Bruno Posted November 25, 2014 Share Posted November 25, 2014 I've spent a few weeks trying to find out what was wrong with my lenses and why I couldn't get infinity focus. Since I wasn't using any MFT lenses, I started losing faith in the adapted ones, I even considered it might be a faulty or badly calibrated sensor, but it turns out it was all the adapter's fault, so if you're experiencing the same issues, or if you're thinking of getting one of these for your Pocket Camera, beware! I found a similar one by Fotasy on eBay, it was even cheaper and it works great, I can now focus to infinity and beyond! Just by comparing the two of them, one can tell the Fotodiox is thicker than the Fotasy one, so one of them is gotta be wrong. There's also a chance I have a faulty Fotodiox adapter (haven't tried it in a different MFT camera), but for now I'll stick to the Fotasy one. Link to comment Share on other sites More sharing options...
jax_rox Posted November 25, 2014 Share Posted November 25, 2014 A lot of adapters aren't built to very high tolerances, and therefore can be slightly off in terms of length, which will totally throw out your FFD (or back focus) and make it impossible to focus to infinity. If you do have adapted lenses that aren't focusing to infinity, try switching adapters before despairing too much. Often it's not even related to price - $10 adapters can be better, as good as, or worse than $100 adapters. There are a few brands that are trustworthy when it comes to adapters, but the adapters they make all tend to be quite expensive. Link to comment Share on other sites More sharing options...
Quirky Posted November 25, 2014 Share Posted November 25, 2014 Well, you usually get what you pay for. The Fotodiox adapters I have are fine, and I'd see no problem in buying more of them. Although I wouldn't want to go for an adapter with a built in iris blades, be it a Fotodiox one or some other brand.. Link to comment Share on other sites More sharing options...
Guest 560a4aedcb80685284629074497fdc75 Posted November 25, 2014 Share Posted November 25, 2014 Do your lenses focus accurately to the distances marked on the barrel when using the Fotasy? If it's focusing far beyond infinity you may not get the close focus each lens should be capable of ... Link to comment Share on other sites More sharing options...
Bruno Posted November 25, 2014 Author Share Posted November 25, 2014 Well, you usually get what you pay for. Well, in this case I got more from the cheapest option! Do your lenses focus accurately to the distances marked on the barrel when using the Fotasy? If it's focusing far beyond infinity you may not get the close focus each lens should be capable of ... That's true, but it's not like there is one brand that will have the perfect adapter that will work with all lenses, so it's a bit hit and miss really. It's true I miss a bit of the near focus with the Fotasy adapter, but I also kept the Fotodiox adapter, which increases my lenses' near focus ability! Link to comment Share on other sites More sharing options...
Guest 560a4aedcb80685284629074497fdc75 Posted November 25, 2014 Share Posted November 25, 2014 I imagine Novaflex and Metabones will be pretty accurate at both ends ... Link to comment Share on other sites More sharing options...
Bruno Posted November 26, 2014 Author Share Posted November 26, 2014 I can't think such an adapter by Novoflex, and the Metabones one costs 20x more, way more than I'm supposed to spend on a MFT accessory. All my lenses are full frame, with an APS-C exception and I'd like to keep it that way, the Pocket Camera is an exception in sensor format, but I'm not spending that much money on something that will only work with this camera. $300 would make me think twice though. Link to comment Share on other sites More sharing options...
Quirky Posted November 26, 2014 Share Posted November 26, 2014 All my lenses are full frame, but I'm not spending that much money on something that will only work with this camera. Why not? BTW, Speed Boosters aside, Novoflex do make a regular mFT to EF adapter. It's not that much more expensive than the regular Metabones adapter. Link to comment Share on other sites More sharing options...
Bruno Posted November 26, 2014 Author Share Posted November 26, 2014 Why not? BTW, Speed Boosters aside, Novoflex do make a regular mFT to EF adapter. It's not that much more expensive than the regular Metabones adapter. Because I can't justify it. I want to get the BMD 4K camera at some point, ideally they'd come out with one that does at least 50fps, then I'd be happy, the Pocket camera is great, but I don't want any MFT specific gear. Couldn't find that adapter earlier on their website, but was in a hurry, will look it up later. (not that I need yet another adapter at this point) Link to comment Share on other sites More sharing options...
