharing options...
andy lee Posted October 10, 2014 Share Posted October 10, 2014 Wow! This looks awesome, look forward to some real world results! Just wondering if the Hypergonar Hi Fi 2 will work with this adapter? I don't see it listed but it is essentially a cinema anamorphic projection lens right? hypergonar is huge , this FM module will only work with 70.6mm diameter projection lenses , this is the industry standard size for these smaller integrated anamorphic lenses. Hypergonar is a1960's first generation anamorphic projection lens , these 70.6mm lenses are all modern 2000 onwards era lenses Link to comment Share on other sites More sharing options...
Hans Punk Posted October 10, 2014 Share Posted October 10, 2014 Hans_Punk knows about a special adaptor with the correct thread on it.. Maybe he can chime in. I already had a 72mm clamp floating around in the draw that came with a morphic lens from years back. Similar to the vid-Atlantic ones, basically a tin tube with rear 72mm thread and nylon screws, not at all Redstan quality but holds it well enough for testing with. As soon as the FM lens is in my hands, I'll probably throw that clamp in the river. richg101, valid and dahlfors 3 Link to comment Share on other sites More sharing options...
Cosimo murgolo Posted October 10, 2014 Share Posted October 10, 2014 I already had a 72mm clamp floating around in the draw that came with a morphic lens from years back. Similar to the vid-Atlantic ones, basically a tin tube with rear 72mm thread and nylon screws, not at all Redstan quality but holds it well enough for testing with. As soon as the FM lens is in my hands, I'll probably throw that clamp in the river. That's what I did, I used a 72 filter clamp from redstan, then a 72mm to 52 step down ring and at end 52mm to 52mm lens reversing coupler adapter. richg101 and Hans Punk 2 Link to comment Share on other sites More sharing options...
Cosimo murgolo Posted October 16, 2014 Share Posted October 16, 2014 That's what I did, I used a 72 filter clamp from redstan, then a 72mm to 52 step down ring and at end 52mm to 52mm lens reversing coupler adapter. Link to comment Share on other sites More sharing options...
valid Posted October 16, 2014 Share Posted October 16, 2014 BTW I have one of those gold schneiders with the front lips for sale if anyone is looking for one? Just having a clear-out so not looking to make a big profit. Link to comment Share on other sites More sharing options...
ken Posted October 16, 2014 Share Posted October 16, 2014 Hi, did any one compare Schneiders with ISCO integrated lens? Which is wider? Optics difference? Link to comment Share on other sites More sharing options...
dahlfors Posted October 16, 2014 Share Posted October 16, 2014 BTW I have one of those gold schneiders with the front lips for sale if anyone is looking for one? Just having a clear-out so not looking to make a big profit. Gold Schneiders - do you mean the same Cinelux ones discussed in this thread? If so, I might be interested if the glass is in good condition and the price is low enough. Link to comment Share on other sites More sharing options...
dahlfors Posted October 16, 2014 Share Posted October 16, 2014 I already had a 72mm clamp floating around in the draw that came with a morphic lens from years back. Similar to the vid-Atlantic ones, basically a tin tube with rear 72mm thread and nylon screws, not at all Redstan quality but holds it well enough for testing with. As soon as the FM lens is in my hands, I'll probably throw that clamp in the river. Got a vid-atlantic clamp for my ultra star too. Probably needless to say - but the ultra star is pretty scratched after using that clamp. Hans Punk 1 Link to comment Share on other sites More sharing options...
wallpaperviking Posted November 11, 2014 Share Posted November 11, 2014 Apologies if this has already been posted but I was just wondering the relevance of Diopters (such as as the Tokina 0.4) given that the new FM module is able to focus from 50cm to Infinity? I have the Tokina 0.4 and have barely used it to be honest and would potentially look at selling it to help fund the purchase of the new FM module. Like many others, I will wait for more samples but from what I have seen so far, is looking pretty good :) I guess there are always Iscorama users who would still have the need for such a diopter (as it is already single focus). Are there any other anamorphics out there that will not be covered by the FM module and would still demand the use of the Tokina 0.4 diopter? Also, given that the front of the FM module is so large, there is no way of using the Tokina 0.4 Diopter if I did want extreme minimum focus? O.K, thanks so much in advance :) Link to comment Share on other sites More sharing options...
