Urthona Posted December 2, 2014 Share Posted December 2, 2014 Obviously the stabilization isn't well implemented for filming purposes but I wouldn't bother to buy the A7II as a B-Cam anyway if the don't have such a bad track record for providing updates. The A6000 for example still has no XAVC-S. So I think I will sit this one out... Link to comment Share on other sites More sharing options...
ZoranBerlin Posted December 2, 2014 Share Posted December 2, 2014 Hey Andy, 2 questions: - How does a STABILIZED lens perform with in camera stabilization? I imagine it to perform extremely well in combination. That may "relativize" - if that s an English word – your verdict. - Does it have Active Mode? And if so, how does it perform to standard steady shot? Sony provides balanced steady shot to some camcorders, which performs extremely well. I wonder why they didn t implement similar tech to mirrorless... Thanks. Z Link to comment Share on other sites More sharing options...
someguy Posted December 6, 2014 Share Posted December 6, 2014 This is my next camera. Link to comment Share on other sites More sharing options...
ectobuilder Posted December 9, 2014 Share Posted December 9, 2014 Any sign of overheating when filming video? Is it as robust as the A7S? Or does it overheat easily like the original A7? I would assume because the sensor is decoupled from the heat sink due to the sensor stabilization that it would run hotter? Link to comment Share on other sites More sharing options...
jgharding Posted December 10, 2014 Share Posted December 10, 2014 I guess it's just much harder to stabilise full frame compared to four thirds. It's a much larger area and probably much more difficult to eliminate rolling artefacts across it, without greatly increasing scan speed, that is. You'd probably need some clever software stabilisation too, analysing the movement sensor and trying to counteract rolling shutter too. Link to comment Share on other sites More sharing options...
ectobuilder Posted December 11, 2014 Share Posted December 11, 2014 For video (unlike photo), I don't need the shot to be absolutely still. I need it to have two modes: 1) Eases the handheld look but doesn't totally dampen it. It should still look more edgier than the steadicam look. 2) Give us the easing of the motorized gimbal look. Similar to the Follow Mode or Majestic Mode of every motorized gimbal on the market. Link to comment Share on other sites More sharing options...
/p/ Posted December 11, 2014 Share Posted December 11, 2014 Does the a7II have APSC mode? How would shooting in that mkde affect IBIS, would it make anh difference at all? Wouldn't the IBIS need to move less to stabilise the APSC crop? How much difference is there between 3 and 5 axis stabilisation for static handheld shots? Onviously the IBIS is most appealing for use with vintage glass (at least for me) which don't get 5 axis.. Link to comment Share on other sites More sharing options...
Inazuma Posted December 11, 2014 Share Posted December 11, 2014 Where did you read that vintage glass dont get 5 axis? Link to comment Share on other sites More sharing options...
Nikkor Posted December 11, 2014 Share Posted December 11, 2014 http://www.sonyalpharumors.com/anti-seismic-japanese-buildings-to-make-the-a7ii-5-axis-system/ Link to comment Share on other sites More sharing options...
stripedrex Posted December 14, 2014 Share Posted December 14, 2014 I just got the A7II and I see the same jitter with the 55mm f.18. HOWEVER ... I put on the LAEA4 adapter and 85mm 1.4 (which uses 3 axis) and NO JITTER! I wonder if this can be fixed in firmware if the problem is the 2-axis not used with adapters. Can others with A7II confirm what I'm seeing? Link to comment Share on other sites More sharing options...
vincent v Posted December 18, 2014 Share Posted December 18, 2014 Interesting! Are you sure the 85mm+LAEA4 uses 3 axis? It may use 5 because it can send data electronically to the body. Also, could you post video samples of the two lenses on YouTube or WeTransfer? I'm holding back on purchasing the A7II because of the jitter issue. This may change my mind. Link to comment Share on other sites More sharing options...
LTZ470 Posted December 21, 2014 Share Posted December 21, 2014 A7M2 cannot provide 5-axis with any lens that does not have OSS/OS/VC:5 Axis requires a lens with OSS/VC/OS:You get the 2 from the lens and the 3 from the body...total 5-axis...All 5 axis of stabilization will function at all times, even when used with third-party lenses and adapters or lenses with built-in optical stabilization (of course would have to be communicating with camera).So any lens that has OSS/OS/VC that is Sony capable will have 5-Axis, but ONLY OSS/OS/VC lens period will have 5-Axis...to include yaw/pitch in the stabilization, everything else 3-axis...According to Brian Smith:E-Mount lenses with OSS get 2 axis IBIS (Pitch and Yaw) + 3 axis OSS from lens.E-Mount lenses without OSS get full 5 axis IBIS from camera?"Only those lenses without OSS, such as non-OSS E-mount lenses, and 8-pin A-mount lenses when used with LA-EA series adapters, that can also communicate focal length and focal distance enjoy 5-axis IS from the camera.Sony E mount lenses with OSS get 3-axis compensation from the camera, and the other 2-axis pitch and yaw compensation from the lens."Non-native lenses without OSS do not get full 5 axis IBIS from camera."Requires awareness of both focal length and camera to subject distance (focal distance). Bear in mind that X/Y compensation can’t be provided by a lens (with one exception – see below). If the lens can’t communicate focal distance, then the camera can’t provide it. This is the case for almost all 3rd party lenses (although we haven’t tested an AF capable mount adapter, I’m pretty sure it doesn’t work)."Non-native lenses with OSS need to have stabilization turned off."Requires awareness of both focal length and camera to subject distance (focal distance). Bear in mind that X/Y compensation can’t be provided by a lens (with one exception – see below). If the lens can’t communicate focal distance, then the camera can’t provide it. This is the case for almost all 3rd party lenses (although we haven’t tested an AF capable mount adapter, I’m pretty sure it doesn’t work)."Some A-Mount lenses using LA-EA3/4 only have 3 axis compensation (SAL 16, 20 & 500mm).What about Third-Party A-Mount since Sigma and Tamron disable it on their Sony A-Mount lens? Link to comment Share on other sites More sharing options...
xenogears Posted January 8, 2015 Share Posted January 8, 2015 A new firmware version has been released improving the stabilisation performance. Link to comment Share on other sites More sharing options...
LazSim Posted January 22, 2015 Share Posted January 22, 2015 Hi Andy,The A7 II 1.10 firmware (released two weeks ago) is supposed to improve the stabilization, including for videos... any plans to update the review with the new firmware?http://***URL removed***/articles/9214399472/sony-issues-firmware-1-10-for-alpha-7-iiThanks Link to comment Share on other sites More sharing options...
