benymypony Posted August 11, 2015 Share Posted August 11, 2015 Sorry for being a greenhorn, but how do I use this LUT?How to use in Adobe After Effects : https://youtu.be/_39GzdjZKmAHow to use in Adobe Premiere Pro : https://youtu.be/PvjHqNlrCJwHow to use in Adobe Photoshop : http://is.gd/wX8zqsHow to use in Final Cut Pro X with LUT Utility plugin : https://youtu.be/xlm-Wqdmu4AHow to use Magic Bullet LUT Buddy : https://youtu.be/hrSbtqLIamEHope it helps tosvus 1 Link to comment Share on other sites More sharing options...
MBFrancis Posted August 11, 2015 Share Posted August 11, 2015 Thanks Beny! Realized I can just drop the file into LUT Utility through System preferences.Anyways, the LUT works fantastic! In combination with the Alexa LUT, it makes for some natural and pleasing colors! It's been a pain getting consistent good colors out of the LX100, but this definitely helps a lot! benymypony 1 Link to comment Share on other sites More sharing options...
shanebrutal Posted August 17, 2015 Share Posted August 17, 2015 Still playing with the LX100, I tried a lot of profile settings and Highlight/Shadow curves to get the best image for color grading.Finally I recommend the following settings :Contrast -2 / Sharpen -3 / Noise reduction -2 / Saturation 0Highlight -2 / Shadow -2As it's impossible to apply a real LOG flat profile in-camera, so I created a LUT to flatten the image the safest way.I based this LUT on the rendering of the VisionLOG profile with some adjustments.Download (.3dl and .cube in ZIP, 2.5MB) : IWLTBAP_Flattener_LUT.zip Hi, thanks for your findings I plan to try this out soon. Is this for the Standard picture style in the lx100? Link to comment Share on other sites More sharing options...
benymypony Posted August 17, 2015 Share Posted August 17, 2015 Hi, thanks for your findings I plan to try this out soon. Is this for the Standard picture style in the lx100?Yes, Standard.Right now I use Natural with :Contrast -5 / Sharpen -5 / Noise reduction -5 / Saturation 0Highlight 0 / Shadow 0Almost no noise up to 800 ISO.Check this beautiful video by a user with same settings on LX100 : https://vimeo.com/116671977You can download the 2.5K version from Vimeo, and the quality is very impressive ! tosvus and shanebrutal 2 Link to comment Share on other sites More sharing options...
shanebrutal Posted August 18, 2015 Share Posted August 18, 2015 Yes, Standard.Right now I use Natural with :Contrast -5 / Sharpen -5 / Noise reduction -5 / Saturation 0Highlight 0 / Shadow 0Almost no noise up to 800 ISO.Check this beautiful video by a user with same settings on LX100 : https://vimeo.com/116671977You can download the 2.5K version from Vimeo, and the quality is very impressive !Indeed that is very nice. I have impulz and use it with my gh4 but haven't been able to match it well with the lx100 on standard. Do you still use your flatenner lut with those settings on natural? Link to comment Share on other sites More sharing options...
maxotics Posted August 18, 2015 Share Posted August 18, 2015 Found an open-box lx100 so have been playing around. I'm using a script to downsample all the files to 1080 so i can view/work with them easier. So for anyone interested in a windows script using ffmpeg. Copy this "converto1080.bat" script (or whatever batch filename you want to call it ) into a folder with 4K mp4 files. Run it and it will created 1080 COPIES in mp4_1080 (or whatever you want to call the folder).ALSO, if anyone has better ffmpeg paramaters, please post!@echo OFF SETLOCAL REM title Converting... REM ***** CONFIG ***** REM like F:\Files2015_Maxotics\Video\ REM fold= curent folder set fold=%~dp0 set ext=*.mp4 REM dest = curent folder + mp4_1080 REM like F:\Files2015_Maxotics\Video\mp4_1080\ REM change to whatever you like... set dest=%~dp0\mp4_1080\ REM ***** END CONFIG ***** :: This makes the target folder ::MD "%fold%" MD "%dest%" REM make sure you have correct path to ffmpeg.exe for %%f in (%fold%%ext%) do "C:\Files2013_VidPhotoSoft\ffmpeg\64bit\bin\ffmpeg.exe" -i %%f -vf scale=1920:1080 -c:v libx264 -crf 10 -preset slow -c:a copy -sn "%dest%%%~nxf" REM if errors, pause so command window doesn't lcose REM pause If I need to just convert one file, I edit this batch fileecho OFF set fold=%~dp0 set dest=%~dp0\mp4_1080\ set usefile=P1040162.mp4 ::MD "%fold%" MD "%dest%" "C:\Files2013_VidPhotoSoft\ffmpeg\64bit\bin\ffmpeg.exe" -i %usefile% -vf scale=1920:1080 -c:v libx264 -crf 10 -preset slow -c:a copy -sn "%dest%%usefile%" REM pause REM unREM pause to look at output in command window tosvus 1 Link to comment Share on other sites More sharing options...