richg101 Posted November 11, 2014 Author Share Posted November 11, 2014 Apologies if this has already been posted but I was just wondering the relevance of Diopters (such as as the Tokina 0.4) given that the new FM module is able to focus from 50cm to Infinity? The tokina is something that will always find use and is a great addition to anyone's lens collection. personally I'd still rather use an achromatic diopter and limit the minimum focus of the fm module to 1m or longer, using a diopter to get closer. the magic of the tokina is that it'll allow racking from 2.4metrs down to half of the minimum focus of the lens it is attached to. The Tokina would be a lot more valuable to you if it were 105mm, but i imagine you'll still get better results from using the tokina than racking those two optics farther and farther apart on the fm module. Also since the cineluxes are rather long, they limit how wide taking lens you can use meaning the 72mm diameter might not be as much as a limitation as the 105mm front of the fm module might suggest. Link to comment Share on other sites More sharing options...
wallpaperviking Posted November 12, 2014 Share Posted November 12, 2014 Thanks so much for the insight Richg101, will hold onto the Tokina 0.4 and wait patiently for the FM module to be announced :) Link to comment Share on other sites More sharing options...
dwijip Posted November 27, 2014 Share Posted November 27, 2014 Had a quick lens test last night with the new Isco ultra star I got off ebay. Lens works fine except I quickly found you need diopters to frame more freely. And the focus ring is really stiff not sure if the thing is built that way or just age stiffened it. I arrived home really late but had to try the workflow before going to sleep. Couldn't get my brother to be on camera so I made him film me instead. Bad iso settings I know, but room was not so well lit. Found that this lens had 1.9x Squeeze Factor rather than 2x. So edited in 3648x1080 then, exported downscaled to 1920X568, aspect ratio turned out to be something like 3.38 : 1 I think I would crop off the sides when I actually do some filming with it. http://vimeo.com/113008765 Link to comment Share on other sites More sharing options...
ken Posted November 28, 2014 Share Posted November 28, 2014 I think it is still 2x lens. If you shot at very close object, need to reduce the ratio for sure. ISCO integrated lens taken samples as 2x decompression : http://pan.baidu.com/s/1kT42hj5 http://pan.baidu.com/s/1hqIf2dA Link to comment Share on other sites More sharing options...
dwijip Posted November 28, 2014 Share Posted November 28, 2014 Really? I thought it was something in between 1.8x and 1.9x for sure. Is there a chance that it might vary depending on the particular lens and the set up maybe? Link to comment Share on other sites More sharing options...
ken Posted November 28, 2014 Share Posted November 28, 2014 I am sure you got 2x, after focusing over 20 meters, might less than 2x if less than 10m, about 1.9x. For 1.5m, even less than 1.9x. All lenses specs are said at infinity. Link to comment Share on other sites More sharing options...
dwijip Posted November 29, 2014 Share Posted November 29, 2014 oh I see what you mean, Thanks I sort of get it now Link to comment Share on other sites More sharing options...
richg101 Posted December 15, 2014 Author Share Posted December 15, 2014 Here is an example of the cinelux es 2x running on the zeiss 85mm f1.4, wide open on full frame. no cropping. 3:2 still from the A7r then de squeezed. Incredible image quality. dahlfors and Cosimo murgolo 2 Link to comment Share on other sites More sharing options...
richg101 Posted December 16, 2014 Author Share Posted December 16, 2014 and another. wide open at f1.4. Link to comment Share on other sites More sharing options...