benymypony Posted August 18, 2015 Share Posted August 18, 2015 Indeed that is very nice. I have impulz and use it with my gh4 but haven't been able to match it well with the lx100 on standard. Do you still use your flatenner lut with those settings on natural?Yes I use it, but I have not yet made a video project with the LX100, only tests.Found an open-box lx100 so have been playing around. I'm using a script to downsample all the files to 1080 so i can view/work with them easier. So for anyone interested in a windows script using ffmpeg. Copy this "converto1080.bat" script (or whatever batch filename you want to call it ) into a folder with 4K mp4 files. Run it and it will created 1080 COPIES in mp4_1080 (or whatever you want to call the folder).(...)For Windows and Mac users, there is the freeware Rocky Mountains Movie Converter.It uses FFMPEG with simple interface and it's really fast compared to Adobe Media Encoder, Apple Compressor or others encoding applications.Download : http://sourceforge.net/projects/rockymountainsmovieconverter/files/ tosvus 1 Link to comment Share on other sites More sharing options...
jase Posted August 19, 2015 Share Posted August 19, 2015 I got quite a good deal on the LX100 and will love to try it out. I am not interested in 4k output, but merely in getting an increase in quality by downscaling to 1080. My Macbook Pro is from 2011 and it will not be able to handle 4k properly i am afraid, so.... which workflow is preferred? Downscaling it before with something like the ffmpeg method suggested by @maxotics? Or do I need to go down the path to import the 4k footage in FCPX and start drinking more coffee? Link to comment Share on other sites More sharing options...
mercer Posted August 19, 2015 Share Posted August 19, 2015 I got quite a good deal on the LX100 and will love to try it out. I am not interested in 4k output, but merely in getting an increase in quality by downscaling to 1080. My Macbook Pro is from 2011 and it will not be able to handle 4k properly i am afraid, so.... which workflow is preferred? Downscaling it before with something like the ffmpeg method suggested by @maxotics? Or do I need to go down the path to import the 4k footage in FCPX and start drinking more coffee?I have a 2014 MacBook Air with 8gb ram and have no problems with 4k footage, but I think it looks better, heavier if that makes sense, when downscaled to 1080p at conversion. I use EditReady and it is lightning fast. But I have heard Rocky Mountain converter is excellent and it's free. The only reason I went with EditReady is for the other features and I already had ClipWrap and you get a lower price by upgrading from ClipWrap to EditReady. Link to comment Share on other sites More sharing options...
PannySVHS Posted August 19, 2015 Share Posted August 19, 2015 Yes I use it, but I have not yet made a video project with the LX100, only tests.For Windows and Mac users, there is the freeware Rocky Mountains Movie Converter.It uses FFMPEG with simple interface and it's really fast compared to Adobe Media Encoder, Apple Compressor or others encoding applications.Download : http://sourceforge.net/projects/rockymountainsmovieconverter/files/Hallo Benjamin, I would need to rewrap the mts files to mp4 if I´d like to use Rocky Mountains Movie Converter on Windows. Do you know a nice n easy rewrap tool withoutencoding, so there won´t be another encoding step and quality loss when rewrapping? best regards, Marty Link to comment Share on other sites More sharing options...
maxotics Posted August 19, 2015 Share Posted August 19, 2015 I got quite a good deal on the LX100 and will love to try it out. I am not interested in 4k output, but merely in getting an increase in quality by downscaling to 1080. My Macbook Pro is from 2011 and it will not be able to handle 4k properly i am afraid, so.... which workflow is preferred? Downscaling it before with something like the ffmpeg method suggested by @maxotics? Or do I need to go down the path to import the 4k footage in FCPX and start drinking more coffee?If you want to use ffmpeg here is a srcript I used for MTS to MP4. YES, ffmpeg is difficult to use, BUT it can do ANYTHING, I mean ANYTHING. Most freeware/shareware software is based on ffmpeg. DO ( md mts md mp4 ) for %%f IN (*.mts) DO ( "C:\Files2013_VidPhotoSoft\ffmpeg\64bit\bin\ffmpeg.exe" -i %%f -y -map 0:0 -c:0 copy -map 0:1 -c:1 aac -b:1 128k -ac:1 2 -cutoff 19000 -strict experimental -sn %%~nf.mp4 ) DO ( Link to comment Share on other sites More sharing options...
jase Posted August 19, 2015 Share Posted August 19, 2015 I know & love fffmpeg and i am everything but afraid of configuring it - so thats not the issue. The question to me is more whether ffmpeg has the better encoder than FCPX or NLE's in general. But if i got @mercer right, downscaling outside the NLE is preferred to using the 4k material and let the NLE do the scaling? Link to comment Share on other sites More sharing options...
mercer Posted August 19, 2015 Share Posted August 19, 2015 I know & love fffmpeg and i am everything but afraid of configuring it - so thats not the issue. The question to me is more whether ffmpeg has the better encoder than FCPX or NLE's in general. But if i got @mercer right, downscaling outside the NLE is preferred to using the 4k material and let the NLE do the scaling?I preferred it. I noticed no difference downscaling before I brought the footage into fcpx, as opposed to editing 4k prores and then rendering out to 1080p. I will say it is faster to do the downscaling before hand, but that may just be due to my hardware limitations. jase 1 Link to comment Share on other sites More sharing options...
Deadcode Posted August 19, 2015 Share Posted August 19, 2015 Im using FCPX and importing 4K files from card, then im making proxy (1/4 resolution = 1080p) files from everything.Im working with proxy's and it's butter smooth, the quality is OK, and it's easy to work with (4K timeline)Then im exporting in 4KThen creating a 1080p timeline, copy/paste from the 4K project, then exporting to 1080p, simple, fast easy, but storage space consuming. Link to comment Share on other sites More sharing options...
jase Posted August 24, 2015 Share Posted August 24, 2015 This weekend i received this little gem. I started playing around finding some proper settings. This is my current status:https://vimeo.com/137074524 (password: lx100)What do you guys think? It might be a little to contrasty.. Link to comment Share on other sites More sharing options...
Inazuma Posted August 24, 2015 Share Posted August 24, 2015 This weekend i received this little gem. I started playing around finding some proper settings. This is my current status:https://vimeo.com/137074524 (password: lx100)What do you guys think? It might be a little to contrasty..Id probably start by raising all the shadows a bit Link to comment Share on other sites More sharing options...
thefactory Posted August 30, 2015 Share Posted August 30, 2015 @benymypony thanks for the LUT. I have been testing it with edit ready and then in FCP x applying some koji LUTS and getting some good results. Think i can match this in well with the GH4 . Keep testing people's. Loving this thread on the LX100 benymypony 1 Link to comment Share on other sites More sharing options...
jase Posted August 31, 2015 Share Posted August 31, 2015 Next try (4k, JPEG rendered by FCPX): benymypony 1 Link to comment Share on other sites More sharing options...
benymypony Posted August 31, 2015 Share Posted August 31, 2015 Next try (4k, JPEG rendered by FCPX):(...)Oh, very nice !Love this color grading.Can you share your LX100 settings (contrast, sharpen, NR, saturation, highlight/shadow curve) ?Do you remember the ISO of these shots ?Would love to see this video Link to comment Share on other sites More sharing options...
jase Posted August 31, 2015 Share Posted August 31, 2015 Thanks. I went back to square one after having quite a few unsuccessful attempts and remembered and old video from me, which i really liked:Recipe is as follows:Standard with -5,-5,-5,-5Highlight / Shadow 0,0Iso was Auto, but i guess it was 200-400Tiffen Ultra Contrast 3 FilterFilmConvert with GH4 Profile, FJ SuperX 400 emulation was used with 30% grainSome slight adjustment in the shadows to give it more contrast, thats it. Works out of the box on the GM1 and seems to work out of the box on the LX100.Will put up some small demo video later. tosvus, 1tkman and benymypony 3 Link to comment Share on other sites More sharing options...
